    MMM-OpenWeatherForecast
    92 Posts 14 Posters 67.7k Views 14 Watching
      megagprime @sdetweil
      @sdetweil i did, i commented out the urlbase. All the other config settings are the same that have been working for years.
      wishmaster270W 1 Reply Last reply
      • wishmaster270W
        wishmaster270 Module Developer @megagprime
        @megagprime You will need to update to the new fork of the module.
        It does not matter if the old settings worked for years as the provider shut down the old api and you need to use the new api if you want some information to be displayed again.
        The original module did not provide a way to change the url the information is fetched of. Even if you add the apiBaseUrl to the settings the old module will ignore it.
        I released a new version IN MY FORK yesterday which uses the new URL in default. So no need to set the base URL in the settings anymore. The version in my fork before yesterday needed the parameter in the config to work with the new api.
        So either change to my fork and update with:
        cd ~/MagicMirror/modules/MMM-OpenWeatherForecast
        git remote set-url origin https://github.com/Tom-Hirschberger/MMM-OpenWeatherForecast.git
        git pull
        rm -rf node_modules package-lock.json
        npm install
        Or remove the old module folder and reinstall from this Url:
        My Fork
        Reply Quote 2
          sdetweil @wishmaster270
          @wishmaster270 thanks Tom
          • butchkemperB
            butchkemper
            Howdy,
            I am having trouble getting MMM-OpenWeatherForecast to run and have been working my way through the problems.
            First problem was a typo of “apiKey” which caused this message to flood the .pm2/logs/MagicMirror-out.log. Problem solved by correctly spelling the variable name “apikey” - notice the subtle difference between the “K” and “k”.
            [2024-10-03 10:22:54.732] [LOG]   [MMM-OpenWeatherForecast] 3-Oct-24 10:22 ** ERROR ** No API key configured. Get an API key at https://darksky.net
            Once the “apikey” spelling problem was solved, the next error arrived and the log file was flooded with thousands of this message:
            code_[2024-10-03 12:09:29.002] [LOG]   [MMM-OpenWeatherForecast] 3-Oct-24 12:09 ** ERROR ** Latitude and/or longitude not provided.
            This error was caused by confusing documentation that made it appear the variables were “lat” and “lon” instead of “latitude” and “longitude”. Correcting the spelling eliminated the error messages.
            The current problem is this message which is again flooding the pm2 error.log:
            [2024-10-03 14:10:02.077] ^[[31m[ERROR]^[[39m ^[[31m[MMM-OpenWeatherForecast] 3-Oct-24 14:10 ** ERROR ** TypeError: fetch failed^[[39m
            I need a hint of where to look or what to do. I sure it is not hard but just me overlooking something.
            However,the three problems reveal that the Module contains an error that flood the log files with thousands of messages.
            Here is the portion configuration file relative to the OpenWeatherForecast module:
                                    module: "MMM-OpenWeatherForecast",
                                    header: "Current Weather",
                                            type: "hourly",
                                            units: "imperial",
                                            tempUnits: "imperial",
                                            roundTemp: true,
                                            timeFormat: 24,
                                            onlyTemp: false,
                                            appendLocationNameToHeader: true,
                                            showSun: true,
                                            fade: false,
                                            fadePoint: 1,
                                            colored: true,
                                            updateInterval: 900000,      // 15 minutes, 900 seconds
                                            maxEntries: 10,
                                            degreeLabel: true,
                                            lang: "en",
                                            locationID: "4724564", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz;
                                            latitude: 32.98579,
                                            longitude: -96.60234,
                                            apiVersion: "3.0",
                                            weatherEndpoint: "/onecall",
                                            apikey: "This is a 3.0 key"
            I am also confused about the updateInterval value. Previously in this module and in other modules, time intervals are given in milliseconds so 15 minutes is written as 900000.
            Thank you for reading.
            Butch
            Resistance is not Futile!
            It is voltage divided by current.
            M 1 Reply Last reply
              MarcLandis Module Developer @butchkemper
              @butchkemper it seems that you are mixing configuration for the standard weather module and configuration for MMM-OpenWeatherForecast
              butchkemperB 1 Reply Last reply
              • butchkemperB
                butchkemper @MarcLandis
                @MarcLandis Thank you for the push in the right direction. I took the time to remove all the unused options and corrected the updateInterval. Now everything is back to working.
                Now I will need to study the new options to see if I need to change anything.
                Thanks again.
                Butch
                  Ray
                  So after getting everything set up with the new version 3.0 at openweathermap.org
                  I turned on my mirror for the first time this morning and it displayed the weather
                  and so I went to openweathermap.org just to check how many calls I made it already had me down for 20 calls
                  am I missing something here
                    sdetweil @Ray
                    @Ray how often is the module fetching the weather ?
                    wishmaster270W R 2 Replies Last reply
                    • wishmaster270W
                      wishmaster270 Module Developer @sdetweil
                      @sdetweil In default the module calls the Api every 10 minutes.
                      S R 2 Replies Last reply
                        @wishmaster270 thanks. i knew i could go look, asking poster to do the same.
                          Ray @wishmaster270
                          @wishmaster270 yes I have mine set for 15
                          but that doesn’t explain why when I turn it on for the first time in the morning they already have 20 calls I don’t get that
                            Ray @sdetweil
                            @sdetweil I have it set for 15 minutes
                              MarcLandis Module Developer @Ray
                              @Ray said in MMM-OpenWeatherForecast:
                              What means “turn it on”? Boot up the Pi or turn on the screen?
                              R 1 Reply Last reply
                                Ray @MarcLandis
                                @MarcLandis sorry for the misunderstanding there
                                when I activate my mirror and it checks the weather
                                  @Ray updates are still done even the screen is off.
                                    Ray @MarcLandis
                                    @MarcLandis yes I get that and I totally understand that
                                    but that’s not my question maybe it can’t be answered
                                    my magic mirror is on a computer when I boot the computer up in the morning it will automatically start magic mirror usually the first thing it checks is the weather
                                    if I turn the computer off there should be no more calls to the weather app
                                    so my original question would be if I turn my computer on first thing in the morning and I go to the weather app why does it say I already have 20 calls that’s my real question
                                    • wishmaster270W
                                      wishmaster270 Module Developer @Ray
                                      @Ray
                                      Hi, I do not know your set up nor do I know when the “in one day” changes to the next day at OpenWeaterMap.
                                      I use the API Key exactly in this module and only have one instance of the mirror running…
                                      I just checked my statistics at OpenWeaterMap and I do have at about 112 calls a day. Which is correct as my mirror is shutdown between 11:30pm and 5am.
                                      Maybe it is a matter of your timezone and calls of the last day are counted in the current one.
                                      What does your statistic look like
                                      https://home.openweathermap.org/statistics/onecall_30
                                      Edit:
                                      And one small side note. Even if you use different keys the calls a summarized per account
                                        Ray @wishmaster270
                                        @wishmaster270
                                        I totally agree with everything you said I do have two keys but I only use one
                                        the only thing I can think of is maybe the 20 calls are a carryover from the previous day that’s the only thing I can think of
                                        I shut down my mirror around 7 o’clock at night
                                        and when I started up in the morning around 8 o’clock in the morning I would think there would only be one call
                                        but when I looked it said there were 20
                                        so like I said maybe it’s a carryover from the previous day
                                        so tomorrow morning I’m going to conduct a test
                                        I will check the website first to see if there any calls there before I start my mirror
                                        if you want I will let you know
                                          Ray @wishmaster270
                                          @wishmaster270
                                          so I found out what was going on with the calls being counted when my magic mirror wasn’t even up and running
                                          so here’s what I found out
                                          I have MMM-OpenWeatherForecast checking the temperature in two time zones
                                          and one of the time zone I have set requestDelay: 250
                                          this was done before the upgrade to 3.0 call abb
                                          since then I have deleted one of the time zones
                                          but forgot to delete requestDelay: 250 an error in my part
                                          it turns out that the One Call API 3.0 was counting all the calls in that 250
                                          in version 2.5 we didn’t have to worry about that
                                            sdetweil @Ray
                                            @Ray yes, a call is a call. 250 is WAY TOO OFTEN for weather that doesn’t changed but every 10-15 minutes
                                            • 4 / 5
