    MMM-OpenWeatherForecast
    92 Posts 14 Posters 66.6k Views 14 Watching
      Ray @Ray
      @Ray origin https://github.com/jclarke0000/MMM-OpenWeatherForecast.git (fetch)
      origin https://github.com/jclarke0000/MMM-OpenWeatherForecast.git (push)
      ray@ray-VirtualBox:~/MagicMirror/modules/MMM-OpenWeatherForecast$
        sdetweil @Ray
        @Ray yes, that is the original, now some 3 years old
        from the modules list (linked in the header of the forum),
        https://kristjanesperanto.github.io/MagicMirror-3rd-Party-Modules/
        with openweather in the search box
        https://github.com/Tom-Hirschberger/MMM-OpenWeatherForecast
          Ray @sdetweil
          the one that’s installed on my mirror is
          jclarke0000
            sdetweil @Ray
            @Ray i know, that is old, time to migrate to a newer version
              megagprime
              Hi guys, so do we have a definitive fix? I tried new api key, old api key, base url, no base url, still not working.
                sdetweil @megagprime
                  megagprime @sdetweil
                  @sdetweil yes thank you i have done all that, still doesn’t work. Do i need to update the module?
                    @megagprime id let the module set the urlbase
                      @megagprime also note the config parms it uses
                        @sdetweil i did, i commented out the urlbase. All the other config settings are the same that have been working for years.
                        • wishmaster270W
                          wishmaster270 Module Developer @megagprime
                          @megagprime You will need to update to the new fork of the module.
                          It does not matter if the old settings worked for years as the provider shut down the old api and you need to use the new api if you want some information to be displayed again.
                          The original module did not provide a way to change the url the information is fetched of. Even if you add the apiBaseUrl to the settings the old module will ignore it.
                          I released a new version IN MY FORK yesterday which uses the new URL in default. So no need to set the base URL in the settings anymore. The version in my fork before yesterday needed the parameter in the config to work with the new api.
                          So either change to my fork and update with:
                          cd ~/MagicMirror/modules/MMM-OpenWeatherForecast
                          git remote set-url origin https://github.com/Tom-Hirschberger/MMM-OpenWeatherForecast.git
                          git pull
                          rm -rf node_modules package-lock.json
                          npm install
                          Or remove the old module folder and reinstall from this Url:
                          My Fork
                            sdetweil @wishmaster270
                            @wishmaster270 thanks Tom
                            • butchkemperB
                              butchkemper
                              Howdy,
                              I am having trouble getting MMM-OpenWeatherForecast to run and have been working my way through the problems.
                              First problem was a typo of “apiKey” which caused this message to flood the .pm2/logs/MagicMirror-out.log. Problem solved by correctly spelling the variable name “apikey” - notice the subtle difference between the “K” and “k”.
                              [2024-10-03 10:22:54.732] [LOG]   [MMM-OpenWeatherForecast] 3-Oct-24 10:22 ** ERROR ** No API key configured. Get an API key at https://darksky.net
                              Once the “apikey” spelling problem was solved, the next error arrived and the log file was flooded with thousands of this message:
                              code_[2024-10-03 12:09:29.002] [LOG]   [MMM-OpenWeatherForecast] 3-Oct-24 12:09 ** ERROR ** Latitude and/or longitude not provided.
                              This error was caused by confusing documentation that made it appear the variables were “lat” and “lon” instead of “latitude” and “longitude”. Correcting the spelling eliminated the error messages.
                              The current problem is this message which is again flooding the pm2 error.log:
                              [2024-10-03 14:10:02.077] ^[[31m[ERROR]^[[39m ^[[31m[MMM-OpenWeatherForecast] 3-Oct-24 14:10 ** ERROR ** TypeError: fetch failed^[[39m
                              I need a hint of where to look or what to do. I sure it is not hard but just me overlooking something.
                              However,the three problems reveal that the Module contains an error that flood the log files with thousands of messages.
                              Here is the portion configuration file relative to the OpenWeatherForecast module:
                                                      module: "MMM-OpenWeatherForecast",
                                                      header: "Current Weather",
                                                              type: "hourly",
                                                              units: "imperial",
                                                              tempUnits: "imperial",
                                                              roundTemp: true,
                                                              timeFormat: 24,
                                                              onlyTemp: false,
                                                              appendLocationNameToHeader: true,
                                                              showSun: true,
                                                              fade: false,
                                                              fadePoint: 1,
                                                              colored: true,
                                                              updateInterval: 900000,      // 15 minutes, 900 seconds
                                                              maxEntries: 10,
                                                              degreeLabel: true,
                                                              lang: "en",
                                                              locationID: "4724564", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz;
                                                              latitude: 32.98579,
                                                              longitude: -96.60234,
                                                              apiVersion: "3.0",
                                                              weatherEndpoint: "/onecall",
                                                              apikey: "This is a 3.0 key"
                              I am also confused about the updateInterval value. Previously in this module and in other modules, time intervals are given in milliseconds so 15 minutes is written as 900000.
                              Thank you for reading.
                              Butch
                              Resistance is not Futile!
                              It is voltage divided by current.
                                MarcLandis Module Developer @butchkemper
                                @butchkemper it seems that you are mixing configuration for the standard weather module and configuration for MMM-OpenWeatherForecast
                                butchkemperB 1 Reply Last reply Reply Quote 0
                                • butchkemperB
                                  butchkemper @MarcLandis
                                  @MarcLandis Thank you for the push in the right direction. I took the time to remove all the unused options and corrected the updateInterval. Now everything is back to working.
                                  Now I will need to study the new options to see if I need to change anything.
                                  Thanks again.
                                  Butch
                                    Ray
                                    So after getting everything set up with the new version 3.0 at openweathermap.org
                                    I turned on my mirror for the first time this morning and it displayed the weather
                                    and so I went to openweathermap.org just to check how many calls I made it already had me down for 20 calls
                                    am I missing something here
                                      sdetweil @Ray
                                      @Ray how often is the module fetching the weather ?
                                      wishmaster270W R 2 Replies Last reply Reply Quote 0
                                      • wishmaster270W
                                        wishmaster270 Module Developer @sdetweil
                                        @sdetweil In default the module calls the Api every 10 minutes.
                                        S R 2 Replies Last reply Reply Quote 1
                                          @wishmaster270 thanks. i knew i could go look, asking poster to do the same.
                                            Ray @wishmaster270
                                            @wishmaster270 yes I have mine set for 15
                                            but that doesn’t explain why when I turn it on for the first time in the morning they already have 20 calls I don’t get that
                                            • 4 / 5
