    MMM-CalendarExt3
    689 Posts 82 Posters 3.1m Views 86 Watching
      MMRIZE @bobbylx
      @bobbylx
      To emphasize this month, I added this to the cells of this month.
      .CX3 .thisMonth {
        background-color: rgb(255 255 255 / 10%);
      rgb(RED GREEN BLUE / TRANSPARENCY); could be what you were searching.
        bobbylx @MMRIZE
        @MMRIZE said in MMM-CalendarExt3:
        @bobbylx
        .CX3 .thisMonth {
        Thanks again, this did it.
          almightyyoshi
          I have a Cozi calendar for dinner and the event comes over as “All: Pork Tenderloin”. Is there any way to get rid of the “All:” (with either Transform or preProcessor) and keep the rest?
            MMRIZE @almightyyoshi
            @almightyyoshi
            eventTransformer: (ev) => {
              ev.title = ev.title.replace("All:", "")
              return ev
              almightyyoshi @MMRIZE
              @MMRIZE Sigh. I knew it was going to be something easy like that and I was overthinking it. Thanks! Couple more questions:
              1. How can I remove the CW? I’ve tried:
              .CX3 .cell.cellHeader .cw {
                      display: none;
              .CX3 .cell .cellHeader .cw {
                      display: none;
              .CX3 .cellHeader .cw {
                      display: none;
              and
              .CX3 .cell .cw {
                      display: none;
              1. How can I remove the start time in an instance? I’ve tried:
              .CX3_currentMonth .event .time.startTime {
                      display: none;
              I got it working with a specific calendar using:
              .CX3 .event.calendar_Dinner .time.startTime {
                      display: none;
                @almightyyoshi
                For removing calendarWeek number;
                https://github.com/MMRIZE/MMM-CalendarExt3/wiki/Examples-%26-Tips
                  @almightyyoshi
                  For the second question, I cannot understand. More details for TO-BE and AS-IS be needed. (Show me the example)
                    @MMRIZE Perfect. Thanks!
                      @MMRIZE I have two instances of CalExt3: monthly (currentMonth) and weekly (currentWeek). Except for one calendar (Dinner), they both currently shows events with the event time like this:
                      What I’d like is for only the currentMonth instance to show events without the event time like this:
                        @almightyyoshi
                        /* css/custom.css */
                        .CX3_currentMonth .event.singleday .headline .time {
                          display: none;
                        Before
                        After
                          @MMRIZE That worked…after I figured out I spelled instanceId incorrectly (I had instanceID). Thanks!
                            moosespectacles
                            Anyone know of a config that looks identical/similar to the skylight calendar layout? I’m trying to emulate that look and those features, as a starting point, but I’m having trouble with getting the calendar to even display one week or 3 days, only. At the moment I see a week, with another week right next to it, instead of underneath it, as well as week numbers being show. I haven’t been able to figure out how to get rid of the extra days, nor the week numbers.
                              sdetweil @moosespectacles
                              @moosespectacles well the skylight view is one week
                              so
                              mode:‘week’,
                              weeksInView:1,
                              then you have to use css to remove the weeknumber
                                MMRIZE @moosespectacles
                                @moosespectacles
                                I think what you want is MMM-CalendarExtJournal, not this module.
                                  moosespectacles @MMRIZE
                                  @moosespectacles
                                  The thing is I want the full calendar functionality, similar to Google calendar/skylight, so I have the ability to change views. Is that possible with either module or another? My main goal is a fully functional Google/skylight calendar clone, in terms of looks and features and use that as my layout, and build the rest of my features/modules off of that, so if I decide I want to add a tab for a shopping list or to do list later on, I can, but at minimum I’d love to be able to have a calendar that syncs with all of my family’s devices to be a family calendar
                                    danncabrera
                                    Love this module, and have spent some time modifying some parts of it using CSS and learning a lot on the way. One thing i have not been able to achieve is to have the time format to show exactly how i want it to be.
                                    I want the time for any event to show like 9am / 9:15am instead of the “9:00 a.m.”, to save some space and try to make it more readable. Any ideas on how to achieve this?? i have tried to modify with eventtransformer code in many ways, but all i get is to turn back to 24hr; it seems like it defaults to my locale (ES), and i don’t want to switch since i want everything to be in Spanish.
                                    Any suggestions are welcomed, thank you.
                                    eventTransformer: (event) => {
                                      // Get the event's start time as a Date object
                                      let startDate = new Date(event.startDate);
                                      // Manually extract hours and minutes
                                      let hours = startDate.getHours();
                                      let minutes = startDate.getMinutes();
                                      // Determine AM or PM
                                      let ampm = hours >= 12 ? 'pm' : 'am';
                                      // Convert 24-hour format to 12-hour
                                      hours = hours % 12;
                                      hours = hours ? hours : 12;  // If 0 (midnight/noon), set to 12
                                      // Format minutes (add leading zero if needed)
                                      let formattedMinutes = minutes < 10 ? '0' + minutes : minutes;
                                      // Construct the final time format (e.g., "9am" or "9:15am")
                                      let formattedTime = `${hours}${minutes === 0 ? '' : ':' + formattedMinutes}${ampm}`;
                                      // Manually set the formatted time as the event's start time
                                      event.startTime = formattedTime;
                                      return event;  // Return the modified event with the new time
                                      sdetweil @danncabrera
                                      @danncabrera did you try to change the formatting via the module configuration ?
                                      see
                                      https://devhints.io/moment
                                        MMRIZE @sdetweil
                                        @sdetweil this module doesn’t use moment module. It is using pure JavaScript Intl function
                                          sdetweil @MMRIZE
                                          @MMRIZE i stand corrected, sadly few options for formatting
                                            MMRIZE @danncabrera
                                            @danncabrera
                                            https://forum.magicmirror.builders/post/101510
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 34
                                            • 35
                                            • 27 / 35
