    v2.29.0 weather module issue
    21 Posts 8 Posters 10.6k Views 8 Watching
      reilley @dawookie1979
      @dawookie1979 - Be sure to add apiVersion: ‘3.0’ to your config
      D K 2 Replies Last reply Reply Quote 0
        dawookie1979 @reilley
        @reilley Hello, where do i add it? can you help me edit my script?
        S R 2 Replies Last reply Reply Quote 0
          sdetweil @dawookie1979
          @dawookie1979 see the documentation. its a property in the config section of the weather module configuration
          documentation is linked from the top menu here
            Andreas1956 @MarcLandis
            @MarcLandis
            i only added
            apiVersion: “2.5”,
            to my config, now its all fine again.
              sdetweil @Andreas1956
              @Andreas1956 tgat means you gave the old apikey, which will fail ‘soon’
                Peter @sdetweil
                @sdetweil Sam, do you know how many calls the default weather module makes per day?
                Am I right: default is every 10 minutes, so 24x6 per day?
                I have two Magic mirrors (1 for me and 1 for my daughter) using the same API.
                I would like to use the API (3.0) for free, so use not more than 1000 calls per day.
                Thanks for your answer in advance.
                Peter
                  @dawookie1979 - just add it somewhere in the config for your weather module. I added "apiVersion: “3.0"” just above the apiKey.
                  I’d help you write yours, but I’m struggling with mine as well so you might get better assistance from the gurus here!
                  • H Offline
                    HeikoGr @kent79
                    @kent79 @dawookie1979
                    it’s all in the docs - but you need to read it carefully.
                    in short: forecast needs
                    • lat/lon , locationID isn’t working for forecast
                    • weatherEndpoint: ‘/onecall’, must be set
                    This works for me;
                                disabled: false,
                                module: "weather",
                                config:
                                    weatherProvider: 'openweathermap',
                                    weatherEndpoint: '/onecall',
                                    apiKey: 'xxx',
                                    apiVersion: '3.0',
                                    lat: '49.8',
                                    lon: '8.49',
                                    type: 'forecast',
                                    colored: true,
                                    fade: false,
                                    maxNumberOfDays: 3,
                                    degreeLabel: 'true',
                                    showWindDirectionAsArrow: 'true',
                                    decimalSymbol: ','
                    R S 2 Replies Last reply Reply Quote 0
                      reilley @HeikoGr
                      @HeikoGr - What are you seeing for the header? Does it say [country]/[city] and if so, is it correct? Mine is saying “America/New York”, when I’m in Canton, Georgia.
                        sdetweil @Peter
                        @Peter yes, every 10 minutes, 6 times per hour
                          sdetweil @HeikoGr
                          @HeikoGr is that gepos right?
                          i am in texas and my lat is 30
                          • H Offline
                            HeikoGr @sdetweil
                            @sdetweil yes, lat/lon is correct as I am in Germany :-D
                            @reilley unfortunately openweather doesnt respond with geoname but with timeszone… so it’s euroe/berlin in my case.
                            • K Offline
                              kent79 @reilley
                              @reilley
                              It works. Thank you
