    Weatherunderground - currently - hourly - daily - configurable
    126 Posts 26 Posters 245.9k Views 13 Watching
      pugsly
      So I came home today and noticed that the weather had not refreshed in two days. When I did a pm2 mm restart it did refresh but now im wondering maybe its not refreshing on its own? is there a config setting for how often it does a refresh?
        RedNax Module Developer @pugsly
        @pugsly That’s strange! There is a setting, but it has a default 10 minute setting.
        Did you look at the log for clues?
        updateInterval: 10 * 60 * 1000, // every 10 minutes
          djsunrise19
          How can I find the locid? I try a few options but everytime I get an error in my console:
          http://***:8080/modules/MMM-Wunderground//MMM-Wunderground.js
          Failed to load resource: the server responded with a status of 404 (Not Found)
          Also with: pws: ‘pws:IUTRECHT148’, OR pws: ‘NY/New_York’ OR pws: ‘locid:NLXX8014;loctype:1’
            Could you post the relevant config.js section? Could you also check on your pi if /modules/MMM-Wunderground/MMM-Wunderground.js actually exists?
              djsunrise19
              File exists! Config output (actually uncomment):
              	//	module: 'MMM-Wunderground',
              	//	position: 'top_right',  // This can be any of the regions.
              	//								// Best results in left or right regions.
              	//	config: {
              	//		// See 'Configuration options' for more information.
              	//		apikey: 'c4fbdf2a7b44d2bd', // private; don't share!
              	//		pws: 'NY/New_York',
              	//		//lang: 'DE',
              	//		fctext: '1',
              	//			fcdaycount: "5",
              	//			fcdaystart: "0",
              	//			hourly: '1',
              	//			hourlyinterval: "3",
              	//				hourlycount: "2",
              	//				alerttime: 10000,
              	//				alerttruncatestring: "english:" // truncate the alertstring ath this word//
                Any log available? At this point i have no clue why it would stall…
                  pugsly
                  Its been ok since I restarted so I am keeping an eye on it.
                  On another note, why do some configuration items use " ", some use ’ ’ and others don’t have any quotation marks at all?
                  I changed all of mine to ’ ’
                    djsunrise19
                    Thanks @pugsly, I checked that again, only with the following config:
                    			apikey: 'XXXXXX',
                    			pws: 'locid:NLXX8014;loctype:1'
                    Result is still a black screen. I can see that error on the console (on my computer):
                    Cannot GET /modules/MMM-Wunderground//MMM-Wunderground.js
                    But the file is in the folder. Weird!
                      djsunrise19
                      Perhaps I found something: The Filename is: MMM-WunderGround.js. Tha app is looking for MMM-Wunderground.js. If I change the filename to MMM-Wunderground.js, the mirror starts, but the Module don’t work.
                      I only see this:
                      0_1464276980611_upload-f8788a81-cd89-4a52-806e-da102ea6f282
                        djsunrise19
                        Any ideas?
                          djsunrise19
                          I cloned your repo to MMM-WunderGround and edited the module name also. Now it works. You should change your Readme.
                          Thanks for the cool module ;).
                          R 1 Reply Last reply Reply Quote 2
                            RedNax Module Developer @djsunrise19
                            @djsunrise19 Thanks for spotting my mistake :D I’ve modified the readme accordingly. Enjoy!
                              MagicCrumps1
                              it’s taking me forever but How do i change pws: ‘locid:’ for san francisco? I cant find the location ID for my city using google
                              • strawberry 3.141S
                                Can be any WU api location info.
                                US Example: NY/New_York
                                Example: locid:NLXX8014;loctype:1
                                so just change it to CA/San_Francisco
                                  MagicCrumps1
                                  I’m getting a blank screen. Any idea why?
                                  		module: 'MMM-WunderGround',
                                  		header: 'Weather Forecast',
                                  		    apikey: 'a1fa37eaff91b5450c',
                                  		    pws: 'CA/San_Francisco',
                                  		    fctext: '1',
                                  			  fcdaycount: '5',
                                  			  fcdaystart: '0',
                                  			  hourly: '1',
                                  			  hourlyinterval: '3',
                                  				hourlycount: '2',
                                  				alerttime: 1000,
                                  				alerttruncatestring: 'english:'
                                    Config looks good, could you have a look at your logs?
                                    See here for some troubleshootign info: https://forum.magicmirror.builders/topic/86/how-to-troubleshoot
                                      RedNax Module Developer @MagicCrumps1
                                      @MagicCrumps1 On the other hand, you api key seems to be invalid. (if the key in your post is indeed your key):
                                        "response": {
                                        "version":"0.1",
                                        "termsofService":"http://www.wunderground.com/weather/api/d/terms.html",
                                        "features": {
                                      	"error": {
                                      		"type": "keynotfound"
                                      		,"description": "this key does not exist"
                                        MagicCrumps1 @RedNax
                                          @RedNax Still not working. Sorry, I should have included that I added a few extra keys to my personal api key thus making them invalid.
                                          Loading config …
                                          Loading module helpers …
                                          No helper found for module: MMM-WunderGround.
                                          All module helpers loaded.
                                          Starting server op port 8080 …
                                          Server started …
                                          Starting module: newsfeed
                                          Sockets connected & modules started …
                                          Launching application.
                                          • K
                                            KirAsh4 Moderator
                                            That looks like everything did load up properly there. There’s a way to look at electron’s console logs but I don’t know what the keystroke is (maybe CTRL-W?). But, at times like this, I find it’s easier/faster for me to debug by using a different machine with Chrome/Firefox and load up the mirror that way by going to the rpi’s IP and port: http://10.0.0.1:8080 (assuming your rpi’s IP is 10.0.0.1, change it to match yours.) Black screen or not, you can always hit F12 on a windows browser and pull up the console log. Look for Javascript errors.
                                            • 3 / 7
