    Mobile app (bachelor thesis)
    116 Posts 31 Posters 203.2k Views 31 Watching
    • L
      lolobyte
      @strawberry-3-141
      it’s safe now to update module and app?
      • strawberry 3.141S
        @bminer1 you shouldn’t edit the files, remove the module directory completely, clone again, put your config in config.js if you dont succeed send me a private message and i will help you
        @lolobyte, still you should uninstall the app first before upgrading to the newest prototype, but the magic mirror module should be fine with just updating
        • L
          lolobyte
          i don’t know why but i had again problems scanning the qr code on the Mirror.
          After the qr code automated was hidden and all modules started i went to my laptop starting a vnc session and opening the qr code with mirage and the scan was simle and fast done, the app has synchronized an it works now.
          Maybe the qr picture is to dark or to small, i don’t know what’s the mater with qr scanning on my iPhone 6s.
          • strawberry 3.141S
            strawberry 3.141 Project Sponsor Module Developer @lolobyte
            @lolobyte next time you could try to use the config option qrSize
            • L
              lolobyte @strawberry 3.141
              @strawberry-3.141
              ok, i’ll try that
                bminer1 @strawberry 3.141
                @strawberry-3.141
                Im googling how to remove the module directory but its not really clear. Is it as simple as deleting the module folder or is there more to it?
                • T
                  tosti007 Module Developer @bminer1
                  @bminer1 yea just deleting the folder removes a module
                  If there is anything don’t hesitate to contact me!
                  ProfileSwitcher, TouchNotifications
                    bminer1
                    Hi Strawberry 3.141, I am still having an issue with using the mobile app.
                    Below is the steps i took based on the install guide from the git and deleting the folder.
                    Here is the install:
                    pi@raspberrypi:~/MagicMirror/modules $ git clone https://github.com/fewieden/MMM-Mobile.git
                    Cloning into ‘MMM-Mobile’…
                    remote: Counting objects: 84, done.
                    remote: Compressing objects: 100% (21/21), done.
                    remote: Total 84 (delta 12), reused 0 (delta 0), pack-reused 63
                    Unpacking objects: 100% (84/84), done.
                    Checking connectivity… done.
                    Then the Dependencies
                    pi@raspberrypi:~/MagicMirror/modules/MMM-Mobile $ npm install
                    mmm-mobile@1.0.0 preinstall /home/pi/MagicMirror/modules/MMM-Mobile
                    node scripts/preinstall.js
                    Creating Backup for config.js!
                    Saving updated config.js!
                    mmm-mobile@1.0.0 /home/pi/MagicMirror/modules/MMM-Mobile
                    ├─┬ async@2.1.4
                    │ └── lodash@4.17.4
                    ├── moment@2.17.1
                    ├── qr-image@3.2.0
                    └── simple-git@1.65.0
                    add to config.js file
                    “modules”: [
                    “module”: “alert”
                    module: “MMM-Mobile”
                    the QRcode popped up but still would not connect
                    in the app, i put in my IP address and it said Connected for a milisecond then showed could not connect again
                    • strawberry 3.141S
                      problem solved after adding ip to config.js
                      • strawberry 3.141S
                        I sent an email again with the 3rd prototype. Make sure to check your spam folders.
                        I also would like to ask to take part in the survey which I sent by mail to evaluate the app.
                        As it turned out the last fix didn’t solve the issue with loosing pairing on a
                        restart. This is hopefully resolved now.
                        In the settings there is an advanced and simple mode (simple mode is
                        currently available for the default calendar only).
                        Also there is a new entry in the menu to do some tasks (restart mirror,
                        show/hide modules).
                        Don't forget to update the MMM-Mobile
                        Problems should be created as issues on github.
                        • L
                          @strawberry-3.141
                          Thank you for the new admin functions.
                          It’s possible for the app to realize if there is an available update for one or more of the installed modules and make this visible with a badge number?
                          Similar function like the default “updatenotification” module from @michmich
                          • strawberry 3.141S
                            @lolobyte
                            Spoiler: I want to integrate push notifications which will do exactly this. But that will be after my thesis.
                            • L
                              @strawberry-3.141
                              • L
                                lolobyte
                                @strawberry-3-141
                                Hey Man. Hope you are well.
                                So, i updated the module with git pull
                                and npm install.
                                well done the system.
                                Then removed the app an installed again.
                                Now here my observations and questions.
                                In the Menu Module Verfügbar is nothing listed. I tried with pull down but no modules listed like before.
                                Only this comment
                                Kein Modul erfüllt diese Kriterien.
                                Installiert -> pull down -> all my installled modules are listed. OK
                                Regionen works well also the Synchronisieren and QR Code recognizing with phone.
                                All Befehle are working well.
                                My question.
                                What exactly is the difference between simple an advanced mode.
                                I don’t understand what you are meaning with the default calendar only.
                                What is the difference?
                                Good luck with your thesis and an lucky punch with it.
                                • strawberry 3.141S
                                  @lolobyte simple mode is only available for the configuration of the default calendar module. then you cannot specify custom stuff, only properties which are defined for this module. this will come for all default modules and modules which will be supported from their developers
                                  • strawberry 3.141S
                                    strawberry 3.141 Project Sponsor Module Developer @strawberry 3.141
                                    @strawberry-3.141 as a reminder the survey, I sent by mail, for the evaluation of the app will be closed tomorrow, would be great to get more feedback
                                    L R Y 3 Replies Last reply Reply Quote 0
                                    • L
                                      @strawberry-3.141
                                      Hy @strawberry-3-141
                                      how i said.
                                      In the menu “Module” “Verfügar” were in the past a lot of available modules after a pull down. Now there is nothing. He give a error message “Fehlgeschlagen: Module können nicht aktualisiert werden!”
                                      At “Installiert” all my installed on configured modules in the config.js are available. Wen i chose then a Module to see the details an wish to go back then the “verfügbar” entry is chosen by the app. In my opinion it may be better to chose “Installiert”
                                      What happens after the evaluation step?
                                        roramirez Core Contributors @strawberry 3.141
                                        @strawberry-3.141 I try the pair the app when MagicMirror and can’t
                                        The log of cli on MagicMirror say
                                        Missing error handler on `socket`.
                                        TypeError: Data must be a string or a buffer
                                            at TypeError (native)
                                            at Hash.update (crypto.js:74:16)
                                            at Array.io.of.use (/home/piMagicMirror/modules/MMM-Mobile/node_helper.js:166:52)
                                            at run (/home/piMagicMirror/node_modules/socket.io/lib/namespace.js:116:11)
                                            at Namespace.run (/home/piMagicMirror/node_modules/socket.io/lib/namespace.js:128:3)
                                            at Namespace.add (/home/piMagicMirror/node_modules/socket.io/lib/namespace.js:157:8)
                                            at Client.connect (/home/piMagicMirror/node_modules/socket.io/lib/client.js:76:20)
                                            at Client.ondecoded (/home/piMagicMirror/node_modules/socket.io/lib/client.js:190:10)
                                            at Decoder.Emitter.emit (/home/piMagicMirror/node_modules/socket.io/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20)
                                            at Decoder.add (/home/piMagicMirror/node_modules/socket.io/node_modules/socket.io-parser/index.js:246:12)
                                          PeppaPigKilla
                                          Has this happened ?
                                          • strawberry 3.141S
                                            @lolobyte the app takes the modules from http://beta.magicmirror.builders/modules maybe the service wasnt available at the time you tried. The thing with the tabs is on my list, there are also some other problems with the history stack.
                                            evaluation
                                            .then(finishThesis)
                                            .then(defineConfigStandardWithSimilarModules)
                                            .then(postTheResultsOfTheUserSurvey)
                                            .then(improveTheApp)
                                            .then(bringTheAppsIntoAppStoresOneDay);
                                            @roramirez does the mirror show the qrcode or does it happen before?
                                            @PeppaPigKilla what happened?
                                            • 4 / 6
