v2.29.0 weather module issue
21 Posts 8 Posters 3.5k Views 8 Watching
  • K Offline
    kent79
    I just update to v2.29.0, but find out the weather module doesn’t work (MagicMirror\modules\default\weather). It can’t show the information.
    I used the old module to replace. It works again. So it must be weather module issue. Please fix it. Thanks.
    Below is my config
                    			module: "weather",
                    				type: "current",
                    				locationID: "1",
                    				apiKey: "1",
                    				showSun: false,
                    				showHumidity: "wind",
                    			module: "weather",
                    			header: "weather",
                    				type: "forecast",
                    				locationID: "1",
                    				apiKey: "1",
                    				colored: true,
    M 1 Reply Last reply Oct 1, 2024, 1:30 PM Reply Quote 0
      MarcLandis @kent79
      @kent79 Did you get a new V3 API key at openweathermap.com? Old V2.5 keys won’t work anymore.
      K A 2 Replies Last reply Oct 1, 2024, 2:03 PM Reply Quote 0
      • K Offline
        kent79 @MarcLandis
        @MarcLandis
        V3 submittion need to provide a credit information. It is bad idea. Well, I will keep using 2.5 api key and 2.28 old weather module in this moment.
        I wish MM can revert it later since version 2.5 is totally free. Thanks.
        M 1 Reply Last reply Oct 1, 2024, 2:08 PM Reply Quote 0
          MarcLandis @kent79
          @kent79 from openweathermap.com:
          "Dear OpenWeather user,
          We would like to inform you about our plans to complete the migration from One Call 2.5 to One Call 3.0 that started 2 years ago. In line with this, access to One Call 2.5 will be finally closed in June 2024.
          One Call 3.0 provides you with significantly advanced business-demanded features such as a minute forecast for 1 hour, 4 days forecast for any timestamp, a daily forecast for 8 days, including a human-readable summary, historical data (45-year archive) for timestamps, and with daily aggregation, 1.5-year long-term forecast with daily aggregation, and others."
          So V2.5 is only working because openwaethermap didn’t fully shut it down even the deadline is over. It can happen any day.
          K 1 Reply Last reply Oct 1, 2024, 2:21 PM Reply Quote 0
          • K Offline
            kent79 @MarcLandis
            @MarcLandis
            I see. Thank you for your quick reply. Any free API is available now? I will move
            M 1 Reply Last reply Oct 1, 2024, 2:25 PM Reply Quote 0
              MarcLandis @kent79
              @kent79 V3 is free for 1000 calls a day and unless you update the weather every minute you probably won’t reach that limit.
              K 1 Reply Last reply Oct 1, 2024, 2:38 PM Reply Quote 0
              • K Offline
                kent79 @MarcLandis
                @MarcLandis
                Thank you for information
                H 1 Reply Last reply Oct 2, 2024, 7:44 PM Reply Quote 0
                  dawookie1979
                  i have same issue. I have signed up for the v3 api. Does anyone have a config for me to copy my api into?
                  my code:
                  module: “weather”,
                  position: “top_left”,
                  header: “Weather Forecast”,
                  weatherProvider: “openweathermap”,
                  type: “forecast”,
                  locationID: “2647310”, //
                  apiKey: “LEFT BLANK”
                  R 1 Reply Last reply Oct 2, 2024, 12:41 AM Reply Quote 0
                    reilley @dawookie1979
                    @dawookie1979 - Be sure to add apiVersion: ‘3.0’ to your config
                    D K 2 Replies Last reply Oct 2, 2024, 8:33 AM Reply Quote 0
                      dawookie1979 @reilley
                      @reilley Hello, where do i add it? can you help me edit my script?
                      S R 2 Replies Last reply Oct 2, 2024, 11:16 AM Reply Quote 0
                      1 / 3
