    Mobile app (bachelor thesis)
    116 Posts 31 Posters 203.2k Views 31 Watching
    • strawberry 3.141S
      strawberry 3.141 Project Sponsor Module Developer @lolobyte
      @lolobyte
      Spoiler: I want to integrate push notifications which will do exactly this. But that will be after my thesis.
      • L
        lolobyte @strawberry 3.141
        @strawberry-3.141
        • L
          lolobyte
          @strawberry-3-141
          Hey Man. Hope you are well.
          So, i updated the module with git pull
          and npm install.
          well done the system.
          Then removed the app an installed again.
          Now here my observations and questions.
          In the Menu Module Verfügbar is nothing listed. I tried with pull down but no modules listed like before.
          Only this comment
          Kein Modul erfüllt diese Kriterien.
          Installiert -> pull down -> all my installled modules are listed. OK
          Regionen works well also the Synchronisieren and QR Code recognizing with phone.
          All Befehle are working well.
          My question.
          What exactly is the difference between simple an advanced mode.
          I don’t understand what you are meaning with the default calendar only.
          What is the difference?
          Good luck with your thesis and an lucky punch with it.
          • strawberry 3.141S
            @lolobyte simple mode is only available for the configuration of the default calendar module. then you cannot specify custom stuff, only properties which are defined for this module. this will come for all default modules and modules which will be supported from their developers
            • strawberry 3.141S
              strawberry 3.141 Project Sponsor Module Developer @strawberry 3.141
              @strawberry-3.141 as a reminder the survey, I sent by mail, for the evaluation of the app will be closed tomorrow, would be great to get more feedback
              L R Y 3 Replies Last reply Reply Quote 0
              • L
                @strawberry-3.141
                Hy @strawberry-3-141
                how i said.
                In the menu “Module” “Verfügar” were in the past a lot of available modules after a pull down. Now there is nothing. He give a error message “Fehlgeschlagen: Module können nicht aktualisiert werden!”
                At “Installiert” all my installed on configured modules in the config.js are available. Wen i chose then a Module to see the details an wish to go back then the “verfügbar” entry is chosen by the app. In my opinion it may be better to chose “Installiert”
                What happens after the evaluation step?
                  roramirez Core Contributors @strawberry 3.141
                  @strawberry-3.141 I try the pair the app when MagicMirror and can’t
                  The log of cli on MagicMirror say
                  Missing error handler on `socket`.
                  TypeError: Data must be a string or a buffer
                      at TypeError (native)
                      at Hash.update (crypto.js:74:16)
                      at Array.io.of.use (/home/piMagicMirror/modules/MMM-Mobile/node_helper.js:166:52)
                      at run (/home/piMagicMirror/node_modules/socket.io/lib/namespace.js:116:11)
                      at Namespace.run (/home/piMagicMirror/node_modules/socket.io/lib/namespace.js:128:3)
                      at Namespace.add (/home/piMagicMirror/node_modules/socket.io/lib/namespace.js:157:8)
                      at Client.connect (/home/piMagicMirror/node_modules/socket.io/lib/client.js:76:20)
                      at Client.ondecoded (/home/piMagicMirror/node_modules/socket.io/lib/client.js:190:10)
                      at Decoder.Emitter.emit (/home/piMagicMirror/node_modules/socket.io/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20)
                      at Decoder.add (/home/piMagicMirror/node_modules/socket.io/node_modules/socket.io-parser/index.js:246:12)
                    PeppaPigKilla
                    Has this happened ?
                    • strawberry 3.141S
                      @lolobyte the app takes the modules from http://beta.magicmirror.builders/modules maybe the service wasnt available at the time you tried. The thing with the tabs is on my list, there are also some other problems with the history stack.
                      evaluation
                      .then(finishThesis)
                      .then(defineConfigStandardWithSimilarModules)
                      .then(postTheResultsOfTheUserSurvey)
                      .then(improveTheApp)
                      .then(bringTheAppsIntoAppStoresOneDay);
                      @roramirez does the mirror show the qrcode or does it happen before?
                      @PeppaPigKilla what happened?
                        PeppaPigKilla
                        The app been released ?
                        Searched the store, but couldnt find anything.
                        • strawberry 3.141S
                          strawberry 3.141 Project Sponsor Module Developer @PeppaPigKilla
                          @PeppaPigKilla no, there was just a beta testing of the prototypes for Android and iOS yet.
                            PeppaPigKilla @strawberry 3.141
                            @strawberry-3.141
                            ok, Thanks for the info. Look vforward to the release
                              @strawberry-3.141 said in Mobile app (bachelor thesis):
                              @strawberry-3.141 Yes, it show me the QR code. This happens after Paired the app with MagicMirror.
                              • Y
                                yawns Moderator @strawberry 3.141
                                Your email reminder was moved to JunkMail by outlook.com, so I didn’t notice.
                                I completed the survey anyway
                                  1m2
                                  embarrassed to even ask this but is there a step by step typed out of this other than what’s in the “README.dm” file, I mean some thing a little more detailed? noob status. apologies. I saw bminer1’s post but I’m looking for even more detail than that since I don’t know all the correct command lines. I have the .apk, just need help as my install failed.
                                  • strawberry 3.141S
                                    strawberry 3.141 Project Sponsor Module Developer @1m2
                                    @1m2 if you want to, i can help via a remote desktop session
                                    1 1 Reply Last reply Reply Quote 1
                                      1m2 @strawberry 3.141
                                      @strawberry-3.141
                                      No TY Sir, I want to learn on my own but I also never give access to my machines, even if it is just the Pi. It’s cool, I’ll work on it. TY for the offer Sir!
                                      • L
                                        lolobyte @1m2
                                        @1m2 that is you decision but i tell you @strawberry-3-141 has helped me in the past, and not only once. He is very gentle and his intention is the only one to help YOU.
                                        We made a connection with TeamViever, he logged in to your raspi with putty and his work began.
                                        Don’t worry, you can see at your monitor what he’s doing.
                                        • cowboysdudeC
                                          cowboysdude Module Developer @lolobyte
                                          @lolobyte Yes. He’s been inside my machine a couple times… I don’t mind. He’s a great guy!
                                          Besides it’s clean and you can watch what he’s doing and then you’ll see what’s wrong.
                                            Beh
                                            Hey!
                                            Has anyone commented on getting back to the original config file? I haven’t seen any comments for this in this thread, but maybe I scrolled too fast ^^’
                                            Some days ago I wanted to replace the MMM-Mobile config with my original config and all I got was a white screen on the mirror. Is this a known issue?
                                            I want to use my old config until the app is really finished and the thesis is done…
                                            • 4 / 6
