    MMM-CalendarExt3
    689 Posts 82 Posters 3.0m Views 86 Watching
      MMRIZE @moosespectacles
      @moosespectacles
      I think what you want is MMM-CalendarExtJournal, not this module.
        moosespectacles @MMRIZE
        @MMRIZE said in MMM-CalendarExt3:
        @moosespectacles
        The thing is I want the full calendar functionality, similar to Google calendar/skylight, so I have the ability to change views. Is that possible with either module or another? My main goal is a fully functional Google/skylight calendar clone, in terms of looks and features and use that as my layout, and build the rest of my features/modules off of that, so if I decide I want to add a tab for a shopping list or to do list later on, I can, but at minimum I’d love to be able to have a calendar that syncs with all of my family’s devices to be a family calendar
          danncabrera
          Love this module, and have spent some time modifying some parts of it using CSS and learning a lot on the way. One thing i have not been able to achieve is to have the time format to show exactly how i want it to be.
          I want the time for any event to show like 9am / 9:15am instead of the “9:00 a.m.”, to save some space and try to make it more readable. Any ideas on how to achieve this?? i have tried to modify with eventtransformer code in many ways, but all i get is to turn back to 24hr; it seems like it defaults to my locale (ES), and i don’t want to switch since i want everything to be in Spanish.
          Any suggestions are welcomed, thank you.
          eventTransformer: (event) => {
            // Get the event's start time as a Date object
            let startDate = new Date(event.startDate);
            // Manually extract hours and minutes
            let hours = startDate.getHours();
            let minutes = startDate.getMinutes();
            // Determine AM or PM
            let ampm = hours >= 12 ? 'pm' : 'am';
            // Convert 24-hour format to 12-hour
            hours = hours % 12;
            hours = hours ? hours : 12;  // If 0 (midnight/noon), set to 12
            // Format minutes (add leading zero if needed)
            let formattedMinutes = minutes < 10 ? '0' + minutes : minutes;
            // Construct the final time format (e.g., "9am" or "9:15am")
            let formattedTime = `${hours}${minutes === 0 ? '' : ':' + formattedMinutes}${ampm}`;
            // Manually set the formatted time as the event's start time
            event.startTime = formattedTime;
            return event;  // Return the modified event with the new time
            sdetweil @danncabrera
            @danncabrera did you try to change the formatting via the module configuration ?
            see
            https://devhints.io/moment
              MMRIZE @sdetweil
              @sdetweil this module doesn’t use moment module. It is using pure JavaScript Intl function
                sdetweil @MMRIZE
                @MMRIZE i stand corrected, sadly few options for formatting
                  MMRIZE @danncabrera
                  @danncabrera
                  https://forum.magicmirror.builders/post/101510
                  • G Offline
                    GerrieD
                    this month has to much weeks so I am having overlap issues, one of my options is to remove the header (September) but I cant find where to remove it.
                    I am trying to remove the Month at the top.
                               module: "MMM-CalendarExt3",
                               title: "",
                               instanceId: '1',
                                 mode: 'month',
                                 carouselId: "basicCalendar",
                                 locale: 'en-ZA',
                    		     header: "",
                                 //headerTitleOptions: {month: 'long' , year:'numeric'},
                    		     eventTimeOptions: {timeStyle: 'short'},
                    		     useWeather: false,
                                 maxEventLines: 5,
                                 firstDayOfWeek: 1,
                    		     displayEndTime: false,
                    		     useMarquee: true,
                    		     displayCW: false,
                    		     showMore: true,
                    		     showEnd: false,
                    		     weekIndex: 0, // From which week the view starts; -1 : last week, 0: this week 2: 2 weeks later, ...
                    		     weeksInView: 5, // How many weeks will be shown from `weekIndex`
                    		     fontSize: "18px",
                                 eventHight: "20px",
                    		     calendarSet: ['Pieter', 'US_holiday'],
                    .MMM-CalendarExt3 .module-header {
                    	text-align:center;
                    	padding-bottom :30px;
                    	font-size:80px;
                    	color:rgb(45,73,69);     /*This is the Header Month Colour  */
                    	/*text-shadow: -1px 0 white, 0 1px white, 1px 0 white, 0 -1px white;*/
                    	display: none;
                      sdetweil @GerrieD
                      @GerrieD i don’t know exactly, but you can use the developers window to find the html element and get its classes
                      see the second link in my signature for how to use the developers window
                      • G Offline
                        GerrieD @sdetweil
                        @sdetweil thanks for you quick response
                        I have followed a lot of your hep topics and thanks to you got familiar with the developers window.
                        I added the display: none; to the module but in the developers window it is crossed out.
                          sdetweil @GerrieD
                          @GerrieD you can add !important
                          after the display:none;
                          display:none !important;
                          this should override the more specific
                          you are doing this in the top window. right
                          in custom.css
                          .CX3 .module-header {
                          display:none;
                          should work tho
                            sdetweil @GerrieD
                            @GerrieD also, in the top window you have display:block, the top window overrides those below
                            remove that top window should be empty
                            element.style
                            • G Offline
                              GerrieD @sdetweil
                              @sdetweil said in MMM-CalendarExt3:
                              That worked. I try to not use !important to much (someone told me not to do it)
                              But in this case it worked 100%
                              • G Offline
                                GerrieD @sdetweil
                                Thanks, I will see where to fix that as well.
                                Sam you are a legend here!!
                                  sdetweil @GerrieD
                                  @GerrieD i think that element.style is only if you type it. should be empty when you open dev window
                                    danncabrera @sdetweil
                                    @sdetweil Thank you for your support. This community is awesome.
                                      danncabrera @MMRIZE
                                      @MMRIZE Thank you for taking the time, that post was super helpful. You are a legend!
                                        @danncabrera I wanted to post additional info for anyone else looking in
                                        the image you posted of the dev window had the cause of the strikethru(overridden)
                                        your pointer red/pink shows the strikethru… which means something ABOVE in the SAME COLUMN has that setting too… (and it wins)
                                        my purple arrow
                                        you’ll see that font-size in the header{ } is also strike thru, because the
                                        .MMM-CalendarExt3 .module-header (ABOVE) the header specifies the font-size,
                                        thus overriding the header setting…
                                        and you can’t see it in these pics cause of the clipping,but the source of that
                                        .MMM-CalendarExt3 .module-header came from the custom.css file…
                                        (right edge same row)
                                          MMRIZE
                                          UPDATE 1.9.0 (2024-09-25)
                                          • customHeader available,.
                                            Now you can add customHeader for the calendar view instead of module’s default header.
                                          • variable maxEventLines by number of rows
                                            Every month has a different number of weeks in its calendar, so it was hard to adjust the height of the month view. Now, you can assign the variable maxEventLines by the number of rows. (And additional CSS Selectors related to it was added.)
                                          G 1 Reply Last reply Reply Quote 1
                                          • G Offline
                                            GerrieD @MMRIZE
                                            @MMRIZE
                                            Wow thanks for adding this. I have not tested yet, but I assume that with this update I can limit the size of the calendar if we have a 6 week month like this month.
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 34
                                            • 35
                                            • 27 / 35
