    MMM-CalendarExt3
    689 Posts 82 Posters 3.3m Views 86 Watching
      bobbylx @MMRIZE
      @MMRIZE said in MMM-CalendarExt3:
      @bobbylx
      To emphasize this month, I added this to the cells of this month.
      .CX3 .thisMonth {
        background-color: rgb(255 255 255 / 10%);
      rgb(RED GREEN BLUE / TRANSPARENCY); could be what you were searching.
      Thanks again, this did it.
      • A
        almightyyoshi
        I have a Cozi calendar for dinner and the event comes over as “All: Pork Tenderloin”. Is there any way to get rid of the “All:” (with either Transform or preProcessor) and keep the rest?
        M 1 Reply Last reply
          MMRIZE @almightyyoshi
          @almightyyoshi
          eventTransformer: (ev) => {
            ev.title = ev.title.replace("All:", "")
            return ev
          A 1 Reply Last reply
          • A
            almightyyoshi @MMRIZE
            @MMRIZE Sigh. I knew it was going to be something easy like that and I was overthinking it. Thanks! Couple more questions:
            1. How can I remove the CW? I’ve tried:
            .CX3 .cell.cellHeader .cw {
                    display: none;
            .CX3 .cell .cellHeader .cw {
                    display: none;
            .CX3 .cellHeader .cw {
                    display: none;
            and
            .CX3 .cell .cw {
                    display: none;
            1. How can I remove the start time in an instance? I’ve tried:
            .CX3_currentMonth .event .time.startTime {
                    display: none;
            I got it working with a specific calendar using:
            .CX3 .event.calendar_Dinner .time.startTime {
                    display: none;
            M 2 Replies Last reply
              @almightyyoshi
              For removing calendarWeek number;
              https://github.com/MMRIZE/MMM-CalendarExt3/wiki/Examples-%26-Tips
                @almightyyoshi
                For the second question, I cannot understand. More details for TO-BE and AS-IS be needed. (Show me the example)
                • A
                  @MMRIZE Perfect. Thanks!
                  • A
                    @MMRIZE I have two instances of CalExt3: monthly (currentMonth) and weekly (currentWeek). Except for one calendar (Dinner), they both currently shows events with the event time like this:
                    What I’d like is for only the currentMonth instance to show events without the event time like this:
                      @almightyyoshi
                      /* css/custom.css */
                      .CX3_currentMonth .event.singleday .headline .time {
                        display: none;
                      Before
                      After
                      • A
                        @MMRIZE That worked…after I figured out I spelled instanceId incorrectly (I had instanceID). Thanks!
                          moosespectacles
                          Anyone know of a config that looks identical/similar to the skylight calendar layout? I’m trying to emulate that look and those features, as a starting point, but I’m having trouble with getting the calendar to even display one week or 3 days, only. At the moment I see a week, with another week right next to it, instead of underneath it, as well as week numbers being show. I haven’t been able to figure out how to get rid of the extra days, nor the week numbers.
                          S M 2 Replies Last reply
                            sdetweil @moosespectacles
                            @moosespectacles well the skylight view is one week
                            so
                            mode:‘week’,
                            weeksInView:1,
                            then you have to use css to remove the weeknumber
                              MMRIZE @moosespectacles
                              @moosespectacles
                              I think what you want is MMM-CalendarExtJournal, not this module.
                                moosespectacles @MMRIZE
                                @moosespectacles
                                The thing is I want the full calendar functionality, similar to Google calendar/skylight, so I have the ability to change views. Is that possible with either module or another? My main goal is a fully functional Google/skylight calendar clone, in terms of looks and features and use that as my layout, and build the rest of my features/modules off of that, so if I decide I want to add a tab for a shopping list or to do list later on, I can, but at minimum I’d love to be able to have a calendar that syncs with all of my family’s devices to be a family calendar
                                  danncabrera
                                  Love this module, and have spent some time modifying some parts of it using CSS and learning a lot on the way. One thing i have not been able to achieve is to have the time format to show exactly how i want it to be.
                                  I want the time for any event to show like 9am / 9:15am instead of the “9:00 a.m.”, to save some space and try to make it more readable. Any ideas on how to achieve this?? i have tried to modify with eventtransformer code in many ways, but all i get is to turn back to 24hr; it seems like it defaults to my locale (ES), and i don’t want to switch since i want everything to be in Spanish.
                                  Any suggestions are welcomed, thank you.
                                  eventTransformer: (event) => {
                                    // Get the event's start time as a Date object
                                    let startDate = new Date(event.startDate);
                                    // Manually extract hours and minutes
                                    let hours = startDate.getHours();
                                    let minutes = startDate.getMinutes();
                                    // Determine AM or PM
                                    let ampm = hours >= 12 ? 'pm' : 'am';
                                    // Convert 24-hour format to 12-hour
                                    hours = hours % 12;
                                    hours = hours ? hours : 12;  // If 0 (midnight/noon), set to 12
                                    // Format minutes (add leading zero if needed)
                                    let formattedMinutes = minutes < 10 ? '0' + minutes : minutes;
                                    // Construct the final time format (e.g., "9am" or "9:15am")
                                    let formattedTime = `${hours}${minutes === 0 ? '' : ':' + formattedMinutes}${ampm}`;
                                    // Manually set the formatted time as the event's start time
                                    event.startTime = formattedTime;
                                    return event;  // Return the modified event with the new time
                                    sdetweil @danncabrera
                                    @danncabrera did you try to change the formatting via the module configuration ?
                                    see
                                    https://devhints.io/moment
                                      MMRIZE @sdetweil
                                      @sdetweil this module doesn’t use moment module. It is using pure JavaScript Intl function
                                        sdetweil @MMRIZE
                                        @MMRIZE i stand corrected, sadly few options for formatting
                                        D 1 Reply Last reply
                                          MMRIZE @danncabrera
                                          @danncabrera
                                          https://forum.magicmirror.builders/post/101510
                                          • G
                                            GerrieD
                                            this month has to much weeks so I am having overlap issues, one of my options is to remove the header (September) but I cant find where to remove it.
                                            I am trying to remove the Month at the top.
                                                       module: "MMM-CalendarExt3",
                                                       title: "",
                                                       instanceId: '1',
                                                         mode: 'month',
                                                         carouselId: "basicCalendar",
                                                         locale: 'en-ZA',
                                            		     header: "",
                                                         //headerTitleOptions: {month: 'long' , year:'numeric'},
                                            		     eventTimeOptions: {timeStyle: 'short'},
                                            		     useWeather: false,
                                                         maxEventLines: 5,
                                                         firstDayOfWeek: 1,
                                            		     displayEndTime: false,
                                            		     useMarquee: true,
                                            		     displayCW: false,
                                            		     showMore: true,
                                            		     showEnd: false,
                                            		     weekIndex: 0, // From which week the view starts; -1 : last week, 0: this week 2: 2 weeks later, ...
                                            		     weeksInView: 5, // How many weeks will be shown from `weekIndex`
                                            		     fontSize: "18px",
                                                         eventHight: "20px",
                                            		     calendarSet: ['Pieter', 'US_holiday'],
                                            .MMM-CalendarExt3 .module-header {
                                            	text-align:center;
                                            	padding-bottom :30px;
                                            	font-size:80px;
                                            	color:rgb(45,73,69);     /*This is the Header Month Colour  */
                                            	/*text-shadow: -1px 0 white, 0 1px white, 1px 0 white, 0 -1px white;*/
                                            	display: none;
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 34
                                            • 35
                                            • 27 / 35
