    v2.29.0 weather module issue
    21 Posts 8 Posters 11.1k Views 8 Watching
      sdetweil @dawookie1979
      @dawookie1979 see the documentation. its a property in the config section of the weather module configuration
      documentation is linked from the top menu here
        Andreas1956 @MarcLandis
        @MarcLandis
        i only added
        apiVersion: “2.5”,
        to my config, now its all fine again.
          sdetweil @Andreas1956
          @Andreas1956 tgat means you gave the old apikey, which will fail ‘soon’
            Peter @sdetweil
            @sdetweil Sam, do you know how many calls the default weather module makes per day?
            Am I right: default is every 10 minutes, so 24x6 per day?
            I have two Magic mirrors (1 for me and 1 for my daughter) using the same API.
            I would like to use the API (3.0) for free, so use not more than 1000 calls per day.
            Thanks for your answer in advance.
            Peter
              reilley @dawookie1979
              @dawookie1979 - just add it somewhere in the config for your weather module. I added "apiVersion: “3.0"” just above the apiKey.
              I’d help you write yours, but I’m struggling with mine as well so you might get better assistance from the gurus here!
              • H Offline
                HeikoGr @kent79
                @kent79 @dawookie1979
                it’s all in the docs - but you need to read it carefully.
                in short: forecast needs
                • lat/lon , locationID isn’t working for forecast
                • weatherEndpoint: ‘/onecall’, must be set
                This works for me;
                            disabled: false,
                            module: "weather",
                            config:
                                weatherProvider: 'openweathermap',
                                weatherEndpoint: '/onecall',
                                apiKey: 'xxx',
                                apiVersion: '3.0',
                                lat: '49.8',
                                lon: '8.49',
                                type: 'forecast',
                                colored: true,
                                fade: false,
                                maxNumberOfDays: 3,
                                degreeLabel: 'true',
                                showWindDirectionAsArrow: 'true',
                                decimalSymbol: ','
                R S 2 Replies Last reply Reply Quote 0
                  reilley @HeikoGr
                  @HeikoGr - What are you seeing for the header? Does it say [country]/[city] and if so, is it correct? Mine is saying “America/New York”, when I’m in Canton, Georgia.
                    sdetweil @Peter
                    @Peter yes, every 10 minutes, 6 times per hour
                      sdetweil @HeikoGr
                      @HeikoGr is that gepos right?
                      i am in texas and my lat is 30
                      • H Offline
                        HeikoGr @sdetweil
                        @sdetweil yes, lat/lon is correct as I am in Germany :-D
                        @reilley unfortunately openweather doesnt respond with geoname but with timeszone… so it’s euroe/berlin in my case.
                        • K Offline
                          kent79 @reilley
                          @reilley
                          It works. Thank you
