    Electron failed to install properly
    11 Posts 4 Posters 11.1k Views 3 Watching
      cianoo45
      Used the auto-installer to install MM2, When i type DISPLAY=:0 npm start i get this error. ```
      magicmirror@2.1.0 start /home/pi/MagicMirror
      > electron js/electron.js
      /home/pi/MagicMirror/node_modules/electron/index.js:9
      throw new Error('Electron failed to install correctly, please delete node_modu        les/' + path.basename(__dirname) + ' and try installing again')
      Error: Electron failed to install correctly, please delete node_modules/electron        and try installing again
        at Object. (/home/pi/MagicMirror/node_modules/electron/index.js:9        :9)
        at Module._compile (module.js:570:32)
        at Object.Module._extensions..js (module.js:579:10)
        at Module.load (module.js:487:32)
        at tryModuleLoad (module.js:446:12)
        at Function.Module._load (module.js:438:3)
        at Module.require (module.js:497:17)
        at require (internal/module.js:20:19)
        at Object. (/home/pi/MagicMirror/node_modules/electron/cli.js:3:1        6)
      npm ERR! Linux 4.4.43-v7+
      npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
      npm ERR! node v6.9.4
      npm ERR! npm  v3.10.10
      npm ERR! code ELIFECYCLE
      npm ERR! magicmirror@2.1.0 start: `electron js/electron.js`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the magicmirror@2.1.0 start script 'electron js/electron.js'.
      npm ERR! If you do, this is most likely a problem with the magicmirror package,
      npm ERR! not with npm itself.
      npm ERR!     electron js/electron.js
      npm ERR!     npm bugs magicmirror
      npm ERR! Or if that isn't available, you can get their info via:
      npm ERR!     npm owner ls magicmirror
      npm ERR!     /home/pi/MagicMirror/npm-debug.log
      Looked around for a fix but could not find one, Electron quick start gave the same error, any ideas?
      • cowboysdudeC Offline
        Are you starting your mirror over ssh?
        That would be the only reason to use DISPLAY=:0 npm start
          cianoo45
          Yeah I am
          • MichMichM Offline
            MichMich
            Which version of Raspbian are you using?
              cianoo45
              The latest one, Jesse, only downloaded it a couple days ago
              • MichMichM Offline
                MichMich
                Jessie or Jessie Lite?
                  cianoo45
                  Full version of Jessie, not Jessie light
                    cianoo45
                    When i type “node --version” it says i have V4.0.0 installed which is very outdated, could this be why?
                      cianoo45 @cianoo45
                      @cianoo45 said in Electron failed to install properly:
                      Nevermind, updated to V7.4 and i still get the same error when running
                        dpenney
                        Getting the exact same thing here too - Raspberry Pi3 - any ideas?
                        16 error Linux 4.4.34-v7+
                        17 error argv “/usr/local/bin/node” “/usr/local/bin/npm” “start”
                        18 error node v6.9.4
                        19 error npm v3.10.10
                        20 error file sh
                        21 error code ELIFECYCLE
                        22 error errno ENOENT
                        23 error syscall spawn
                        24 error magicmirror@2.1.0 start: electron js/electron.js
                        24 error spawn ENOENT
                        25 error Failed at the magicmirror@2.1.0 start script ‘electron js/electron.js’.
                        I had tried using the latest node too - I downgraded to v6.9.4 just on the off chance it was a versioning thing but as you can see no go.
                          dpenney
                          AH HA! So turns out you need to install as root - the regular pi user doesn’t have enough permissions to install socket.io which is a dependency of electron…
                          The manual install instructions should be updated to state
                          sudo npm install
                          npm start
                          Damian
