    MagicMirror not Mirror
    10 Posts 4 Posters 9.1k Views 5 Watching
      PointPubMedia
      I think it’s time to show you some pic ;)
      I’m using MM as a “HUD” for my home automation project. All the notification from home automation are send to the MM!
      I’m using a 42" tv in portrait mode using a RPI3
      Both front panel are kind of door so I can open it and go behind the monitor and also behind the lower part where I’m having all the hardware I’m using for the home automation!
      Still have some thing to do, like putting some color on the wood to fit the house, probably a little brown like the molding on the ceiling!
      • SnilleS Online
        Snille Module Developer
        Hi! Looking great! I’m working on something similar but in a Mirror, I see you have a graph on the lower third, what module is that? I’m thinking of integrating my Fibaro to show things like power consumption and other graps… :)
        Best regards Snille
          PointPubMedia @Snille
          @Snille said in MagicMirror not Mirror:
          Best regards Snille
          It’s an iframe module showing a graph from Grafana using data from an energy metering (Z-wave) that get the entire house power consumption!
          • SnilleS Online
            Ah! Good to know, so the iframe is the thing to use. :) I have to read up on Grafana, looks nice! What Z-Wave controller do you use?
              I’m using Vera Plus and Vera Edge just to handle Z-Wave and all others function, like, scene are handle by openLuup!
                PointPubMedia
                Need some cleanup for the cables and everything but for the moment all the hardware is inside ;)
                1_1484757729373_IMG_20170117_190842.jpg 0_1484757729372_IMG_20170117_190814.jpg
                  shashank @PointPubMedia
                  @PointPubMedia Even i am using Vera Edge for my Home automation, i wanted use remotecontrol module of MM using Virtual switch or Scene from Vera to restart , monitor OFF, Monitor ON at predefined time using Scenes. Can you help me in this how to use luup code below triggers .
                  http://192.168.1.2:8080/remote?action=REBOOT
                  http://192.168.1.2:8080/remote?action=SHUTDOWN
                  http://192.168.1.2:8080/remote?action=MONITORON
                  http://192.168.1.2:8080/remote?action=MONITOROFF
                    PointPubMedia @shashank
                    @shashank said in MagicMirror not Mirror:
                    I’m using a ZWave power outlet instead to control the monitor ON/OFF using motion sensor in the house.
                    But if you still want to play with remotecontrol, you can use some LUA code in a scene!
                    • F Offline
                      foppa @PointPubMedia
                      I have this code in My Vera Plus and Teo scenes, on, off etc.
                      local http = require(“socket.http”)
                      – 5 Second timeout
                      http.TIMEOUT = 1
                      – The return parameters are in a different order from luup.inet.wget(…)
                      result, status = http.request(“http://192.168.2.41:8080/remote?action=MONITOROFF”)
                      @PointPubMedia
                        PointPubMedia @foppa
                        @foppa
                        I’m using http request in my LUA like that
                        local status,result = luup.inet.wget(“http://10.99.99.15:8080/TESTING”")
                        I also have a URLENCODE function to convert my string…
                        function urlencode(str)
                           if (str) then
                              str = string.gsub (str, "\n", "\r\n")
                              str = string.gsub (str, "([^%w ])",
                                 function (c) return string.format ("%%%02X", string.byte(c)) end)
                              str = string.gsub (str, " ", "%%20")
                           end
                           return str
                        end
