    August-Lock Module Stuck on Loading
    9 Posts 3 Posters 856 Views 4 Watching
      jcgrim13
      I am trying to get the MMM-August-Lock Module to connect and display the status of the multiple August Locks we have around the house. However, after getting everything installed correctly and authorizing via my email/password and the code that is sent the module is stuck on “Loading” when displayed on my mirror. Any ideas on what might cause this? I see that the module is 3 years old so I am guessing it’s possible August has changed some things that haven’t been updated in the module? Anyone have any experience with this one?
      Thanks!
      • KristjanESPERANTOK Offline
        KristjanESPERANTO Module Developer @jcgrim13
        Do you see anything unusual in the logs of node or the browser?
        I link the developer here, maybe he’ll get a notification: @relm923
        • bugsounetB bugsounet referenced this topic on
          jcgrim13
          I am still new at this so didn’t think about the logs. Looks like there is for sure an error, but not sure how to determine what is causing it. Here is the error in the logs…any thoughts
          0|mm  | [2024-04-03 16:42:14.130] [ERROR] Error occurred while fetching stats Error: GET failed with: 401
          0|mm  |     at IncomingMessage.<anonymous> (/home/admin/MagicMirror/modules/MMM-August-Lock/node_modules/tiny-json-http/bundle.js:1:2186)
          0|mm  |     at IncomingMessage.emit (node:events:526:35)
          0|mm  |     at endReadableNT (node:internal/streams/readable:1408:12)
          0|mm  |     at process.processTicksAndRejections (node:internal/process/task_queues:82:21) {
          0|mm  |   raw: <ref *1> IncomingMessage {
          0|mm  |     _readableState: ReadableState {
          0|mm  |       state: 456758,
          0|mm  |       highWaterMark: 16384,
          0|mm  |       buffer: BufferList { head: null, tail: null, length: 0 },
          0|mm  |       length: 0,
          0|mm  |       pipes: [],
          0|mm  |       flowing: true,
          0|mm  |       errored: null,
          0|mm  |       defaultEncoding: 'utf8',
          0|mm  |       awaitDrainWriters: null,
          0|mm  |       decoder: null,
          0|mm  |       encoding: null,
          0|mm  |       [Symbol(kPaused)]: false
          0|mm  |     },
          0|mm  |     _events: [Object: null prototype] {
          0|mm  |       end: [Array],
          0|mm  |       data: [Function (anonymous)]
          0|mm  |     },
          0|mm  |     _eventsCount: 2,
          0|mm  |     _maxListeners: undefined,
          0|mm  |     socket: null,
          0|mm  |     httpVersionMajor: 1,
          0|mm  |     httpVersionMinor: 1,
          0|mm  |     httpVersion: '1.1',
          0|mm  |     complete: true,
          0|mm  |     rawHeaders: [
          0|mm  |       'Date',
          0|mm  |       'Wed, 03 Apr 2024 20:42:14 GMT',
          0|mm  |       'Content-Type',
          0|mm  |       'application/json',
          0|mm  |       'Content-Length',
          0|mm  |       '65',
          0|mm  |       'Connection',
          0|mm  |       'keep-alive',
          0|mm  |       'vary',
          0|mm  |       'origin,access-control-request-method,access-control-request-headers',
          0|mm  |       'content-security-policy',
          0|mm  |       "default-src 'self';base-uri 'self';block-all-mixed-content;font-src 'self' https: data:;frame-ancestors 'self';img-src 'self' data:;object-src 'none';script-src 'self';script-src-attr 'none';style-src 'self' https: 'unsafe-inline';upgrade-insecure-requests",
          0|mm  |       'x-dns-prefetch-control',
          0|mm  |       'off',
          0|mm  |       'expect-ct',
          0|mm  |       'max-age=0',
          0|mm  |       'x-frame-options',
          0|mm  |       'SAMEORIGIN',
          0|mm  |       'strict-transport-security',
          0|mm  |       'max-age=15552000; includeSubDomains',
          0|mm  |       'x-download-options',
          0|mm  |       'noopen',
          0|mm  |       'x-content-type-options',
          0|mm  |       'nosniff',
          0|mm  |       'x-permitted-cross-domain-policies',
          0|mm  |       'none',
          0|mm  |       'referrer-policy',
          0|mm  |       'no-referrer',
          0|mm  |       'x-xss-protection',
          0|mm  |       '0',
          0|mm  |       'api-version',
          0|mm  |       '0.0.1',
          0|mm  |       'x-response-time',
          0|mm  |       '2',
          0|mm  |       'CF-Cache-Status',
          0|mm  |       'DYNAMIC',
          0|mm  |       'Set-Cookie',
          0|mm  |       '__cf_bm=OoUIdyZ8fziOlR0ZXufTExomKxLJrvgfgDil42qlrOk-1712176934-1.0.1.1-6atgYmMjhGdKpAbUxyDKj36_Cswj3DQLV0Me_FTeh0Rywy2UqoMUs35FUtYJoVv06MUOyGfjuch82PQpSg_DGw; path=/; expires=Wed, 03-Apr-24 21:12:14 GMT; domain=.august.com; HttpOnly; Secure; SameSite=None',
          0|mm  |       'Server',
          0|mm  |       'cloudflare',
          0|mm  |       'CF-RAY',
          0|mm  |       '86ebe24d3c4eb3c7-MIA'
          0|mm  |     ],
          0|mm  |     rawTrailers: [],
          0|mm  |     joinDuplicateHeaders: undefined,
          0|mm  |     aborted: false,
          0|mm  |     upgrade: false,
          0|mm  |     url: '',
          0|mm  |     method: null,
          0|mm  |     statusCode: 401,
          0|mm  |     statusMessage: 'Unauthorized',
          0|mm  |     client: TLSSocket {
          0|mm  |       _tlsOptions: [Object],
          0|mm  |       _secureEstablished: true,
          0|mm  |       _securePending: false,
          0|mm  |       _newSessionPending: false,
          0|mm  |       _controlReleased: true,
          0|mm  |       secureConnecting: false,
          0|mm  |       _SNICallback: null,
          0|mm  |       servername: 'api-production.august.com',
          0|mm  |       alpnProtocol: false,
          0|mm  |       authorized: true,
          0|mm  |       authorizationError: null,
          0|mm  |       encrypted: true,
          0|mm  |       _events: [Object: null prototype],
          0|mm  |       _eventsCount: 9,
          0|mm  |       connecting: false,
          0|mm  |       _hadError: false,
          0|mm  |       _parent: null,
          0|mm  |       _host: 'api-production.august.com',
          0|mm  |       _closeAfterHandlingError: false,
          0|mm  |       _readableState: [ReadableState],
          0|mm  |       _writableState: [WritableState],
          0|mm  |       allowHalfOpen: false,
          0|mm  |       _sockname: null,
          0|mm  |       _pendingData: null,
          0|mm  |       _pendingEncoding: '',
          0|mm  |       server: undefined,
          0|mm  |       _server: null,
          0|mm  |       ssl: [TLSWrap],
          0|mm  |       _requestCert: true,
          0|mm  |       _rejectUnauthorized: true,
          0|mm  |       timeout: 5000,
          0|mm  |       parser: null,
          0|mm  |       _httpMessage: null,
          0|mm  |       autoSelectFamilyAttemptedAddresses: [Array],
          0|mm  |       [Symbol(alpncallback)]: null,
          0|mm  |       [Symbol(res)]: [TLSWrap],
          0|mm  |       [Symbol(verified)]: true,
          0|mm  |       [Symbol(pendingSession)]: null,
          0|mm  |       [Symbol(async_id_symbol)]: -1,
          0|mm  |       [Symbol(kHandle)]: [TLSWrap],
          0|mm  |       [Symbol(lastWriteQueueSize)]: 0,
          0|mm  |       [Symbol(timeout)]: Timeout {
          0|mm  |         _idleTimeout: 5000,
          0|mm  |         _idlePrev: [TimersList],
          0|mm  |         _idleNext: [Timeout],
          0|mm  |         _idleStart: 498879,
          0|mm  |         _onTimeout: [Function: bound ],
          0|mm  |         _timerArgs: undefined,
          0|mm  |         _repeat: null,
          0|mm  |         _destroyed: false,
          0|mm  |         [Symbol(refed)]: false,
          0|mm  |         [Symbol(kHasPrimitive)]: false,
          0|mm  |         [Symbol(asyncId)]: 17455,
          0|mm  |         [Symbol(triggerId)]: 17453
          0|mm  |       },
          0|mm  |       [Symbol(kBuffer)]: null,
          0|mm  |       [Symbol(kBufferCb)]: null,
          0|mm  |       [Symbol(kBufferGen)]: null,
          0|mm  |       [Symbol(kCapture)]: false,
          0|mm  |       [Symbol(kSetNoDelay)]: false,
          0|mm  |       [Symbol(kSetKeepAlive)]: true,
          0|mm  |       [Symbol(kSetKeepAliveInitialDelay)]: 1,
          0|mm  |       [Symbol(kBytesRead)]: 0,
          0|mm  |       [Symbol(kBytesWritten)]: 0,
          0|mm  |       [Symbol(connect-options)]: [Object]
          0|mm  |     },
          S KristjanESPERANTOK 2 Replies Last reply Reply Quote 0
            sdetweil @jcgrim13
            @jcgrim13 GET failed with: 401
            unauthorized
              @jcgrim13 Check that your password and augustID are correct.
                jcgrim13
                @KristjanESPERANTO, I had that same thought so I triple checked those, even used the same ones to log in to get the authorization code thats required when you first install the module. I am wondering if August changed something with their API…
                KristjanESPERANTOK S 2 Replies Last reply Reply Quote 0
                  @jcgrim13 I recommend to open an issue in the module’s repository. Maybe the author will notice that.
                    sdetweil @jcgrim13
                    @jcgrim13 sid you rerun the auth script?
                      jcgrim13
                      @sdetweil, I did and everything authorized successfully. I will open an issue with the developer as suggested above. I appreciate the responses and help!
