    MMM-OpenWeatherForecast
    92 Posts 14 Posters 68.0k Views 14 Watching
      sdetweil @Ray
      @Ray i know, that is old, time to migrate to a newer version
        megagprime
        Hi guys, so do we have a definitive fix? I tried new api key, old api key, base url, no base url, still not working.
          sdetweil @megagprime
          M 1 Reply Last reply
            megagprime @sdetweil
            @sdetweil yes thank you i have done all that, still doesn’t work. Do i need to update the module?
            S 2 Replies Last reply
              @megagprime id let the module set the urlbase
                @megagprime also note the config parms it uses
                  @sdetweil i did, i commented out the urlbase. All the other config settings are the same that have been working for years.
                  wishmaster270W 1 Reply Last reply
                  • wishmaster270W
                    wishmaster270 Module Developer @megagprime
                    @megagprime You will need to update to the new fork of the module.
                    It does not matter if the old settings worked for years as the provider shut down the old api and you need to use the new api if you want some information to be displayed again.
                    The original module did not provide a way to change the url the information is fetched of. Even if you add the apiBaseUrl to the settings the old module will ignore it.
                    I released a new version IN MY FORK yesterday which uses the new URL in default. So no need to set the base URL in the settings anymore. The version in my fork before yesterday needed the parameter in the config to work with the new api.
                    So either change to my fork and update with:
                    cd ~/MagicMirror/modules/MMM-OpenWeatherForecast
                    git remote set-url origin https://github.com/Tom-Hirschberger/MMM-OpenWeatherForecast.git
                    git pull
                    rm -rf node_modules package-lock.json
                    npm install
                    Or remove the old module folder and reinstall from this Url:
                    My Fork
                    Reply Quote 2
                      sdetweil @wishmaster270
                      @wishmaster270 thanks Tom
                      • butchkemperB
                        butchkemper
                        Howdy,
                        I am having trouble getting MMM-OpenWeatherForecast to run and have been working my way through the problems.
                        First problem was a typo of “apiKey” which caused this message to flood the .pm2/logs/MagicMirror-out.log. Problem solved by correctly spelling the variable name “apikey” - notice the subtle difference between the “K” and “k”.
                        [2024-10-03 10:22:54.732] [LOG]   [MMM-OpenWeatherForecast] 3-Oct-24 10:22 ** ERROR ** No API key configured. Get an API key at https://darksky.net
                        Once the “apikey” spelling problem was solved, the next error arrived and the log file was flooded with thousands of this message:
                        code_[2024-10-03 12:09:29.002] [LOG]   [MMM-OpenWeatherForecast] 3-Oct-24 12:09 ** ERROR ** Latitude and/or longitude not provided.
                        This error was caused by confusing documentation that made it appear the variables were “lat” and “lon” instead of “latitude” and “longitude”. Correcting the spelling eliminated the error messages.
                        The current problem is this message which is again flooding the pm2 error.log:
                        [2024-10-03 14:10:02.077] ^[[31m[ERROR]^[[39m ^[[31m[MMM-OpenWeatherForecast] 3-Oct-24 14:10 ** ERROR ** TypeError: fetch failed^[[39m
                        I need a hint of where to look or what to do. I sure it is not hard but just me overlooking something.
                        However,the three problems reveal that the Module contains an error that flood the log files with thousands of messages.
                        Here is the portion configuration file relative to the OpenWeatherForecast module:
                                                module: "MMM-OpenWeatherForecast",
                                                header: "Current Weather",
                                                        type: "hourly",
                                                        units: "imperial",
                                                        tempUnits: "imperial",
                                                        roundTemp: true,
                                                        timeFormat: 24,
                                                        onlyTemp: false,
                                                        appendLocationNameToHeader: true,
                                                        showSun: true,
                                                        fade: false,
                                                        fadePoint: 1,
                                                        colored: true,
                                                        updateInterval: 900000,      // 15 minutes, 900 seconds
                                                        maxEntries: 10,
                                                        degreeLabel: true,
                                                        lang: "en",
                                                        locationID: "4724564", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz;
                                                        latitude: 32.98579,
                                                        longitude: -96.60234,
                                                        apiVersion: "3.0",
                                                        weatherEndpoint: "/onecall",
                                                        apikey: "This is a 3.0 key"
                        I am also confused about the updateInterval value. Previously in this module and in other modules, time intervals are given in milliseconds so 15 minutes is written as 900000.
                        Thank you for reading.
                        Butch
                        Resistance is not Futile!
                        It is voltage divided by current.
                          MarcLandis Module Developer @butchkemper
                          @butchkemper it seems that you are mixing configuration for the standard weather module and configuration for MMM-OpenWeatherForecast
                          butchkemperB 1 Reply Last reply
                          • butchkemperB
                            butchkemper @MarcLandis
                            @MarcLandis Thank you for the push in the right direction. I took the time to remove all the unused options and corrected the updateInterval. Now everything is back to working.
                            Now I will need to study the new options to see if I need to change anything.
                            Thanks again.
                            Butch
                              Ray
                              So after getting everything set up with the new version 3.0 at openweathermap.org
                              I turned on my mirror for the first time this morning and it displayed the weather
                              and so I went to openweathermap.org just to check how many calls I made it already had me down for 20 calls
                              am I missing something here
                                sdetweil @Ray
                                @Ray how often is the module fetching the weather ?
                                wishmaster270W R 2 Replies Last reply
                                • wishmaster270W
                                  wishmaster270 Module Developer @sdetweil
                                  @sdetweil In default the module calls the Api every 10 minutes.
                                  S R 2 Replies Last reply
                                    @wishmaster270 thanks. i knew i could go look, asking poster to do the same.
                                      Ray @wishmaster270
                                      @wishmaster270 yes I have mine set for 15
                                      but that doesn’t explain why when I turn it on for the first time in the morning they already have 20 calls I don’t get that
                                        Ray @sdetweil
                                        @sdetweil I have it set for 15 minutes
                                          MarcLandis Module Developer @Ray
                                          @Ray said in MMM-OpenWeatherForecast:
                                          What means “turn it on”? Boot up the Pi or turn on the screen?
                                          R 1 Reply Last reply
                                            Ray @MarcLandis
                                            @MarcLandis sorry for the misunderstanding there
                                            when I activate my mirror and it checks the weather
                                            • 4 / 5
