Electron failed to install properly
11 Posts 4 Posters 9.8k Views 3 Watching
    cianoo45
    Used the auto-installer to install MM2, When i type DISPLAY=:0 npm start i get this error. ```
    magicmirror@2.1.0 start /home/pi/MagicMirror
    > electron js/electron.js
    /home/pi/MagicMirror/node_modules/electron/index.js:9
    throw new Error('Electron failed to install correctly, please delete node_modu        les/' + path.basename(__dirname) + ' and try installing again')
    Error: Electron failed to install correctly, please delete node_modules/electron        and try installing again
      at Object. (/home/pi/MagicMirror/node_modules/electron/index.js:9        :9)
      at Module._compile (module.js:570:32)
      at Object.Module._extensions..js (module.js:579:10)
      at Module.load (module.js:487:32)
      at tryModuleLoad (module.js:446:12)
      at Function.Module._load (module.js:438:3)
      at Module.require (module.js:497:17)
      at require (internal/module.js:20:19)
      at Object. (/home/pi/MagicMirror/node_modules/electron/cli.js:3:1        6)
    npm ERR! Linux 4.4.43-v7+
    npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
    npm ERR! node v6.9.4
    npm ERR! npm  v3.10.10
    npm ERR! code ELIFECYCLE
    npm ERR! magicmirror@2.1.0 start: `electron js/electron.js`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the magicmirror@2.1.0 start script 'electron js/electron.js'.
    npm ERR! If you do, this is most likely a problem with the magicmirror package,
    npm ERR! not with npm itself.
    npm ERR!     electron js/electron.js
    npm ERR!     npm bugs magicmirror
    npm ERR! Or if that isn't available, you can get their info via:
    npm ERR!     npm owner ls magicmirror
    npm ERR!     /home/pi/MagicMirror/npm-debug.log
    Looked around for a fix but could not find one, Electron quick start gave the same error, any ideas?
      Are you starting your mirror over ssh?
      That would be the only reason to use DISPLAY=:0 npm start
        cianoo45
        Yeah I am
          MichMich
          Which version of Raspbian are you using?
            cianoo45
            The latest one, Jesse, only downloaded it a couple days ago
              MichMich
              Jessie or Jessie Lite?
                cianoo45
                Full version of Jessie, not Jessie light
                  cianoo45
                  When i type “node --version” it says i have V4.0.0 installed which is very outdated, could this be why?
                  C 1 Reply Last reply Jan 21, 2017, 2:23 PM Reply Quote 0
                    cianoo45 @cianoo45
                    @cianoo45 said in Electron failed to install properly:
                    Nevermind, updated to V7.4 and i still get the same error when running
                      dpenney
                      Getting the exact same thing here too - Raspberry Pi3 - any ideas?
                      16 error Linux 4.4.34-v7+
                      17 error argv “/usr/local/bin/node” “/usr/local/bin/npm” “start”
                      18 error node v6.9.4
                      19 error npm v3.10.10
                      20 error file sh
                      21 error code ELIFECYCLE
                      22 error errno ENOENT
                      23 error syscall spawn
                      24 error magicmirror@2.1.0 start: electron js/electron.js
                      24 error spawn ENOENT
                      25 error Failed at the magicmirror@2.1.0 start script ‘electron js/electron.js’.
                      I had tried using the latest node too - I downgraded to v6.9.4 just on the off chance it was a versioning thing but as you can see no go.
