    MMM-OpenWeatherForecast
    92 Posts 14 Posters 63.7k Views 14 Watching
      Ray @sdetweil
      I was under the impression that I had to do that in order for it to work
      so I don’t understand what you mean what other way is there
        sdetweil @Ray
        @Ray which repo are you using
        do
        git remote -v
        in the module folder
          Ray @sdetweil
          okay I got this
          origin https://github.com/MichMich/MagicMirror.git (fetch)
          origin https://github.com/MichMich/MagicMirror.git (push)
          is that what you’re looking for
          R S 2 Replies Last reply Reply Quote 0
            Ray @Ray
            @Ray
            I also got this
            origin https://github.com/jclarke0000/MMM-OpenWeatherForecast.git (fetch)
            origin https://github.com/jclarke0000/MMM-OpenWeatherForecast.git (push)
              sdetweil @Ray
              @Ray no… in the MMM-OpenWeatherForecast module folder
                Ray @sdetweil
                @sdetweil the last one there I posted was done in that folder
                but I can’t say I have the older version that is been working good for years
                  Ray @Ray
                  @Ray origin https://github.com/jclarke0000/MMM-OpenWeatherForecast.git (fetch)
                  ray@ray-VirtualBox:~/MagicMirror/modules/MMM-OpenWeatherForecast$
                    sdetweil @Ray
                    @Ray yes, that is the original, now some 3 years old
                    from the modules list (linked in the header of the forum),
                    https://kristjanesperanto.github.io/MagicMirror-3rd-Party-Modules/
                    with openweather in the search box
                    https://github.com/Tom-Hirschberger/MMM-OpenWeatherForecast
                      Ray @sdetweil
                      the one that’s installed on my mirror is
                      jclarke0000
                        sdetweil @Ray
                        @Ray i know, that is old, time to migrate to a newer version
                          megagprime
                          Hi guys, so do we have a definitive fix? I tried new api key, old api key, base url, no base url, still not working.
                            sdetweil @megagprime
                              megagprime @sdetweil
                              @sdetweil yes thank you i have done all that, still doesn’t work. Do i need to update the module?
                                @megagprime id let the module set the urlbase
                                  @megagprime also note the config parms it uses
                                    @sdetweil i did, i commented out the urlbase. All the other config settings are the same that have been working for years.
                                    • wishmaster270W Offline
                                      wishmaster270 Module Developer @megagprime
                                      @megagprime You will need to update to the new fork of the module.
                                      It does not matter if the old settings worked for years as the provider shut down the old api and you need to use the new api if you want some information to be displayed again.
                                      The original module did not provide a way to change the url the information is fetched of. Even if you add the apiBaseUrl to the settings the old module will ignore it.
                                      I released a new version IN MY FORK yesterday which uses the new URL in default. So no need to set the base URL in the settings anymore. The version in my fork before yesterday needed the parameter in the config to work with the new api.
                                      So either change to my fork and update with:
                                      cd ~/MagicMirror/modules/MMM-OpenWeatherForecast
                                      git remote set-url origin https://github.com/Tom-Hirschberger/MMM-OpenWeatherForecast.git
                                      git pull
                                      rm -rf node_modules package-lock.json
                                      npm install
                                      Or remove the old module folder and reinstall from this Url:
                                      My Fork
                                        sdetweil @wishmaster270
                                        @wishmaster270 thanks Tom
                                        • butchkemperB Offline
                                          butchkemper
                                          Howdy,
                                          I am having trouble getting MMM-OpenWeatherForecast to run and have been working my way through the problems.
                                          First problem was a typo of “apiKey” which caused this message to flood the .pm2/logs/MagicMirror-out.log. Problem solved by correctly spelling the variable name “apikey” - notice the subtle difference between the “K” and “k”.
                                          [2024-10-03 10:22:54.732] [LOG]   [MMM-OpenWeatherForecast] 3-Oct-24 10:22 ** ERROR ** No API key configured. Get an API key at https://darksky.net
                                          Once the “apikey” spelling problem was solved, the next error arrived and the log file was flooded with thousands of this message:
                                          code_[2024-10-03 12:09:29.002] [LOG]   [MMM-OpenWeatherForecast] 3-Oct-24 12:09 ** ERROR ** Latitude and/or longitude not provided.
                                          This error was caused by confusing documentation that made it appear the variables were “lat” and “lon” instead of “latitude” and “longitude”. Correcting the spelling eliminated the error messages.
                                          The current problem is this message which is again flooding the pm2 error.log:
                                          [2024-10-03 14:10:02.077] ^[[31m[ERROR]^[[39m ^[[31m[MMM-OpenWeatherForecast] 3-Oct-24 14:10 ** ERROR ** TypeError: fetch failed^[[39m
                                          I need a hint of where to look or what to do. I sure it is not hard but just me overlooking something.
                                          However,the three problems reveal that the Module contains an error that flood the log files with thousands of messages.
                                          Here is the portion configuration file relative to the OpenWeatherForecast module:
        module: "MMM-OpenWeatherForecast",
        header: "Current Weather",
        type: "hourly",
        units: "imperial",
        tempUnits: "imperial",
        roundTemp: true,
        timeFormat: 24,
        onlyTemp: false,
        appendLocationNameToHeader: true,
        showSun: true,
        fade: false,
        fadePoint: 1,
        colored: true,
        updateInterval: 900000,      // 15 minutes, 900 seconds
        maxEntries: 10,
        degreeLabel: true,
        lang: "en",
        locationID: "4724564", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz;
        latitude: 32.98579,
        longitude: -96.60234,
        apiVersion: "3.0",
        weatherEndpoint: "/onecall",
        apikey: "This is a 3.0 key"
                                          I am also confused about the updateInterval value. Previously in this module and in other modules, time intervals are given in milliseconds so 15 minutes is written as 900000.
                                          Thank you for reading.
                                          Butch
                                          Resistance is not Futile!
                                          It is voltage divided by current.
                                            MarcLandis Module Developer @butchkemper
                                            @butchkemper it seems that you are mixing configuration for the standard weather module and configuration for MMM-OpenWeatherForecast
                                            butchkemperB 1 Reply Last reply Reply Quote 0
                                            • 3 / 5
