    Mobile app (bachelor thesis)
    116 Posts 31 Posters 205.2k Views 31 Watching
    • strawberry 3.141S
      I’m sorry, there is a bug in the module, which will override the pairing process each time you start the mirror. I made a bugfix over my phone which hopefully fixes it. Please update the module. It can be that you have to redo the pairing process.
      tosti007T 1 Reply Last reply
      • tosti007T
        tosti007 Module Developer @strawberry 3.141
        @strawberry-3.141 so appart from my hughw ip fail it’s not just me? :O
        If there is anything don’t hesitate to contact me!
        ProfileSwitcher, TouchNotifications
        • K
          kurt
          Also did it and good luck too !
          • K
            kurt
            Just did it, also good luck!
            If you need a beta tester with absolut no programming experience…
              plumcraft
              Can you resend me by email the link where i can download the app ? (i delete all emails in my spam folder on a daily basis)
              thanks
              • strawberry 3.141S
                strawberry 3.141 Project Sponsor Module Developer @plumcraft
                @plumcraft can you send me your mail address in a private message?
                  bminer1
                  I cant get the QR Code to come back up. My app is saying “Cannot Establish Connection to MagicMirror”. I didnt have the IP Address in there so i added it and now i cant get the QR code to come back on.
                  • strawberry 3.141S
                    strawberry 3.141 Project Sponsor Module Developer @bminer1
                    @bminer1 remove the qr.png and mobile.json in the module directory
                    B 1 Reply Last reply
                      bminer1 @strawberry 3.141
                      @strawberry-3.141
                      I deleted the files and it came back up but the app is still not connecting.
                      defaults: {
                          ip: '192.168.......',
                          qrSize: 300,
                          qrTimer: 60 * 1000 },
                        bminer1 @bminer1
                        @strawberry
                        I deleted the Module and reinstalled, the QR code is not generating now. I made a mess of this. ugh.
                        • lolobyteL
                          lolobyte
                          @strawberry-3-141
                          it’s safe now to update module and app?
                          • strawberry 3.141S
                            @bminer1 you shouldn’t edit the files, remove the module directory completely, clone again, put your config in config.js if you dont succeed send me a private message and i will help you
                            @lolobyte, still you should uninstall the app first before upgrading to the newest prototype, but the magic mirror module should be fine with just updating
                            • lolobyteL
                              lolobyte
                              i don’t know why but i had again problems scanning the qr code on the Mirror.
                              After the qr code automated was hidden and all modules started i went to my laptop starting a vnc session and opening the qr code with mirage and the scan was simle and fast done, the app has synchronized an it works now.
                              Maybe the qr picture is to dark or to small, i don’t know what’s the mater with qr scanning on my iPhone 6s.
                              • strawberry 3.141S
                                strawberry 3.141 Project Sponsor Module Developer @lolobyte
                                @lolobyte next time you could try to use the config option qrSize
                                lolobyteL 1 Reply Last reply
                                • lolobyteL
                                  lolobyte @strawberry 3.141
                                  @strawberry-3.141
                                  ok, i’ll try that
                                    @strawberry-3.141
                                    Im googling how to remove the module directory but its not really clear. Is it as simple as deleting the module folder or is there more to it?
                                    • tosti007T
                                      tosti007 Module Developer @bminer1
                                      @bminer1 yea just deleting the folder removes a module
                                        bminer1
                                        Hi Strawberry 3.141, I am still having an issue with using the mobile app.
                                        Below is the steps i took based on the install guide from the git and deleting the folder.
                                        Here is the install:
                                        pi@raspberrypi:~/MagicMirror/modules $ git clone https://github.com/fewieden/MMM-Mobile.git
                                        Cloning into ‘MMM-Mobile’…
                                        remote: Counting objects: 84, done.
                                        remote: Compressing objects: 100% (21/21), done.
                                        remote: Total 84 (delta 12), reused 0 (delta 0), pack-reused 63
                                        Unpacking objects: 100% (84/84), done.
                                        Checking connectivity… done.
                                        Then the Dependencies
                                        pi@raspberrypi:~/MagicMirror/modules/MMM-Mobile $ npm install
                                        mmm-mobile@1.0.0 preinstall /home/pi/MagicMirror/modules/MMM-Mobile
                                        node scripts/preinstall.js
                                        Creating Backup for config.js!
                                        Saving updated config.js!
                                        mmm-mobile@1.0.0 /home/pi/MagicMirror/modules/MMM-Mobile
                                        ├─┬ async@2.1.4
                                        │ └── lodash@4.17.4
                                        ├── moment@2.17.1
                                        ├── qr-image@3.2.0
                                        └── simple-git@1.65.0
                                        add to config.js file
                                        “modules”: [
                                        “module”: “alert”
                                        module: “MMM-Mobile”
                                        the QRcode popped up but still would not connect
                                        in the app, i put in my IP address and it said Connected for a milisecond then showed could not connect again
                                        • strawberry 3.141S
                                          problem solved after adding ip to config.js
                                          • strawberry 3.141S
                                            I sent an email again with the 3rd prototype. Make sure to check your spam folders.
                                            I also would like to ask to take part in the survey which I sent by mail to evaluate the app.
                                            As it turned out the last fix didn’t solve the issue with loosing pairing on a
                                            restart. This is hopefully resolved now.
                                            In the settings there is an advanced and simple mode (simple mode is
                                            currently available for the default calendar only).
                                            Also there is a new entry in the menu to do some tasks (restart mirror,
                                            show/hide modules).
                                            Don't forget to update the MMM-Mobile
                                            Problems should be created as issues on github.
                                            • 3 / 6
