    MMM-OpenWeatherForecast
    92 Posts 14 Posters 64.4k Views 14 Watching
      Ray
      So I went ahead and applied for the app 3.0
      and gave them my credit card
      and it was extremely easy to do
      I did not have to create a new app key I was able to use my original ones
      I also change the number of calls from 10 minutes to 15 minutes
      and I added “https://api.openweathermap.org/data/3.0/onecall?”
      In the node_helper.js
      thanks to everyone here I was successful
      my two systems are back online showing the current temperature
      S J 2 Replies Last reply Reply Quote 0
        sdetweil @Ray
        @Ray said in MMM-OpenWeatherForecast:
        if you change to the latest version/fork of the module you do not need to do that
          Ray @sdetweil
          I was under the impression that I had to do that in order for it to work
          so I don’t understand what you mean what other way is there
            sdetweil @Ray
            @Ray which repo are you using
            do
            git remote -v
            in the module folder
              Ray @sdetweil
              okay I got this
              origin https://github.com/MichMich/MagicMirror.git (fetch)
              origin https://github.com/MichMich/MagicMirror.git (push)
              is that what you’re looking for
              R S 2 Replies Last reply Reply Quote 0
                Ray @Ray
                @Ray
                I also got this
                origin https://github.com/jclarke0000/MMM-OpenWeatherForecast.git (fetch)
                origin https://github.com/jclarke0000/MMM-OpenWeatherForecast.git (push)
                  sdetweil @Ray
                  @Ray no… in the MMM-OpenWeatherForecast module folder
                    Ray @sdetweil
                    @sdetweil the last one there I posted was done in that folder
                    but I can’t say I have the older version that is been working good for years
                      Ray @Ray
                      @Ray origin https://github.com/jclarke0000/MMM-OpenWeatherForecast.git (fetch)
                      ray@ray-VirtualBox:~/MagicMirror/modules/MMM-OpenWeatherForecast$
                        sdetweil @Ray
                        @Ray yes, that is the original, now some 3 years old
                        from the modules list (linked in the header of the forum),
                        https://kristjanesperanto.github.io/MagicMirror-3rd-Party-Modules/
                        with openweather in the search box
                        https://github.com/Tom-Hirschberger/MMM-OpenWeatherForecast
                          Ray @sdetweil
                          the one that’s installed on my mirror is
                          jclarke0000
                            sdetweil @Ray
                            @Ray i know, that is old, time to migrate to a newer version
                              megagprime
                              Hi guys, so do we have a definitive fix? I tried new api key, old api key, base url, no base url, still not working.
                                sdetweil @megagprime
                                  megagprime @sdetweil
                                  @sdetweil yes thank you i have done all that, still doesn’t work. Do i need to update the module?
                                    @megagprime id let the module set the urlbase
                                      @megagprime also note the config parms it uses
                                        @sdetweil i did, i commented out the urlbase. All the other config settings are the same that have been working for years.
                                        • wishmaster270W Offline
                                          wishmaster270 Module Developer @megagprime
                                          @megagprime You will need to update to the new fork of the module.
                                          It does not matter if the old settings worked for years as the provider shut down the old api and you need to use the new api if you want some information to be displayed again.
                                          The original module did not provide a way to change the url the information is fetched of. Even if you add the apiBaseUrl to the settings the old module will ignore it.
                                          I released a new version IN MY FORK yesterday which uses the new URL in default. So no need to set the base URL in the settings anymore. The version in my fork before yesterday needed the parameter in the config to work with the new api.
                                          So either change to my fork and update with:
                                          cd ~/MagicMirror/modules/MMM-OpenWeatherForecast
                                          git remote set-url origin https://github.com/Tom-Hirschberger/MMM-OpenWeatherForecast.git
                                          git pull
                                          rm -rf node_modules package-lock.json
                                          npm install
                                          Or remove the old module folder and reinstall from this Url:
                                          My Fork
                                            sdetweil @wishmaster270
                                            @wishmaster270 thanks Tom
                                            • 3 / 5
