    Mirror larger than monitor
    14 Posts 8 Posters 13.6k Views 8 Watching
      A Former User
      does anybody know, if it still looks good if the mirror is larger than the monitor?
      • F Offline
        feuerball
        i got a 50x50 mirror with a approx. 24° monitor.
        i taped the free area of the mirror to get full darkness behind it.
        looks very good :)
          marcwagner
          Could you share some pictures? I would love to see for myself.
          • Z Offline
            ZombieDE
            Is there any downside when the mirror is bigger (*1,5 or *2) than the monitor behind it?
            For example my current idea would look like this:
            alt text
            • strawberry 3.141S Offline
              strawberry 3.141 Project Sponsor Module Developer @ZombieDE
              @ZombieDE the bleeding of the monitor could be more obvious if its not all over the place
              Z 1 Reply Last reply Reply Quote 0
              • Z Offline
                ZombieDE @strawberry 3.141
                @strawberry-3.141 How bad could it get? Sorry, I have no experience with mirrors.
                Do you have any pictures how it could look like?
                (I changed/updated my first question)
                  @ZombieDE this depends on the brightness of your monitor and the light transition of the mirror, for example here you can see the cut where the monitor ends https://forum.magicmirror.builders/topic/1250/my-first-build-using-a-lasered-frame/2
                  • Z Offline
                    @strawberry-3.141 I’ll use the two way mirror form Germany (light transmisson 24 percent)and (probably) the BenQ GL2760H (contrast 1000:1, brightness 300 nits = 300 cd/m²) if you can get something out of it.
                      @ZombieDE I guess @Goldjunge_Chriz can help you more with your question
                        Atheose
                        For what it’s worth, I have a mirror that’s larger than my monitor:
                        Monitor: 12.5x19.5"
                        Mirror: 14x22"
                        It looks totally fine. There was some bleed at the edge of the monitor where you could see some light-glow, but I taped that down with electrical tape and now it’s perfect.
