    MMM-CalendarExt3
    689 Posts 82 Posters 3.2m Views 86 Watching
    • A
      almightyyoshi @MMRIZE
      @MMRIZE That worked…after I figured out I spelled instanceId incorrectly (I had instanceID). Thanks!
        moosespectacles
        Anyone know of a config that looks identical/similar to the skylight calendar layout? I’m trying to emulate that look and those features, as a starting point, but I’m having trouble with getting the calendar to even display one week or 3 days, only. At the moment I see a week, with another week right next to it, instead of underneath it, as well as week numbers being show. I haven’t been able to figure out how to get rid of the extra days, nor the week numbers.
        S M 2 Replies Last reply
          sdetweil @moosespectacles
          @moosespectacles well the skylight view is one week
          so
          mode:‘week’,
          weeksInView:1,
          then you have to use css to remove the weeknumber
            MMRIZE @moosespectacles
            @moosespectacles
            I think what you want is MMM-CalendarExtJournal, not this module.
            M 1 Reply Last reply
              moosespectacles @MMRIZE
              @MMRIZE said in MMM-CalendarExt3:
              @moosespectacles
              The thing is I want the full calendar functionality, similar to Google calendar/skylight, so I have the ability to change views. Is that possible with either module or another? My main goal is a fully functional Google/skylight calendar clone, in terms of looks and features and use that as my layout, and build the rest of my features/modules off of that, so if I decide I want to add a tab for a shopping list or to do list later on, I can, but at minimum I’d love to be able to have a calendar that syncs with all of my family’s devices to be a family calendar
                danncabrera
                Love this module, and have spent some time modifying some parts of it using CSS and learning a lot on the way. One thing i have not been able to achieve is to have the time format to show exactly how i want it to be.
                I want the time for any event to show like 9am / 9:15am instead of the “9:00 a.m.”, to save some space and try to make it more readable. Any ideas on how to achieve this?? i have tried to modify with eventtransformer code in many ways, but all i get is to turn back to 24hr; it seems like it defaults to my locale (ES), and i don’t want to switch since i want everything to be in Spanish.
                Any suggestions are welcomed, thank you.
                eventTransformer: (event) => {
                  // Get the event's start time as a Date object
                  let startDate = new Date(event.startDate);
                  // Manually extract hours and minutes
                  let hours = startDate.getHours();
                  let minutes = startDate.getMinutes();
                  // Determine AM or PM
                  let ampm = hours >= 12 ? 'pm' : 'am';
                  // Convert 24-hour format to 12-hour
                  hours = hours % 12;
                  hours = hours ? hours : 12;  // If 0 (midnight/noon), set to 12
                  // Format minutes (add leading zero if needed)
                  let formattedMinutes = minutes < 10 ? '0' + minutes : minutes;
                  // Construct the final time format (e.g., "9am" or "9:15am")
                  let formattedTime = `${hours}${minutes === 0 ? '' : ':' + formattedMinutes}${ampm}`;
                  // Manually set the formatted time as the event's start time
                  event.startTime = formattedTime;
                  return event;  // Return the modified event with the new time
                  sdetweil @danncabrera
                  @danncabrera did you try to change the formatting via the module configuration ?
                  see
                  https://devhints.io/moment
                    MMRIZE @sdetweil
                    @sdetweil this module doesn’t use moment module. It is using pure JavaScript Intl function
                      sdetweil @MMRIZE
                      @MMRIZE i stand corrected, sadly few options for formatting
                      D 1 Reply Last reply
                        MMRIZE @danncabrera
                        @danncabrera
                        https://forum.magicmirror.builders/post/101510
                        • G
                          GerrieD
                          this month has to much weeks so I am having overlap issues, one of my options is to remove the header (September) but I cant find where to remove it.
                          I am trying to remove the Month at the top.
                                     module: "MMM-CalendarExt3",
                                     title: "",
                                     instanceId: '1',
                                       mode: 'month',
                                       carouselId: "basicCalendar",
                                       locale: 'en-ZA',
                          		     header: "",
                                       //headerTitleOptions: {month: 'long' , year:'numeric'},
                          		     eventTimeOptions: {timeStyle: 'short'},
                          		     useWeather: false,
                                       maxEventLines: 5,
                                       firstDayOfWeek: 1,
                          		     displayEndTime: false,
                          		     useMarquee: true,
                          		     displayCW: false,
                          		     showMore: true,
                          		     showEnd: false,
                          		     weekIndex: 0, // From which week the view starts; -1 : last week, 0: this week 2: 2 weeks later, ...
                          		     weeksInView: 5, // How many weeks will be shown from `weekIndex`
                          		     fontSize: "18px",
                                       eventHight: "20px",
                          		     calendarSet: ['Pieter', 'US_holiday'],
                          .MMM-CalendarExt3 .module-header {
                          	text-align:center;
                          	padding-bottom :30px;
                          	font-size:80px;
                          	color:rgb(45,73,69);     /*This is the Header Month Colour  */
                          	/*text-shadow: -1px 0 white, 0 1px white, 1px 0 white, 0 -1px white;*/
                          	display: none;
                            sdetweil @GerrieD
                            @GerrieD i don’t know exactly, but you can use the developers window to find the html element and get its classes
                            see the second link in my signature for how to use the developers window
                            G 1 Reply Last reply
                            • G
                              GerrieD @sdetweil
                              @sdetweil thanks for you quick response
                              I have followed a lot of your hep topics and thanks to you got familiar with the developers window.
                              I added the display: none; to the module but in the developers window it is crossed out.
                              S 2 Replies Last reply
                                sdetweil @GerrieD
                                @GerrieD you can add !important
                                after the display:none;
                                display:none !important;
                                this should override the more specific
                                you are doing this in the top window. right
                                in custom.css
                                .CX3 .module-header {
                                display:none;
                                should work tho
                                  sdetweil @GerrieD
                                  @GerrieD also, in the top window you have display:block, the top window overrides those below
                                  remove that top window should be empty
                                  element.style
                                  • G
                                    GerrieD @sdetweil
                                    @sdetweil said in MMM-CalendarExt3:
                                    That worked. I try to not use !important to much (someone told me not to do it)
                                    But in this case it worked 100%
                                    • G
                                      GerrieD @sdetweil
                                      Thanks, I will see where to fix that as well.
                                      Sam you are a legend here!!
                                        sdetweil @GerrieD
                                        @GerrieD i think that element.style is only if you type it. should be empty when you open dev window
                                          danncabrera @sdetweil
                                          @sdetweil Thank you for your support. This community is awesome.
                                            danncabrera @MMRIZE
                                            @MMRIZE Thank you for taking the time, that post was super helpful. You are a legend!
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 34
                                            • 35
                                            • 27 / 35
