    MMM-CalendarExt3
    689 Posts 82 Posters 3.3m Views 86 Watching
      MMRIZE @almightyyoshi
      @almightyyoshi
      eventTransformer: (ev) => {
        ev.title = ev.title.replace("All:", "")
        return ev
      A 1 Reply Last reply
      • A
        almightyyoshi @MMRIZE
        @MMRIZE Sigh. I knew it was going to be something easy like that and I was overthinking it. Thanks! Couple more questions:
        1. How can I remove the CW? I’ve tried:
        .CX3 .cell.cellHeader .cw {
                display: none;
        .CX3 .cell .cellHeader .cw {
                display: none;
        .CX3 .cellHeader .cw {
                display: none;
        and
        .CX3 .cell .cw {
                display: none;
        1. How can I remove the start time in an instance? I’ve tried:
        .CX3_currentMonth .event .time.startTime {
                display: none;
        I got it working with a specific calendar using:
        .CX3 .event.calendar_Dinner .time.startTime {
                display: none;
        M 2 Replies Last reply
          @almightyyoshi
          For removing calendarWeek number;
          https://github.com/MMRIZE/MMM-CalendarExt3/wiki/Examples-%26-Tips
            @almightyyoshi
            For the second question, I cannot understand. More details for TO-BE and AS-IS be needed. (Show me the example)
            • A
              @MMRIZE Perfect. Thanks!
              • A
                @MMRIZE I have two instances of CalExt3: monthly (currentMonth) and weekly (currentWeek). Except for one calendar (Dinner), they both currently shows events with the event time like this:
                What I’d like is for only the currentMonth instance to show events without the event time like this:
                M 1 Reply Last reply
                  @almightyyoshi
                  /* css/custom.css */
                  .CX3_currentMonth .event.singleday .headline .time {
                    display: none;
                  Before
                  After
                  • A
                    @MMRIZE That worked…after I figured out I spelled instanceId incorrectly (I had instanceID). Thanks!
                      moosespectacles
                      Anyone know of a config that looks identical/similar to the skylight calendar layout? I’m trying to emulate that look and those features, as a starting point, but I’m having trouble with getting the calendar to even display one week or 3 days, only. At the moment I see a week, with another week right next to it, instead of underneath it, as well as week numbers being show. I haven’t been able to figure out how to get rid of the extra days, nor the week numbers.
                      S M 2 Replies Last reply
                        sdetweil @moosespectacles
                        @moosespectacles well the skylight view is one week
                        so
                        mode:‘week’,
                        weeksInView:1,
                        then you have to use css to remove the weeknumber
                          MMRIZE @moosespectacles
                          @moosespectacles
                          I think what you want is MMM-CalendarExtJournal, not this module.
                            moosespectacles @MMRIZE
                            @MMRIZE said in MMM-CalendarExt3:
                            @moosespectacles
                            The thing is I want the full calendar functionality, similar to Google calendar/skylight, so I have the ability to change views. Is that possible with either module or another? My main goal is a fully functional Google/skylight calendar clone, in terms of looks and features and use that as my layout, and build the rest of my features/modules off of that, so if I decide I want to add a tab for a shopping list or to do list later on, I can, but at minimum I’d love to be able to have a calendar that syncs with all of my family’s devices to be a family calendar
                              danncabrera
                              Love this module, and have spent some time modifying some parts of it using CSS and learning a lot on the way. One thing i have not been able to achieve is to have the time format to show exactly how i want it to be.
                              I want the time for any event to show like 9am / 9:15am instead of the “9:00 a.m.”, to save some space and try to make it more readable. Any ideas on how to achieve this?? i have tried to modify with eventtransformer code in many ways, but all i get is to turn back to 24hr; it seems like it defaults to my locale (ES), and i don’t want to switch since i want everything to be in Spanish.
                              Any suggestions are welcomed, thank you.
                              eventTransformer: (event) => {
                                // Get the event's start time as a Date object
                                let startDate = new Date(event.startDate);
                                // Manually extract hours and minutes
                                let hours = startDate.getHours();
                                let minutes = startDate.getMinutes();
                                // Determine AM or PM
                                let ampm = hours >= 12 ? 'pm' : 'am';
                                // Convert 24-hour format to 12-hour
                                hours = hours % 12;
                                hours = hours ? hours : 12;  // If 0 (midnight/noon), set to 12
                                // Format minutes (add leading zero if needed)
                                let formattedMinutes = minutes < 10 ? '0' + minutes : minutes;
                                // Construct the final time format (e.g., "9am" or "9:15am")
                                let formattedTime = `${hours}${minutes === 0 ? '' : ':' + formattedMinutes}${ampm}`;
                                // Manually set the formatted time as the event's start time
                                event.startTime = formattedTime;
                                return event;  // Return the modified event with the new time
                                sdetweil @danncabrera
                                @danncabrera did you try to change the formatting via the module configuration ?
                                see
                                https://devhints.io/moment
                                  MMRIZE @sdetweil
                                  @sdetweil this module doesn’t use moment module. It is using pure JavaScript Intl function
                                    sdetweil @MMRIZE
                                    @MMRIZE i stand corrected, sadly few options for formatting
                                    D 1 Reply Last reply
                                      MMRIZE @danncabrera
                                      @danncabrera
                                      https://forum.magicmirror.builders/post/101510
                                      • G
                                        GerrieD
                                        this month has to much weeks so I am having overlap issues, one of my options is to remove the header (September) but I cant find where to remove it.
                                        I am trying to remove the Month at the top.
                                                   module: "MMM-CalendarExt3",
                                                   title: "",
                                                   instanceId: '1',
                                                     mode: 'month',
                                                     carouselId: "basicCalendar",
                                                     locale: 'en-ZA',
                                        		     header: "",
                                                     //headerTitleOptions: {month: 'long' , year:'numeric'},
                                        		     eventTimeOptions: {timeStyle: 'short'},
                                        		     useWeather: false,
                                                     maxEventLines: 5,
                                                     firstDayOfWeek: 1,
                                        		     displayEndTime: false,
                                        		     useMarquee: true,
                                        		     displayCW: false,
                                        		     showMore: true,
                                        		     showEnd: false,
                                        		     weekIndex: 0, // From which week the view starts; -1 : last week, 0: this week 2: 2 weeks later, ...
                                        		     weeksInView: 5, // How many weeks will be shown from `weekIndex`
                                        		     fontSize: "18px",
                                                     eventHight: "20px",
                                        		     calendarSet: ['Pieter', 'US_holiday'],
                                        .MMM-CalendarExt3 .module-header {
                                        	text-align:center;
                                        	padding-bottom :30px;
                                        	font-size:80px;
                                        	color:rgb(45,73,69);     /*This is the Header Month Colour  */
                                        	/*text-shadow: -1px 0 white, 0 1px white, 1px 0 white, 0 -1px white;*/
                                        	display: none;
                                          sdetweil @GerrieD
                                          @GerrieD i don’t know exactly, but you can use the developers window to find the html element and get its classes
                                          see the second link in my signature for how to use the developers window
                                          G 1 Reply Last reply
                                          • G
                                            GerrieD @sdetweil
                                            @sdetweil thanks for you quick response
                                            I have followed a lot of your hep topics and thanks to you got familiar with the developers window.
                                            I added the display: none; to the module but in the developers window it is crossed out.
                                            S 2 Replies Last reply
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 34
                                            • 35
                                            • 27 / 35
