    MMM-Soccer - Standings, Schedules and Top Scorers
    bundesligafootballmodalpremiere leagueprimiera divisionsoccervoice control
    209 Posts 43 Posters 534.0k Views 43 Watching
      CCoates
      Just added this to my mirror and tin the English Championship league 427
      colour logos for Reading, Preston North End, Brentford, Wolverhampton Wanderers, Bristol City, Blackburn Rovers & Leeds United aren’t working
      (Sorry)
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @CCoates
        @CCoates should be fixed
        TheHyp3T 1 Reply Last reply Reply Quote 0
        • TheHyp3T Offline
          TheHyp3 @strawberry 3.141
          @strawberry-3.141 it is, thank you!
          • O Offline
            ostfilinchen
            Hi @strawberry-3-141. Can u please check the logo for RB Leipzig. It doesn’t shown on my Mirror.
              strawberry 3.141 Project Sponsor Module Developer @ostfilinchen
              @ostfilinchen should be fixed, but i found just the old logo.
              seems to get worse with the icons, probably worth to implement an icon downloader
              • O Offline
                ostfilinchen @strawberry 3.141
                @strawberry-3.141 thanks. Yes i think this would be a great idea :-)
                • SteffS Offline
                  Steff
                  @strawberry-3-141 Now I do have the similar problem for 1. FSV Mainz 05.
                  Adding this line in the .js file solved it:
                  “1. FSV Mainz 05”: “https://upload.wikimedia.org/wikipedia/commons/thumb/d/d6/FSV_Mainz_05_Logo.png/100px-FSV_Mainz_05_Logo.png”
                  Do you think it might make sense to include it as well on github ? Thanks
                  strawberry 3.141S 1 Reply Last reply Reply Quote 1
                    strawberry 3.141 Project Sponsor Module Developer @Steff
                    @Steff done thank you
                    • O Offline
                      @strawberry-3.141 i found a zip file (http://www.vmlogic.net/Downloads/Files/public/dfs_media_2016-09-07.zip) with logos for the soccerclubs. do u think you can implement a downloader and use these logos for the module?
                        @ostfilinchen i will check it in 2-3 weeks after im done with my bachelor stuff. Thank you
                        O 1 Reply Last reply Reply Quote 1
                        • O Offline
                          @strawberry-3.141 the Module wouldn’t start. It only display loading…
                          I have update it and Do npm install
                            @ostfilinchen should be fixed now, was my fault
                            • O Offline
                              @strawberry-3.141 must i do npm install?
                                @ostfilinchen no the dependencies havent changed
                                • O Offline
                                  @strawberry-3.141 great! Works now.
                                    STEFF92
                                    at first, sorry for my bad english. I’m a totally beginner and MMM-Soccer is the first module i want to install by myself. At first i downloaded the Zip file, unpacked it and copied it into /home/pi/MagicMirror/modules. Then i opened the config.js file and added:
                                    module: ‘MMM-soccer’,
                                    position: ‘bottom_right’,
                                    api_key: ‘7cgd8…’,
                                    colored: ‘false’,
                                    show: ‘GERMANY’,
                                    leagues: {“GERMANY”:430},
                                    Then i opened the LXTerminal on the raspberry pi and typed in :
                                    pi@raspberrypi:~/MagicMirror $ npm install ~/MagicMirror/modules/MMM-soccer
                                    Then there came:
                                    npm ERR! addLocal Could not install /home/pi/MagicMirror…
                                    npm ERR! Linux …
                                    What did i wrong? Can anyone help me please?
                                      strawberry 3.141 Project Sponsor Module Developer @STEFF92
                                      @STEFF92 in the terminal you have to do cd ~/MagicMirror/modules/MMM-soccer then npm install
                                      and in your config you have to remove the quotes here colored: false,
                                        STEFF92 @strawberry 3.141
                                        @strawberry-3.141 but then there is :
                                        bash: cd: /home/pi/MagicMirror/modules/MMM-soccer: file or directory not found
                                          @STEFF92 then you did something wrong. Because you said you manually downloaded the files etc. I suggest to delete it again and start from scratch, this will help you to update more easily in future.
                                          type in the terminal
                                          git clone https://github.com/fewieden/MMM-soccer.git
                                          cd MMM-soccer
                                          npm install
                                            @strawberry-3.141 ok now i did it how you said. when its finished i only have to add the module in my config.js file right? and then thats it?
                                            • 10
                                            • 11
                                            • 4 / 11
