    MM current version on Raspberry Pi 5 cannot turn off monitor
    53 Posts 9 Posters 40.3k Views 9 Watching
      sdetweil @karsten13
      @karsten13 awesome. I hope my plug will be here today
        jbat66 @sdetweil
        @sdetweil So I ened up using a Yo-Link Plug, and it’s API. I have my monitor plugged into the Yo-Link Plug. I wrote a script that sets a delay time off to 1 minute for the monitor, and then 10 seconds later does a sudo power off command. So the pi shuts down gracefuly and then the monitor. The pi is powered from the usb connector on the monitor.
          JohnGalt @jbat66
          @jbat66 - thanks for the offer. If you do wind up sharing your work, I will take a look and see if it works for me.
          I don’t run any remote control module, and don’t find the “MMM-remote” you reference when I search. I do, however, find at least two (2) different modules called “MMM-Remote-Control” by two different authors. Do you mean one of those?
          My progress so far is that I can get the monitor to turn off using the following script (called by a cron job), but the monitor then turns back on after ~10-15 seconds:
          #!/bin/bash
          # Script to turn off monitor display when called by crontab
          export WAYLAND_DISPLAY=wayland-1
          export XDG_RUNTIME_DIR=/run/user/1000
          /usr/bin/wlr-randr --output HDMI-A-1 --off
          1 J 2 Replies Last reply Reply Quote 0
          • 1 Offline
            1a2a3a @JohnGalt
            @JohnGalt Can you add vc4.force_hotplug=1 to cmdline.txt (on existing line) and check if behaviour changes? Add a space at the end of the line, save and reboot.
            Assuming you are using the first hdmi port closer to the usb c. If using the 2nd port then change the hot plug number to 2
            J J 2 Replies Last reply Reply Quote 0
              jbat66 @JohnGalt
              @JohnGalt said in MM current version on Raspberry Pi 5 cannot turn off monitor:
              This one: https://github.com/Jopyth/MMM-Remote-Control
              Sorry I should have been more clear.
                JohnGalt @1a2a3a
                @1a2a3a said in MM current version on Raspberry Pi 5 cannot turn off monitor:
                vc4.force_hotplug
                That does appear to work! So far I have tried it on two different Pi 4 instances, and each responded to a script called in crontab to turn off the monitor display, and then a script to turn it back on, as expected.
                Thanks.
                  jbat66 @1a2a3a
                  @1a2a3a Thank you Thank you Thank you… That worked for me as well… Message me, and I will get you a pizza like I promised to anyone who could get my pi4 running latest rasbian to turn off the monitor. Adding vc4.force_hotplug=1 to the end of the line in /boot/cmdline.txt did the trick along with using wlr-randr!!
                  I’m serious about the pizza.
                  1 D 2 Replies Last reply Reply Quote 0
                  • 1 Offline
                    1a2a3a @jbat66
                    @jbat66 all good mate. I’m likely in a different geographic region to you. But anyway it was an issue that someone in GitHub that resolved for me so I can’t really take credit. I would point you to the GitHub but it was quite awhile back hence I can’t find the link anymore, therefore I went into my txt file and gave you guys the code.
                      devonian69 @jbat66
                      @jbat66 I know this thread isn’t about getting MMM-Remote-Control to update with this but I was curious if you know how I could go about that.
                        jbat66 @devonian69
                        @devonian69 Do you mean just a normal update for the module?
                        • L Offline
                          liminal1 @jbat66
                          Hey guys,
                          So how did you get this to work? vc4.force_hotplug ive added that to /boot/firmware/cmdline.txt
                          But now what?
                          Im running Raspbian on a Pi 5, so not sure if all of this is even for bookwork :(
                            sdetweil @liminal1
                            @liminal1 note that rapios on pi4 and 5 use a new display manager called Wayland.
                            so all the commands for display MGMT have changed. see the commands posted above.
                            or set the os back to x11. see the raspi-config command
                            • L Offline
                              liminal1 @sdetweil
                              @sdetweil said in MM current version on Raspberry Pi 5 cannot turn off monitor:
                              I did try those commands, they are not working for me. Maybe I need more context for that (which is essentially what I was asking for :) Or I switch back to a slower and less efficient display model that negates having a Pi 5. Is that a correct asumption?
                              Maybe I wasn’t clear, but Im just asking if anyone does have it working on the Pi 5 with Bookworm. What did you use and how did you do it?
                              Thank you :)
                              S 1 2 Replies Last reply Reply Quote 0
                                sdetweil @liminal1
                                @liminal1 the posts above say it was working on bookworm.
                                https://forum.magicmirror.builders/post/114283
                                • 1 Offline
                                  1a2a3a @liminal1
                                  @liminal1 doesn’t matter 4 or 5. As long as bookworm wayland, it’s working fine. For what’s worth, I’m on a 5.
                                  • L Offline
                                    liminal1 @sdetweil
                                    If I create that script and run it, it brings up a logon page :(
                                    • L Offline
                                      liminal1 @1a2a3a
                                      @1a2a3a
                                      Thanks mate :)
                                      But what is working fine? Which part :)
                                      Im quite new to the Pi
                                        sdetweil @liminal1
                                        @liminal1 that makes no sense.
                                        you are running this from a terminal window, right
                                        ctrl-alt-t on the desktop.
                                        nothing login related there
                                        • L Offline
                                          liminal1 @sdetweil
                                          Yes
                                          Its a touch screen, what does this do?
                                          Not sure what you mean?
                                            sdetweil @liminal1
                                            @liminal1 the terminal window has nothing to do with login.
                                            your system should boot to the desktop
                                            then open a terminal window
                                            and type the commands above
                                            or use an ssh session from your pc
                                            • 2 / 3
