    Mobile app (bachelor thesis)
    116 Posts 31 Posters 205.4k Views 31 Watching
      bminer1 @strawberry 3.141
      @strawberry-3.141
      Im googling how to remove the module directory but its not really clear. Is it as simple as deleting the module folder or is there more to it?
      tosti007T 1 Reply Last reply
      • tosti007T
        tosti007 Module Developer @bminer1
        @bminer1 yea just deleting the folder removes a module
        If there is anything don’t hesitate to contact me!
        ProfileSwitcher, TouchNotifications
          bminer1
          Hi Strawberry 3.141, I am still having an issue with using the mobile app.
          Below is the steps i took based on the install guide from the git and deleting the folder.
          Here is the install:
          pi@raspberrypi:~/MagicMirror/modules $ git clone https://github.com/fewieden/MMM-Mobile.git
          Cloning into ‘MMM-Mobile’…
          remote: Counting objects: 84, done.
          remote: Compressing objects: 100% (21/21), done.
          remote: Total 84 (delta 12), reused 0 (delta 0), pack-reused 63
          Unpacking objects: 100% (84/84), done.
          Checking connectivity… done.
          Then the Dependencies
          pi@raspberrypi:~/MagicMirror/modules/MMM-Mobile $ npm install
          mmm-mobile@1.0.0 preinstall /home/pi/MagicMirror/modules/MMM-Mobile
          node scripts/preinstall.js
          Creating Backup for config.js!
          Saving updated config.js!
          mmm-mobile@1.0.0 /home/pi/MagicMirror/modules/MMM-Mobile
          ├─┬ async@2.1.4
          │ └── lodash@4.17.4
          ├── moment@2.17.1
          ├── qr-image@3.2.0
          └── simple-git@1.65.0
          add to config.js file
          “modules”: [
          “module”: “alert”
          module: “MMM-Mobile”
          the QRcode popped up but still would not connect
          in the app, i put in my IP address and it said Connected for a milisecond then showed could not connect again
          • strawberry 3.141S
            problem solved after adding ip to config.js
            • strawberry 3.141S
              I sent an email again with the 3rd prototype. Make sure to check your spam folders.
              I also would like to ask to take part in the survey which I sent by mail to evaluate the app.
              As it turned out the last fix didn’t solve the issue with loosing pairing on a
              restart. This is hopefully resolved now.
              In the settings there is an advanced and simple mode (simple mode is
              currently available for the default calendar only).
              Also there is a new entry in the menu to do some tasks (restart mirror,
              show/hide modules).
              Don't forget to update the MMM-Mobile
              Problems should be created as issues on github.
              lolobyteL 1 Reply Last reply
              • lolobyteL
                lolobyte @strawberry 3.141
                @strawberry-3.141
                Thank you for the new admin functions.
                It’s possible for the app to realize if there is an available update for one or more of the installed modules and make this visible with a badge number?
                Similar function like the default “updatenotification” module from @michmich
                • strawberry 3.141S
                  strawberry 3.141 Project Sponsor Module Developer @lolobyte
                  @lolobyte
                  Spoiler: I want to integrate push notifications which will do exactly this. But that will be after my thesis.
                  • lolobyteL
                    @strawberry-3.141
                    • lolobyteL
                      lolobyte
                      @strawberry-3-141
                      Hey Man. Hope you are well.
                      So, i updated the module with git pull
                      and npm install.
                      well done the system.
                      Then removed the app an installed again.
                      Now here my observations and questions.
                      In the Menu Module Verfügbar is nothing listed. I tried with pull down but no modules listed like before.
                      Only this comment
                      Kein Modul erfüllt diese Kriterien.
                      Installiert -> pull down -> all my installled modules are listed. OK
                      Regionen works well also the Synchronisieren and QR Code recognizing with phone.
                      All Befehle are working well.
                      My question.
                      What exactly is the difference between simple an advanced mode.
                      I don’t understand what you are meaning with the default calendar only.
                      What is the difference?
                      Good luck with your thesis and an lucky punch with it.
                      • strawberry 3.141S
                        @lolobyte simple mode is only available for the configuration of the default calendar module. then you cannot specify custom stuff, only properties which are defined for this module. this will come for all default modules and modules which will be supported from their developers
                        • strawberry 3.141S
                          strawberry 3.141 Project Sponsor Module Developer @strawberry 3.141
                          @strawberry-3.141 as a reminder the survey, I sent by mail, for the evaluation of the app will be closed tomorrow, would be great to get more feedback
                          lolobyteL R yawnsY 3 Replies Last reply
                          • lolobyteL
                            @strawberry-3.141
                            Hy @strawberry-3-141
                            how i said.
                            In the menu “Module” “Verfügar” were in the past a lot of available modules after a pull down. Now there is nothing. He give a error message “Fehlgeschlagen: Module können nicht aktualisiert werden!”
                            At “Installiert” all my installed on configured modules in the config.js are available. Wen i chose then a Module to see the details an wish to go back then the “verfügbar” entry is chosen by the app. In my opinion it may be better to chose “Installiert”
                            What happens after the evaluation step?
                              roramirez Core Contributors @strawberry 3.141
                              @strawberry-3.141 I try the pair the app when MagicMirror and can’t
                              The log of cli on MagicMirror say
                              Missing error handler on `socket`.
                              TypeError: Data must be a string or a buffer
                                  at TypeError (native)
                                  at Hash.update (crypto.js:74:16)
                                  at Array.io.of.use (/home/piMagicMirror/modules/MMM-Mobile/node_helper.js:166:52)
                                  at run (/home/piMagicMirror/node_modules/socket.io/lib/namespace.js:116:11)
                                  at Namespace.run (/home/piMagicMirror/node_modules/socket.io/lib/namespace.js:128:3)
                                  at Namespace.add (/home/piMagicMirror/node_modules/socket.io/lib/namespace.js:157:8)
                                  at Client.connect (/home/piMagicMirror/node_modules/socket.io/lib/client.js:76:20)
                                  at Client.ondecoded (/home/piMagicMirror/node_modules/socket.io/lib/client.js:190:10)
                                  at Decoder.Emitter.emit (/home/piMagicMirror/node_modules/socket.io/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20)
                                  at Decoder.add (/home/piMagicMirror/node_modules/socket.io/node_modules/socket.io-parser/index.js:246:12)
                                PeppaPigKilla
                                Has this happened ?
                                • strawberry 3.141S
                                  @lolobyte the app takes the modules from http://beta.magicmirror.builders/modules maybe the service wasnt available at the time you tried. The thing with the tabs is on my list, there are also some other problems with the history stack.
                                  evaluation
                                  .then(finishThesis)
                                  .then(defineConfigStandardWithSimilarModules)
                                  .then(postTheResultsOfTheUserSurvey)
                                  .then(improveTheApp)
                                  .then(bringTheAppsIntoAppStoresOneDay);
                                  @roramirez does the mirror show the qrcode or does it happen before?
                                  @PeppaPigKilla what happened?
                                  R 1 Reply Last reply
                                    PeppaPigKilla
                                    The app been released ?
                                    Searched the store, but couldnt find anything.
                                    • strawberry 3.141S
                                      strawberry 3.141 Project Sponsor Module Developer @PeppaPigKilla
                                      @PeppaPigKilla no, there was just a beta testing of the prototypes for Android and iOS yet.
                                      P 1 Reply Last reply
                                        PeppaPigKilla @strawberry 3.141
                                        @strawberry-3.141
                                        ok, Thanks for the info. Look vforward to the release
                                          @strawberry-3.141 said in Mobile app (bachelor thesis):
                                          @strawberry-3.141 Yes, it show me the QR code. This happens after Paired the app with MagicMirror.
                                          • yawnsY
                                            yawns Moderator @strawberry 3.141
                                            Your email reminder was moved to JunkMail by outlook.com, so I didn’t notice.
                                            I completed the survey anyway
                                            • 4 / 6
