    Introducing MMM-YouTubeWebView Module
    youtubewebviewembed
    7 Posts 4 Posters 2.7k Views 5 Watching
      sdetweil @KristjanESPERANTO
      @KristjanESPERANTO if you open the developers window console tab view,
      do you see any errors. this module is all in browser
      • KristjanESPERANTOK Offline
        if you open the developers window console tab view, do you see any errors. this module is all in browser
        Unfortunately, I can’t see any errors there.
        Initializing MagicMirror².
        translator.js:122 Loading core translation file: translations/en.json
        VM4 sandbox_bundle:2 Electron Security Warning (Insecure Content-Security-Policy) This renderer process has either no Content Security
          Policy set or a policy with "unsafe-eval" enabled. This exposes users of
          this app to unnecessary security risks.
        For more information and help, consult
        https://electronjs.org/docs/tutorial/security.
        This warning will not show up
        once the app is packaged.
        warnAboutInsecureCSP @ VM4 sandbox_bundle:2
        translator.js:138 Loading core translation fallback file: translations/en.json
        loader.js:165 Load script: modules/default/clock/clock.js
        module.js:484 Module registered: clock
        loader.js:138 Bootstrapping module: clock
        loader.js:165 Load script: vendor/node_modules/moment/min/moment-with-locales.js
        loader.js:165 Load script: vendor/node_modules/moment-timezone/builds/moment-timezone-with-data.js
        loader.js:165 Load script: vendor/node_modules/suncalc/suncalc.js
        loader.js:142 Scripts loaded for: clock
        loader.js:180 Load stylesheet: modules/default/clock/clock_styles.css
        loader.js:145 Styles loaded for: clock
        loader.js:148 Translations loaded for: clock
        loader.js:165 Load script: modules/MMM-YouTubeWebView/MMM-YouTubeWebView.js
        module.js:484 Module registered: MMM-YouTubeWebView
        loader.js:138 Bootstrapping module: MMM-YouTubeWebView
        loader.js:142 Scripts loaded for: MMM-YouTubeWebView
        loader.js:145 Styles loaded for: MMM-YouTubeWebView
        loader.js:148 Translations loaded for: MMM-YouTubeWebView
        loader.js:180 Load stylesheet: css/custom.css
        clock.js:49 Starting module: clock
        module.js:45 Starting module: MMM-YouTubeWebView
        main.js:608 All modules started!
          mmmmh Project Sponsor @doctorwhen
          @doctorwhen Is there a way to control a video’s volume? I embedded the ISS’s livestream and I would like to mute it since every once in a while some radio chatter is on the audio channel. When I have the module hidden it is kinda eerie.
            KristjanESPERANTO Module Developer @mmmmh
            @mmmmh MMM-ISS-Live has a mute option.
              mmmmh Project Sponsor @KristjanESPERANTO
              @KristjanESPERANTO Now that’s a whole new approach. Thanks, it works!
