    MMM-CalendarExt3
    689 Posts 82 Posters 3.3m Views 86 Watching
      1lolo94
      I had to resize - sorry
        1lolo94 @MMRIZE
        @MMRIZE - correct, sorry - I was testing it out both ways and was about 6 hours straight trying to get everything setup.
        I would like it how it was in the top right. I removed all the calendar coding and the weather shows up correctly.
           		module: "alert",
           		module: "updatenotification",
           		position: "top_bar"
           		module: "clock",
           		position: "top_left"
           		module: "weather",
           			type: "current",
           			locationID: "517xx2078", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
           			apiKey: "1325b9a82957229ac168e428011778d8",
           			roundTemp: true,
           		module: "weather",
           		//header: "Weather Forecast",
           			type: "forecast",
           			locationID: "xxx", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
           			fade: false,
           			colored: "true",
           			roundTemp: true,
        S 2 Replies Last reply
          sdetweil @1lolo94
          @1lolo94 just fyi. you can disable modules by adding a line for each
          disabled:true,
          between the module: and config: lines
          note the trailing comma
            sdetweil @1lolo94
            @1lolo94 note that each section is a stack, 1st in config.js in that position goes first , next next, etc. if too much, it gets clipped off at the bottom of the screen.
            so if ext3 cal is first, others are below it.
            you could change css to prove it
            in custom.css
            body {
              overflow: default;
            then try to scroll the page, up to see below the fold
            1 1 Reply Last reply
              1lolo94 @sdetweil
              @sdetweil So i did everything you said (and i may have messed up) and now all i see if the calendar at the bottom.
              Config.js
              	language: "en",
              	locale: "en-US",
              	timeFormat: 12,
              	units: "imperial",
              			module: "alert",
              			position: "top_bar"
                                      module: "MMM-CalendarExt3",
                                      position: "bottom_bar",
                                      title: "",
                                        mode: "",
                                        weekIndex: 0,
                                        weeksInView: 4,
                                        instanceId: "basicCalendar",
                                        locale: 'en-EN',
                                        maxEventLines: 5,
                                        firstDayOfWeek: 0,
                                        refreshInterval: 120000,
                                        animationSpeed: 0,
                                        useSymbol: false,
                                        calendarSet: ['us_holiday','family'],
                                      position: "",
                                        broadcastPastEvents: true,
                                                url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics",
                                                color: "#6699ff"
                                      position: "",
                                      maximumNumberOfDays: 60,
                                        animationSpeed: 0,
                                        fetchInterval: 100000,
                                        useSymbol: false,
                                                url: "https://calendar.google.com/calendar/ical/508cafe09ed07b094af03472b6e4b4df1afcc8f9bd961857492b70bcc6978e12%40group.calendar.google.com/private-9092589d68a2b474a7739751badffb79/basic.ics",
                                                color: "yellow",
                                                      user: 'xx@gmail.com',
                                                      pass: 'xxxxxx',
                                                      method: 'basic'
              			module: "clock",
              			module: "weather",
              				type: "current",
              				locationID: "xx", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
              				roundTemp: true,
              			module: "weather",
              				type: "forecast",
              				locationID: "51xxx72078", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
              				fade: false,
              				colored: "true",
              				roundTemp: true,
              Custom CSS
              /* MagicMirror² Custom CSS Sample
               * Change color and fonts here.
               * Beware that properties cannot be unitless, so for example write '--gap-body: 0px;' instead of just '--gap-body: 0;'
               * MIT Licensed.
              /* Uncomment and adjust accordingly if you want to import another font from the google-fonts-api: */
              /* @import url('https://fonts.googleapis.com/css2?family=Poppins:wght@100;300;400;700&display=swap'); */
              :root {
                --color-text: #999;
                --color-text-dimmed: #666;
                --color-text-bright: #fff;
                --color-background: black;
                --font-primary: "Roboto Condensed";
                --font-secondary: "Roboto";
                --font-size: 20px;
                --font-size-small: 0.75rem;
                --gap-body-top: 60px;
                --gap-body-right: 60px;
                --gap-body-bottom: 60px;
                --gap-body-left: 60px;
                --gap-modules: 30px;
              body {
                overflow: default;
               body {
               color: #000;
               .dimmed {
                color: #000;
              .normal {
                color: #000;
              .bright {
                color: #000;
              .MMM-CalendarExt3 {
                      margin-bottom: -5px;
                      width: 100%;
                      height: 575px;
                      font-size: 20px;
              .CX3 .cw {
                      display:none
              .CX3 .event.singleday {
                border-left:4px solid var(--calendarColor);
              .CX3 .event.singleday:not(.useSymbol)::before {
                content: '';
              .module.clock {
                background-color:rgba(255,255,255,0.5);
                border-radius:8px;
                padding:8px;
              .module.weather {
                border-radius:8px;
                padding:8px;
              .module.weather {
                border-radius:8px;
                padding:8px;
                color: #000;
              .dimmed {
              /*  color: #666; */
                  color: #000;
              .normal {
              /*  color: #999;*/
                  color: #000;
              .bright {
                color: #000;
              .header {
                color: #000;
                sdetweil @1lolo94
                @1lolo94 sorry it was html, not body
                html {
                   overflow:default;
                  1lolo94 @sdetweil
                  @sdetweil Thanks for the quick response - same issue :(
                  All I see is the calendar at the bottom
                    sdetweil @1lolo94
                    @1lolo94 please change this
                       position: "",
                    to
                     //    position: "",
                    “” causes an error
                    while no position setting is ok
                      1lolo94 @sdetweil
                      @sdetweil YOU ARE AMAZING!
                      Last two questions and I will leave you alone :)
                      1. what settings do i need to change to get the calendar to fit the entire bottom of the screen? Is that possible?
                      2. How can I add a background to this - but have the calendar, weather, etc in front of it? I have seen some others have nature, clouds, etc.
                      Thanks again!
                      S 1 3 Replies Last reply
                        sdetweil @1lolo94
                        @1lolo94 background
                        use one of the modules that displays what you like and use position fullscreen_below, 3d, below is furthest away from the viewer , above is closest to the viewer and default is between them
                        calendar full width. I don’t know, mm sets margin, all the way around so content is NOT jammed against the edge…
                        see css/main.css at the top, 60px as I recall
                        you can override that in custom.css
                          sdetweil @1lolo94
                          @1lolo94 said in MMM-CalendarExt3:
                          I am here every day. am moderator
                          ask away.
                          others smarter than me will jump in too
                            1lolo94 @1lolo94
                            @sdetweil I was able to get the module - MMM-Wallpaper installed and working great - but depending on the picture, i cannot see the the calendar, events, days, etc. I’m assuming that is in the custom cc settings?
                              sdetweil @1lolo94
                              @1lolo94 no cool thing there. some background images will conflict w the foreground…
                              I want dynamic opposite, but… no such thing
                                bobbylx
                                Hello all, just have a couple fine tuning questions for you. Both seem easy but I can’t seem to figure out why it’s not working. FWIW my MM has been running great for months now, finally doing some tweaking.
                                So I’ve got MMM-Calendarext3 setup to only show 1 calendar, it’s my family google account. The last 2 things I would like to accomplish are having the text for long events scroll with useMarquee: true and then also to have the eventTransformer search for a name in the event title and change the color according to that.
                                For some reason, I can’t get either of these to work. Config.js below. If I understand correctly, I shouldn’t need to add anything to custom.css correct? With the config file below, my calendar does not load at all, just get blank screen stating please create a config file, if I hash out the transformer stuff then it loads but never scrolls (marquee). Any advice from ya’ll smart folks?
                                                               title: "",
        mode: "",
        weekIndex: 0,
        weeksInView: 5,
        locale: 'en-EN',
        maxEventLines: 5,
        fontSize: '26px',
        firstDayOfWeek: 0,
        animationSpeed: 0,
        useMarquee: true,
        useSymbol: false,
        useWeather: true,
        displayWeatherTemp: true,
                                                               weatherPayload: (payload) => {
                                         if (Array.isArray(payload?.forecastArray)) {
                                           payload.forecastArray = payload.forecastArray.map((f) => {
                                             f.maxTemperature = Math.round(f.maxTemperature * 9 / 5 + 32)
                                             f.minTemperature = Math.round(f.minTemperature * 9 / 5 + 32)
                                             return f
                                         return payload
                                                       eventTransformer: (ev) => {
                                                        if (ev.title.search('Allie') > -1) ev.color = 'blue'
                                                        return ev
                                H M 2 Replies Last reply
                                • H
                                  hrmax @bobbylx
                                  @bobbylx It could be because you aren’t settings the mode to week or month? It seems that the default is week but that would require that you omit the tag altogether rather than explicitly setting it to an empty string.
                                  B 1 Reply Last reply
                                    MMRIZE @bobbylx
                                    @bobbylx said in MMM-CalendarExt3:
                                         return payload
                                       } // <== HERE
                                                        return ev
                                    You’ve missed comma(,) in the end of weatherPayload definition.
                                      bobbylx @hrmax
                                      @hrmax said in MMM-CalendarExt3:
                                      I have it with no mode and a 5 week rolling view, so the current week is always at the top. I did change it back to month for testing but made no difference.
                                      @MMRIZE said in MMM-CalendarExt3:
                                           return payload
                                         } // <== HERE
                                                          return ev
                                      Awesome, thank you! That did it.
                                      Last one, using the Marquee for long calendar events. Is there anything else I need to do to make that work? See my config.js above, I added useMarquee: ‘true’ but it changed nothing. I assume I’m missing something simple again.
                                      • L
                                        Lilleberg
                                        I have an issue trying to show events from Googles shared family calendar. I have several Google calendars that shows perfectly in the CalendarExt3 module. But to show events from the shared family calendar has been quite an issue.
                                        I found out that I had to install the MMM-GoogleCalendar. In this module I manage to show the events from the shared calendar. But they won´t show up in the CalendarExt3 module.
                                        I found this code (https://github.com/MMRIZE/MMM-CalendarExt3/wiki/Compatible-with-randomBrainstormer-MMM-GoogleCalendar) that should resolve it, but when i paste this code at the end of the config of the CalendarExt3 module. No events show up. Even the events that allready shows from the other Google Calendars.
                                        I have the default calendar module to fetch the events from all of my Google Calendars, and the the GoogleCalendar module to fetch the shared calendar. I tried removing the default calendar module from the config file, and with just one calendar in the GoogleCalendar module. But no result.
                                        It shows just fine in the GoogleCalendar module, so it seems to be a problem to convert the events from the GoogleCalendar module to the CalendarExt3 module.
                                        S M 2 Replies Last reply
                                          sdetweil @Lilleberg
                                          @Lilleberg ext3 gets it’s events from another calendar module. either the default calendar or another.
                                          so if you use MMM-GoogleCalendar then it has the calendar url.
                                          L 1 Reply Last reply
                                          • L
                                            Lilleberg @sdetweil
                                            @sdetweil Not sure if I understod you here. What do you mean with the last sentence?
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 34
                                            • 35
                                            • 23 / 35
