    Changing icons of the modules Current Weather and Weather Forecast
    301 Posts 30 Posters 1.7m Views 33 Watching
      Manu85 @sdetweil
      @sdetweil This means that by using existing modules I can change some properties to adapt them to my needs, for example if I use the ISS live module if I change the address in the module’s js can it work?
        sdetweil @Manu85
        @Manu85 existing modules like MMM-SmartWebDisplay take the URL as a config option . no coding required
          sdetweil @Manu85
          @Manu85 I don’t think the ISS-live module can do that, as it calls an api to get the images
            Manu85 @sdetweil
            @sdetweil ah ok I will try, you are my master
              sdetweil @Manu85
              @Manu85 there are other modules too… (note that you can push the iframe right up against the ISS-live output, so they LOOK like they are together…) a little css borders and padding… maybe other stuff…
                Manu85 @sdetweil
                @sdetweil ok, I will try both solutions
                  Manu85 @sdetweil
                  @sdetweil just copying the link doesn’t work
                    sdetweil @Manu85
                    @Manu85 i don’t know… I put it in smartwebdisplay
                      Manu85 @sdetweil
                      @sdetweil I’ll try
                        sdetweil @Manu85
                        @Manu85 here is the module config I used
                        I took the size from the original web page
                        		module: 'MMM-SmartWebDisplay',
                        		position: 'middle_center',	// This can be any of the regions.
                        			logDebug: false, //set to true to get detailed debug logs. To see them : "Ctrl+Shift+i"
                        			height:"350px", //hauteur du cadre en pixel ou %
                        			width:"650px", //largeur
                                       		updateInterval: 0, //in min. Set it to 0 for no refresh (for videos)
                                        	NextURLInterval: 0.5, //in min, set it to 0 not to have automatic URL change. If only 1 URL given, it will be updated
                                        	displayLastUpdate: true, //to display the last update of the URL
                        					displayLastUpdateFormat: 'ddd - HH:mm:ss', //format of the date and time to display
                                        	url: ["https://isstracker.spaceflight.esa.int/"], //source of the URL to be displayed
                        					scrolling: "no", // allow scrolling or not. html 4 only
                        					shutoffDelay: 10000 //delay in miliseconds to video shut-off while using together with MMM-PIR-Sensor
                        I didn’t change anything other than size and url
                        there could be other settings needed…
                        M 3 Replies Last reply Reply Quote 0
                          Manu85 @sdetweil
                          @sdetweil I did like you I see the image clearly on the MM, but it disappears every 3 seconds then recharges continuously, the green LED of the raspberry is lit very often, as if the module required a lot of resources from the pi
                            Manu85 @sdetweil
                            @sdetweil I found, you have to set this setting to “0”, otherwise it reloads every 30 seconds
                            NextURLInterval: 0,
                              Manu85 @sdetweil
                              @sdetweil Hello Sam, I still need your help, I saw KristjanESPERANTO’s module: MMM-OneCallWeather which I really like, so I installed this module I copied his example from js.config which I have completed with my elements longitude, latitude apy key, I tested my api key on the internet in version 2.5 and it works, so I changed the version in MMM-OneCallWeather.js, as Kristjan explains in the github, and when I restart the MM it notifies loading and nothing happens, I tried to understand, but I’m stuck, so I call a specialist :-)
                                sdetweil @Manu85
                                @Manu85 said in Changing icons of the modules Current Weather and Weather Forecast:
                                -OneCall
                                OneCall requires the v3 key and api as I understand it…
                                M M 3 Replies Last reply Reply Quote 0
                                  Manu85 @sdetweil
                                  @sdetweil In detail he says this:
                                  (apiVersion The OpenWeatherMap API version to use. Change it to “2.5” if you have an old apikey
                                  Default value: 3.0)
                                  I understood that if we had an old version then we had to change this parameter but I may have misinterpreted
                                    Manu85 @sdetweil
                                    @sdetweil when I connect to an internet page it gives me this, so I think it’s active, I entered lat, long and api key
                                      sdetweil @Manu85
                                      @Manu85 as far as I can tell, the one call API with keys since mid 2023 is only available via the v3.0 apikey setting
                                        Manu85 @sdetweil
                                        @sdetweil So it pays?
                                          Manu85 @sdetweil
                                          @sdetweil on my weather module I have an api key 2.5, I don’t know if that’s it but I have the impression that the weather data is wrong. Do you know of a weather module for the MM with current and forecast that would be graphically nice and free? because if to have version 3.0 you have to pay that doesn’t interest me, thank you for your help
                                            sdetweil @Manu85
                                            @Manu85 in the console (where u start magicmirror, npm start )
                                            you might see
                                            [23.01.2024 12:12.22.384] [LOG]   [MMM-OneCallWeather] 23-Jan-24 12:12 ** ERROR ** Error: Unauthorized
                                            if you are using the wrong api key
                                            • 15
                                            • 16
                                            • 7 / 16
