    August-Lock Module Stuck on Loading
    9 Posts 3 Posters 902 Views 4 Watching
      sdetweil @jcgrim13
      @jcgrim13 GET failed with: 401
      unauthorized
      • KristjanESPERANTOK Offline
        KristjanESPERANTO Module Developer @jcgrim13
        @jcgrim13 Check that your password and augustID are correct.
          jcgrim13
          @KristjanESPERANTO, I had that same thought so I triple checked those, even used the same ones to log in to get the authorization code thats required when you first install the module. I am wondering if August changed something with their API…
          KristjanESPERANTOK S 2 Replies Last reply Reply Quote 0
            @jcgrim13 I recommend to open an issue in the module’s repository. Maybe the author will notice that.
              sdetweil @jcgrim13
              @jcgrim13 sid you rerun the auth script?
                jcgrim13
                @sdetweil, I did and everything authorized successfully. I will open an issue with the developer as suggested above. I appreciate the responses and help!
