    Everything was going so well
    52 Posts 4 Posters 26.9k Views 3 Watching
      JMac @mumblebaj
      @mumblebaj that’s worked.
      I’m now presented with
      /dev/mmcblk0p1
      /dev/mmcblk0p2
      so follow @sdetweil step above and go with the second option?
      mumblebajM 1 Reply Last reply
      • mumblebajM
        mumblebaj Module Developer @JMac
        @JMac Yeah, would suggest you follow his recommendations.
        J 1 Reply Last reply
          JMac @mumblebaj
          @mumblebaj cool. Do you have any idea why the initial SD card would be failing to launch when the pi is turned on?
          as mentioned above it’s a good quality SD card so am I daft to consider (providing I can recover a copy of my old setup) copying it back onto to the original SD card, am I asking for trouble in the future?
            JMac @sdetweil
            @sdetweil so I ran e2fsck -f -v /dev/mmcblk0p2
            got a warning about SEVERE filesystem damage.
            went yes and got ]e2fsck : permission denied while trying to open /dev/mmcblk0p2
            you must have r/w access to the filesystem or be root.
            How do I get around this?
            • mumblebajM
              @JMac I am sure Sam is probably still sleeping, but you can try sudo e2fsck -f -v /dev/mmcblk0p2. This should run as root user.
                JMac @mumblebaj
                @mumblebaj when I run that in terminal I get,
                e2fsck 1.46.2 (28-Feb-2021)
                /dev/mmcblk0p2 is mounted.
                e2fsck: cannot continue, aborting.
                Any thoughts, is that image/setup a goner?
                mumblebajM S 2 Replies Last reply
                • mumblebajM
                  @JMac You could try systemctl stop udev and then try running it again. My knowledge of these linux things are not that great. Or service udev stop might work. I am leaning towards the card being a goner thought.
                    JMac @mumblebaj
                    @mumblebaj It would be way easier if I could recover the previous setup but I’m starting to feel like it might be worth starting the entire MM install again, but for me that’s the least interesting parts of Pi builds.
                    The files are still available on the old SD card so the card itself isn’t completely kaput.
                    edit to add I ran the systemctl stop udev command.
                    put in the password of the MM to allow this.
                    re ran sudo e2fsck -f -v /dev/mmcblk0p2
                    and get the same e2fcsk: cannot continue, aborting error.
                    • mumblebajM
                      @JMac You can use the scripts from Sam to install MM. You can find them here. Always do a backup of your install with one of Sam’s script as this would save tears in the end. I have been there before and the backup and restore process saved me a few times.
                      Scripts can be located here:
                        sdetweil @JMac
                        @JMac you cant whack on a file system if its mounted for access,do
                        df -k
                        will show u the devices and where they are mounted then sudo umount /dev/… what you were using
                        df -k should show it gone
                        then the fsck… commands should work w sudo
                          sdetweil @JMac
                          @JMac if u can get the config, custom
                          css and and listing of the modules ( ls command) we can build the backup/restore files
                            JMac @sdetweil
                            @sdetweil sorry to be dense how do I know what I’m unmounting?
                            am I unmounting /dev/mmcblk0p1?? it says thats mounted on /boot.
                            edit to add,
                            after re running sudo fdisk -l it would appear the old memory card (with my previous MM setup on) is on Disk /dev/sda
                            thats classed as Disk Model: storage device (as it’s mounted in the usb drive atm) does this seem correct? is this the one which needs unmounting?
                              sdetweil @JMac
                              @JMac well mounted means accessible by the filesystem
                              so it’s /dev/sda
                              the usb installed sd card
                              so
                              sudo unmount /dev/sda
                              and then run fsck on that
                                JMac
                                so I run the command sudo umount /dev/sda
                                and get
                                umount: /dev/sda: not mounted.
                                so should now go,
                                e2fsck -f -v /dev/sda
                                not the original
                                e2fsck -f -v mmcblk0p2
                                  sdetweil @JMac
                                  @JMac correct… you had to find the disk name
                                    JMac @sdetweil
                                    @sdetweil when i run e2fsck…
                                    I get
                                    e2fsck: permission denied while trying to open /dev/sda
                                      sdetweil @JMac
                                      @JMac yes, you must use sudo on both commands unmount and fsck
                                      sorry I was unclear
                                      normal users should not be able to mess with hardware, so one must act as root
                                        JMac @sdetweil
                                        @sdetweil I run sudo umount…
                                        and get
                                        umount:… not mounted,
                                        then run
                                        sudo e2fsck -f -v /dev/sda
                                        and get
                                        e2fsck 1.46.2 (28-feb-2021)
                                        /dev/sda is in use
                                        efsck: connot continue, aborting.
                                          sdetweil @JMac
                                          @JMac hm… wonder what is using it?
                                          can you open the disks app on the pi from the dedktop menu
                                            JMac @sdetweil
                                            @sdetweil on the home screen I have 2 drive icons under the wastebasket.
                                            one is boot
                                            the other is rootfs
                                            i then have the option to eject these in the file manager
