    MMM-OpenWeatherForecast
    92 Posts 14 Posters 66.6k Views 14 Watching
      megagprime
      Hi guys, so do we have a definitive fix? I tried new api key, old api key, base url, no base url, still not working.
        sdetweil @megagprime
          megagprime @sdetweil
          @sdetweil yes thank you i have done all that, still doesn’t work. Do i need to update the module?
            @megagprime id let the module set the urlbase
              @megagprime also note the config parms it uses
                @sdetweil i did, i commented out the urlbase. All the other config settings are the same that have been working for years.
                • wishmaster270W
                  wishmaster270 Module Developer @megagprime
                  @megagprime You will need to update to the new fork of the module.
                  It does not matter if the old settings worked for years as the provider shut down the old api and you need to use the new api if you want some information to be displayed again.
                  The original module did not provide a way to change the url the information is fetched of. Even if you add the apiBaseUrl to the settings the old module will ignore it.
                  I released a new version IN MY FORK yesterday which uses the new URL in default. So no need to set the base URL in the settings anymore. The version in my fork before yesterday needed the parameter in the config to work with the new api.
                  So either change to my fork and update with:
                  cd ~/MagicMirror/modules/MMM-OpenWeatherForecast
                  git remote set-url origin https://github.com/Tom-Hirschberger/MMM-OpenWeatherForecast.git
                  git pull
                  rm -rf node_modules package-lock.json
                  npm install
                  Or remove the old module folder and reinstall from this Url:
                  My Fork
                    sdetweil @wishmaster270
                    @wishmaster270 thanks Tom
                    • butchkemperB
                      butchkemper
                      Howdy,
                      I am having trouble getting MMM-OpenWeatherForecast to run and have been working my way through the problems.
                      First problem was a typo of “apiKey” which caused this message to flood the .pm2/logs/MagicMirror-out.log. Problem solved by correctly spelling the variable name “apikey” - notice the subtle difference between the “K” and “k”.
                      [2024-10-03 10:22:54.732] [LOG]   [MMM-OpenWeatherForecast] 3-Oct-24 10:22 ** ERROR ** No API key configured. Get an API key at https://darksky.net
                      Once the “apikey” spelling problem was solved, the next error arrived and the log file was flooded with thousands of this message:
                      code_[2024-10-03 12:09:29.002] [LOG]   [MMM-OpenWeatherForecast] 3-Oct-24 12:09 ** ERROR ** Latitude and/or longitude not provided.
                      This error was caused by confusing documentation that made it appear the variables were “lat” and “lon” instead of “latitude” and “longitude”. Correcting the spelling eliminated the error messages.
                      The current problem is this message which is again flooding the pm2 error.log:
                      [2024-10-03 14:10:02.077] ^[[31m[ERROR]^[[39m ^[[31m[MMM-OpenWeatherForecast] 3-Oct-24 14:10 ** ERROR ** TypeError: fetch failed^[[39m
                      I need a hint of where to look or what to do. I sure it is not hard but just me overlooking something.
                      However,the three problems reveal that the Module contains an error that flood the log files with thousands of messages.
                      Here is the portion configuration file relative to the OpenWeatherForecast module:
                                              module: "MMM-OpenWeatherForecast",
                                              header: "Current Weather",
                                                      type: "hourly",
                                                      units: "imperial",
                                                      tempUnits: "imperial",
                                                      roundTemp: true,
                                                      timeFormat: 24,
                                                      onlyTemp: false,
                                                      appendLocationNameToHeader: true,
                                                      showSun: true,
                                                      fade: false,
                                                      fadePoint: 1,
                                                      colored: true,
                                                      updateInterval: 900000,      // 15 minutes, 900 seconds
                                                      maxEntries: 10,
                                                      degreeLabel: true,
                                                      lang: "en",
                                                      locationID: "4724564", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz;
                                                      latitude: 32.98579,
                                                      longitude: -96.60234,
                                                      apiVersion: "3.0",
                                                      weatherEndpoint: "/onecall",
                                                      apikey: "This is a 3.0 key"
                      I am also confused about the updateInterval value. Previously in this module and in other modules, time intervals are given in milliseconds so 15 minutes is written as 900000.
                      Thank you for reading.
                      Butch
                      Resistance is not Futile!
                      It is voltage divided by current.
                        MarcLandis Module Developer @butchkemper
                        @butchkemper it seems that you are mixing configuration for the standard weather module and configuration for MMM-OpenWeatherForecast
                        butchkemperB 1 Reply Last reply Reply Quote 0
                        • butchkemperB
                          butchkemper @MarcLandis
                          @MarcLandis Thank you for the push in the right direction. I took the time to remove all the unused options and corrected the updateInterval. Now everything is back to working.
                          Now I will need to study the new options to see if I need to change anything.
                          Thanks again.
                          Butch
                            Ray
                            So after getting everything set up with the new version 3.0 at openweathermap.org
                            I turned on my mirror for the first time this morning and it displayed the weather
                            and so I went to openweathermap.org just to check how many calls I made it already had me down for 20 calls
                            am I missing something here
                              sdetweil @Ray
                              @Ray how often is the module fetching the weather ?
                              wishmaster270W R 2 Replies Last reply Reply Quote 0
                              • wishmaster270W
                                wishmaster270 Module Developer @sdetweil
                                @sdetweil In default the module calls the Api every 10 minutes.
                                S R 2 Replies Last reply Reply Quote 1
                                  @wishmaster270 thanks. i knew i could go look, asking poster to do the same.
                                    Ray @wishmaster270
                                    @wishmaster270 yes I have mine set for 15
                                    but that doesn’t explain why when I turn it on for the first time in the morning they already have 20 calls I don’t get that
                                      Ray @sdetweil
                                      @sdetweil I have it set for 15 minutes
                                        MarcLandis Module Developer @Ray
                                        @Ray said in MMM-OpenWeatherForecast:
                                        What means “turn it on”? Boot up the Pi or turn on the screen?
                                          Ray @MarcLandis
                                          @MarcLandis sorry for the misunderstanding there
                                          when I activate my mirror and it checks the weather
                                            @Ray updates are still done even the screen is off.
                                            • 4 / 5
