    MagicMirror no longer launches
    38 Posts 4 Posters 12.0k Views 3 Watching
      RIKKO14 @sdetweil
      pi@raspberrypi:~ $ pm2 stop all
      npm install electron@29.1.6
       npm start
      [PM2] Applying action stopProcessId on app [all](ids: [ 0 ])
      [PM2] [MagicMirror](0) ✓
      │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
      │ 0  │ MagicMirror        │ fork     │ 8615 │ stopped   │ 0%       │ 0b       │
      npm ERR! code ENOTEMPTY
      npm ERR! syscall rename
      npm ERR! path /home/pi/MagicMirror/node_modules/caniuse-lite
      npm ERR! dest /home/pi/MagicMirror/node_modules/.caniuse-lite-6h1pL5No
      npm ERR! errno -39
      npm ERR! ENOTEMPTY: directory not empty, rename '/home/pi/MagicMirror/node_modules/caniuse-lite' -> '/home/pi/MagicMirror/node_modules/.caniuse-lite-6h1pL5No'
      npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-04-26T16_18_54_942Z-debug-0.log
      > magicmirror@2.27.0 start
      App threw an error during load
      Error: Cannot find module 'ansis'
      Require stack:
      - /home/pi/MagicMirror/js/logger.js
          at node:internal/modules/cjs/loader:1084:15
          at Function.<anonymous> (node:electron/js2c/browser_init:2:116646)
          at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
          at node:internal/modules/cjs/loader:929:27
          at Function._load (node:electron/js2c/asar_bundle:2:13327)
          at Module.require (node:internal/modules/cjs/loader:1150:19)
          at require (node:internal/modules/cjs/helpers:121:18)
          at /home/pi/MagicMirror/js/logger.js:5:19
          at Object.<anonymous> (/home/pi/MagicMirror/js/logger.js:46:2)
          at Module._compile (node:internal/modules/cjs/loader:1271:14)
          at Object..js (node:internal/modules/cjs/loader:1326:10)
          at Module.load (node:internal/modules/cjs/loader:1126:32)
          at node:internal/modules/cjs/loader:967:12
      A JavaScript error occurred in the main process
      Uncaught Exception:
      Require stack:
      Warning: vkCreateInstance: Found no drivers!
      Warning: vkCreateInstance failed with VK_ERROR_INCOMPATIBLE_DRIVER
          at CheckVkSuccessImpl (../../third_party/dawn/src/dawn/native/vulkan/VulkanError.cpp:88)
          at CreateVkInstance (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:458)
          at Initialize (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:344)
          at Create (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:266)
          at operator() (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:521)
      Warning: eglChooseConfig returned zero configs
          at Create (../../third_party/dawn/src/dawn/native/opengl/ContextEGL.cpp:52)
          at Create (../../third_party/dawn/src/dawn/native/opengl/PhysicalDeviceGL.cpp:97)
        sdetweil @RIKKO14
        @RIKKO14 said in MagicMirror no longer launches:
        ‘ansis’
        npm install ansis
        and try again
          RIKKO14 @sdetweil
          pi@raspberrypi:~ $ npm install ansis
          up to date, audited 2 packages in 1s
          found 0 vulnerabilities
           npm start
          npm ERR! errno -39
          npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-04-26T16_37_54_575Z-debug-0.log
          [2024-04-26 18:38:03.262] [ERROR] App threw an error during load
          [2024-04-26 18:38:03.265] [ERROR] Error: Cannot find module 'socket.io'
          Require stack:
          - /home/pi/MagicMirror/js/server.js
              at Object.<anonymous> (/home/pi/MagicMirror/js/server.js:8:18)
              at Object.<anonymous> (/home/pi/MagicMirror/js/app.js:9:16)
          Uncaught Exception:
          Require stack:
            sdetweil @RIKKO14
            @RIKKO14 sounds like the npm install for MagicMirror failed
            do
            npm run install-mm
              RIKKO14 @sdetweil
              pi@raspberrypi:~ $ npm run install-mm
              npm ERR! Missing script: "install-mm"
              npm ERR!
              npm ERR! Did you mean this?
              npm ERR!     npm install # Install a package
              npm ERR!
              npm ERR! To see a list of scripts, run:
              npm ERR!   npm run
              npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-04-26T16_46_42_166Z-debug-0.log
              pi@raspberrypi:~ $
                sdetweil @RIKKO14
                @RIKKO14 ok, even worse, the git pull failed.
                do
                git pull
                show the output
                bugsounetB 1 Reply Last reply Reply Quote 0
                • bugsounetB
                  bugsounet Banned @sdetweil
                  @sdetweil (inside MagicMirror Folder)
                  maybe: (in this case)
                  rm -rf node_modules
                  git reset --hard origin
                  git pull
                  npm run install-mm
                  no ?
                    sdetweil @bugsounet
                    @bugsounet I want to see what the problem is, not just wipe everything
                    • bugsounetB
                      @sdetweil : yes… but inside MM² Folder not outside ;)
                        sdetweil @bugsounet
                        @bugsounet yes, of course
                          sdetweil @RIKKO14
                          @RIKKO14 as @bugsounet noted, you have ti be in the MagicMirror folder for MagicMirror commands
                          I didn’t say that, as the last instructions left you in that folder
                            RIKKO14 @sdetweil
                            @sdetweil @bugsounet
                            npm ERR!
                            npm ERR!
                            npm ERR!   npm run
                            pi@raspberrypi:~ $ ^C
                            pi@raspberrypi:~ $ git pull
                            fatal: ni ceci ni aucun de ses répertoires parents n'est un dépôt git : .git
                            rm -rf node_modules
                            git pull
                            npm run install-mm
                            HEAD est maintenant à 5ea8a346 Release 2.27.0 (#3410)
                            astuce: Tirer sans spécifier comment réconcilier les branches divergentes
                            astuce: est découragé. Vous pouvez éliminer ce message en lançant une des
                            astuce: commandes suivantes avant votre prochain tirage :
                            astuce:
                            astuce:   git config pull.rebase false  # fusion (stratégie par défaut)
                            astuce:   git config pull.rebase true   # rebasage
                            astuce:   git config pull.ff only       # avance rapide seulement
                            astuce:
                            astuce: Vous pouvez remplacer "git config" par "git config --global" pour que
                            astuce: ce soit l'option par défaut pour tous les dépôts. Vous pouvez aussi
                            astuce: passer --rebase, --no-rebase ou --ff-only sur la ligne de commande pour
                            astuce: remplacer à l'invocation la valeur par défaut configurée.
                            Déjà à jour.
                            > magicmirror@2.27.0 install-mm
                            > npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
                            > magicmirror@2.27.0 postinstall
                            > npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
                            > magicmirror@2.27.0 install-vendor
                            > " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                            changed 1 package in 10s
                            > magicmirror@2.27.0 install-fonts
                            > echo "Installing fonts ...
                            > " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                            changed 2 packages in 4s
                            > magicmirror@2.27.0 prepare
                            > [ -f node_modules/.bin/husky ] && husky || echo no husky installed.
                            no husky installed.
                            added 483 packages in 2m
                            pi@raspberrypi:~/MagicMirror $
                            After a reboot of my Pi the icone on the top of my screen have change
                            and my MM launch but I have a problem of Library :
                            About GA of Bugsounet “Library loading error” remains displayed on my screen…
                            I tried to update GA without success :
                            I post the question on the Bugsounet forum
                            thank you very much both for your help !!
