    Mobile app (bachelor thesis)
    116 Posts 31 Posters 199.0k Views 31 Watching
      bminer1
      I cant get the QR Code to come back up. My app is saying “Cannot Establish Connection to MagicMirror”. I didnt have the IP Address in there so i added it and now i cant get the QR code to come back on.
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @bminer1
        @bminer1 remove the qr.png and mobile.json in the module directory
          bminer1 @strawberry 3.141
          @strawberry-3.141
          I deleted the files and it came back up but the app is still not connecting.
          defaults: {
              ip: '192.168.......',
              qrSize: 300,
              qrTimer: 60 * 1000 },
            bminer1 @bminer1
            @strawberry
            I deleted the Module and reinstalled, the QR code is not generating now. I made a mess of this. ugh.
            • L Offline
              lolobyte
              @strawberry-3-141
              it’s safe now to update module and app?
                @bminer1 you shouldn’t edit the files, remove the module directory completely, clone again, put your config in config.js if you dont succeed send me a private message and i will help you
                @lolobyte, still you should uninstall the app first before upgrading to the newest prototype, but the magic mirror module should be fine with just updating
                • L Offline
                  lolobyte
                  i don’t know why but i had again problems scanning the qr code on the Mirror.
                  After the qr code automated was hidden and all modules started i went to my laptop starting a vnc session and opening the qr code with mirage and the scan was simle and fast done, the app has synchronized an it works now.
                  Maybe the qr picture is to dark or to small, i don’t know what’s the mater with qr scanning on my iPhone 6s.
                    strawberry 3.141 Project Sponsor Module Developer @lolobyte
                    @lolobyte next time you could try to use the config option qrSize
                    • L Offline
                      lolobyte @strawberry 3.141
                      @strawberry-3.141
                      ok, i’ll try that
                        @strawberry-3.141
                        Im googling how to remove the module directory but its not really clear. Is it as simple as deleting the module folder or is there more to it?
                        • T Offline
                          tosti007 Module Developer @bminer1
                          @bminer1 yea just deleting the folder removes a module
                          If there is anything don’t hesitate to contact me!
                          ProfileSwitcher, TouchNotifications
                            bminer1
                            Hi Strawberry 3.141, I am still having an issue with using the mobile app.
                            Below is the steps i took based on the install guide from the git and deleting the folder.
                            Here is the install:
                            pi@raspberrypi:~/MagicMirror/modules $ git clone https://github.com/fewieden/MMM-Mobile.git
                            Cloning into ‘MMM-Mobile’…
                            remote: Counting objects: 84, done.
                            remote: Compressing objects: 100% (21/21), done.
                            remote: Total 84 (delta 12), reused 0 (delta 0), pack-reused 63
                            Unpacking objects: 100% (84/84), done.
                            Checking connectivity… done.
                            Then the Dependencies
                            pi@raspberrypi:~/MagicMirror/modules/MMM-Mobile $ npm install
                            mmm-mobile@1.0.0 preinstall /home/pi/MagicMirror/modules/MMM-Mobile
                            node scripts/preinstall.js
                            Creating Backup for config.js!
                            Saving updated config.js!
                            mmm-mobile@1.0.0 /home/pi/MagicMirror/modules/MMM-Mobile
                            ├─┬ async@2.1.4
                            │ └── lodash@4.17.4
                            ├── moment@2.17.1
                            ├── qr-image@3.2.0
                            └── simple-git@1.65.0
                            add to config.js file
                            “modules”: [
                            “module”: “alert”
                            module: “MMM-Mobile”
                            the QRcode popped up but still would not connect
                            in the app, i put in my IP address and it said Connected for a milisecond then showed could not connect again
                              problem solved after adding ip to config.js
                                I sent an email again with the 3rd prototype. Make sure to check your spam folders.
                                I also would like to ask to take part in the survey which I sent by mail to evaluate the app.
                                As it turned out the last fix didn’t solve the issue with loosing pairing on a
                                restart. This is hopefully resolved now.
                                In the settings there is an advanced and simple mode (simple mode is
                                currently available for the default calendar only).
                                Also there is a new entry in the menu to do some tasks (restart mirror,
                                show/hide modules).
                                Don't forget to update the MMM-Mobile
                                Problems should be created as issues on github.
                                • L Offline
                                  @strawberry-3.141
                                  Thank you for the new admin functions.
                                  It’s possible for the app to realize if there is an available update for one or more of the installed modules and make this visible with a badge number?
                                  Similar function like the default “updatenotification” module from @michmich
                                    @lolobyte
                                    Spoiler: I want to integrate push notifications which will do exactly this. But that will be after my thesis.
                                    • L Offline
                                      @strawberry-3.141
                                      • L Offline
                                        lolobyte
                                        @strawberry-3-141
                                        Hey Man. Hope you are well.
                                        So, i updated the module with git pull
                                        and npm install.
                                        well done the system.
                                        Then removed the app an installed again.
                                        Now here my observations and questions.
                                        In the Menu Module Verfügbar is nothing listed. I tried with pull down but no modules listed like before.
                                        Only this comment
                                        Kein Modul erfüllt diese Kriterien.
                                        Installiert -> pull down -> all my installled modules are listed. OK
                                        Regionen works well also the Synchronisieren and QR Code recognizing with phone.
                                        All Befehle are working well.
                                        My question.
                                        What exactly is the difference between simple an advanced mode.
                                        I don’t understand what you are meaning with the default calendar only.
                                        What is the difference?
                                        Good luck with your thesis and an lucky punch with it.
                                          @lolobyte simple mode is only available for the configuration of the default calendar module. then you cannot specify custom stuff, only properties which are defined for this module. this will come for all default modules and modules which will be supported from their developers
                                            strawberry 3.141 Project Sponsor Module Developer @strawberry 3.141
                                            @strawberry-3.141 as a reminder the survey, I sent by mail, for the evaluation of the app will be closed tomorrow, would be great to get more feedback
                                            L R Y 3 Replies Last reply Reply Quote 0
                                            • 4 / 6
