    Mobile app (bachelor thesis)
    116 Posts 31 Posters 205.4k Views 31 Watching
    • lolobyteL
      lolobyte
      i don’t know why but i had again problems scanning the qr code on the Mirror.
      After the qr code automated was hidden and all modules started i went to my laptop starting a vnc session and opening the qr code with mirage and the scan was simle and fast done, the app has synchronized an it works now.
      Maybe the qr picture is to dark or to small, i don’t know what’s the mater with qr scanning on my iPhone 6s.
      • strawberry 3.141S
        strawberry 3.141 Project Sponsor Module Developer @lolobyte
        @lolobyte next time you could try to use the config option qrSize
        lolobyteL 1 Reply Last reply
        • lolobyteL
          lolobyte @strawberry 3.141
          @strawberry-3.141
          ok, i’ll try that
            bminer1 @strawberry 3.141
            @strawberry-3.141
            Im googling how to remove the module directory but its not really clear. Is it as simple as deleting the module folder or is there more to it?
            tosti007T 1 Reply Last reply
            • tosti007T
              tosti007 Module Developer @bminer1
              @bminer1 yea just deleting the folder removes a module
              If there is anything don’t hesitate to contact me!
              ProfileSwitcher, TouchNotifications
                bminer1
                Hi Strawberry 3.141, I am still having an issue with using the mobile app.
                Below is the steps i took based on the install guide from the git and deleting the folder.
                Here is the install:
                pi@raspberrypi:~/MagicMirror/modules $ git clone https://github.com/fewieden/MMM-Mobile.git
                Cloning into ‘MMM-Mobile’…
                remote: Counting objects: 84, done.
                remote: Compressing objects: 100% (21/21), done.
                remote: Total 84 (delta 12), reused 0 (delta 0), pack-reused 63
                Unpacking objects: 100% (84/84), done.
                Checking connectivity… done.
                Then the Dependencies
                pi@raspberrypi:~/MagicMirror/modules/MMM-Mobile $ npm install
                mmm-mobile@1.0.0 preinstall /home/pi/MagicMirror/modules/MMM-Mobile
                node scripts/preinstall.js
                Creating Backup for config.js!
                Saving updated config.js!
                mmm-mobile@1.0.0 /home/pi/MagicMirror/modules/MMM-Mobile
                ├─┬ async@2.1.4
                │ └── lodash@4.17.4
                ├── moment@2.17.1
                ├── qr-image@3.2.0
                └── simple-git@1.65.0
                add to config.js file
                “modules”: [
                “module”: “alert”
                module: “MMM-Mobile”
                the QRcode popped up but still would not connect
                in the app, i put in my IP address and it said Connected for a milisecond then showed could not connect again
                • strawberry 3.141S
                  problem solved after adding ip to config.js
                  • strawberry 3.141S
                    I sent an email again with the 3rd prototype. Make sure to check your spam folders.
                    I also would like to ask to take part in the survey which I sent by mail to evaluate the app.
                    As it turned out the last fix didn’t solve the issue with loosing pairing on a
                    restart. This is hopefully resolved now.
                    In the settings there is an advanced and simple mode (simple mode is
                    currently available for the default calendar only).
                    Also there is a new entry in the menu to do some tasks (restart mirror,
                    show/hide modules).
                    Don't forget to update the MMM-Mobile
                    Problems should be created as issues on github.
                    • lolobyteL
                      @strawberry-3.141
                      Thank you for the new admin functions.
                      It’s possible for the app to realize if there is an available update for one or more of the installed modules and make this visible with a badge number?
                      Similar function like the default “updatenotification” module from @michmich
                      • strawberry 3.141S
                        @lolobyte
                        Spoiler: I want to integrate push notifications which will do exactly this. But that will be after my thesis.
                        • lolobyteL
                          @strawberry-3.141
                          • lolobyteL
                            lolobyte
                            @strawberry-3-141
                            Hey Man. Hope you are well.
                            So, i updated the module with git pull
                            and npm install.
                            well done the system.
                            Then removed the app an installed again.
                            Now here my observations and questions.
                            In the Menu Module Verfügbar is nothing listed. I tried with pull down but no modules listed like before.
                            Only this comment
                            Kein Modul erfüllt diese Kriterien.
                            Installiert -> pull down -> all my installled modules are listed. OK
                            Regionen works well also the Synchronisieren and QR Code recognizing with phone.
                            All Befehle are working well.
                            My question.
                            What exactly is the difference between simple an advanced mode.
                            I don’t understand what you are meaning with the default calendar only.
                            What is the difference?
                            Good luck with your thesis and an lucky punch with it.
                            • strawberry 3.141S
                              @lolobyte simple mode is only available for the configuration of the default calendar module. then you cannot specify custom stuff, only properties which are defined for this module. this will come for all default modules and modules which will be supported from their developers
                              • strawberry 3.141S
                                strawberry 3.141 Project Sponsor Module Developer @strawberry 3.141
                                @strawberry-3.141 as a reminder the survey, I sent by mail, for the evaluation of the app will be closed tomorrow, would be great to get more feedback
                                lolobyteL R yawnsY 3 Replies Last reply
                                • lolobyteL
                                  @strawberry-3.141
                                  Hy @strawberry-3-141
                                  how i said.
                                  In the menu “Module” “Verfügar” were in the past a lot of available modules after a pull down. Now there is nothing. He give a error message “Fehlgeschlagen: Module können nicht aktualisiert werden!”
                                  At “Installiert” all my installed on configured modules in the config.js are available. Wen i chose then a Module to see the details an wish to go back then the “verfügbar” entry is chosen by the app. In my opinion it may be better to chose “Installiert”
                                  What happens after the evaluation step?
                                    roramirez Core Contributors @strawberry 3.141
                                    @strawberry-3.141 I try the pair the app when MagicMirror and can’t
                                    The log of cli on MagicMirror say
                                    Missing error handler on `socket`.
                                    TypeError: Data must be a string or a buffer
                                        at TypeError (native)
                                        at Hash.update (crypto.js:74:16)
                                        at Array.io.of.use (/home/piMagicMirror/modules/MMM-Mobile/node_helper.js:166:52)
                                        at run (/home/piMagicMirror/node_modules/socket.io/lib/namespace.js:116:11)
                                        at Namespace.run (/home/piMagicMirror/node_modules/socket.io/lib/namespace.js:128:3)
                                        at Namespace.add (/home/piMagicMirror/node_modules/socket.io/lib/namespace.js:157:8)
                                        at Client.connect (/home/piMagicMirror/node_modules/socket.io/lib/client.js:76:20)
                                        at Client.ondecoded (/home/piMagicMirror/node_modules/socket.io/lib/client.js:190:10)
                                        at Decoder.Emitter.emit (/home/piMagicMirror/node_modules/socket.io/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20)
                                        at Decoder.add (/home/piMagicMirror/node_modules/socket.io/node_modules/socket.io-parser/index.js:246:12)
                                      PeppaPigKilla
                                      Has this happened ?
                                      • strawberry 3.141S
                                        @lolobyte the app takes the modules from http://beta.magicmirror.builders/modules maybe the service wasnt available at the time you tried. The thing with the tabs is on my list, there are also some other problems with the history stack.
                                        evaluation
                                        .then(finishThesis)
                                        .then(defineConfigStandardWithSimilarModules)
                                        .then(postTheResultsOfTheUserSurvey)
                                        .then(improveTheApp)
                                        .then(bringTheAppsIntoAppStoresOneDay);
                                        @roramirez does the mirror show the qrcode or does it happen before?
                                        @PeppaPigKilla what happened?
                                        R 1 Reply Last reply
                                          PeppaPigKilla
                                          The app been released ?
                                          Searched the store, but couldnt find anything.
                                          • strawberry 3.141S
                                            strawberry 3.141 Project Sponsor Module Developer @PeppaPigKilla
                                            @PeppaPigKilla no, there was just a beta testing of the prototypes for Android and iOS yet.
                                            P 1 Reply Last reply
                                            • 4 / 6
