    My custom mirror
    16 Posts 5 Posters 10.3k Views 8 Watching
      MMRIZE @greedyvegan
      @greedyvegan
      It will look better to arrange newsfeed module more harmonized.
      /* css/custom.css */
      /* This is just and example. Adjust to your color and dimensions */
      .MMM-anotherNewsFeed .newsfeed-image {
        min-width: 150px;
        min-height: 150px;
        max-width: 150px;
        max-height: 150px;
        margin: 10px 20px 10px 10px;
        border-radius: 15px;
        background-repeat: no-repeat;
        background-position: center center;
        background-size: cover;
      .region .module.MMM-anotherNewsFeed {
        width: 600px;
        height: 300px;
        margin-top: 0;
        background-color: #333;
      G 2 Replies Last reply Reply Quote 1
      • G Offline
        greedyvegan @MMRIZE
        @MMRIZE nice, I like that; thank you
        • G Offline
          greedyvegan @BerkSmash1984
          @BerkSmash1984 https://github.com/ngnijland/MMM-text-clock
          BerkSmash1984B 1 Reply Last reply Reply Quote 0
          • G Offline
            greedyvegan @MMRIZE
            @MMRIZE
            how do I get the news article image to have a permanent position, whether it appears/loads or not?? just like in your image.
            is that float or margin?
            |(image) (text text text text) |
              MMRIZE @greedyvegan
              @greedyvegan
              newsfeed item could have a container with selector withImage or not.
                      <div class="container {% if config.showImage and image %} withImage {% endif %}">
                              <div class="newsfeed-image" style="background-image: url({{image}})"></div>
                          {% endif %}
              So you can specify your style for each case, withImage or not.
              .MMM-anotherNewsFeed .module-content .container {
                text-align: right;
              .MMM-anotherNewsFeed .module-content .container.withImage {
                text-align: left;
              Image and contents are arranged by container’s display:flex so you can reorder or justify with flex-related attributes.
              G 1 Reply Last reply Reply Quote 1
              • BerkSmash1984B Offline
                BerkSmash1984 @greedyvegan
                @greedyvegan Thanks!
                • G Offline
                  greedyvegan @MMRIZE
                  @MMRIZE
                  thank you very much, what’s the hierarchy levels as far as region, container, module in css?
                    sdetweil @greedyvegan
                    @greedyvegan use the developers window elements view to see it
                    • G Offline
                      greedyvegan @sdetweil
                      @sdetweil I understood you here but I’m asking about priority overall, the developer window doesn’t display that.
                        @greedyvegan absolutely does.
                        unless overridden, they are element ordered, outer to inner. some styles can be inherited from parent, never from grandparent
                        the text above the console box shows the stack for the selected element.
                        the right window shows the exact inheritance and override, and sources for styles
                        the most specific style setting wins unless overridden ( !important)
                        • G Offline
                          @sdetweil ok, thanks. I need to look up web developers for dummies now.
                          • bugsounetB bugsounet referenced this topic on
                            ric
                            I like the colours of the agenda and weather module. Can you tell me how you changed the colours? Thank you
                            • G Offline
                              greedyvegan @ric
                              @ric
                              sorry for the delay , I’ve updated the post with the custom css
                                ric @greedyvegan
                                @greedyvegan
                                thank you
