    v2.29.0 weather module issue
    21 Posts 8 Posters 10.6k Views 8 Watching
    • K Offline
      kent79
      I just update to v2.29.0, but find out the weather module doesn’t work (MagicMirror\modules\default\weather). It can’t show the information.
      I used the old module to replace. It works again. So it must be weather module issue. Please fix it. Thanks.
      Below is my config
                      			module: "weather",
                      				type: "current",
                      				locationID: "1",
                      				apiKey: "1",
                      				showSun: false,
                      				showHumidity: "wind",
                      			module: "weather",
                      			header: "weather",
                      				type: "forecast",
                      				locationID: "1",
                      				apiKey: "1",
                      				colored: true,
        MarcLandis Module Developer @kent79
        @kent79 Did you get a new V3 API key at openweathermap.com? Old V2.5 keys won’t work anymore.
        K A 2 Replies Last reply Reply Quote 0
        • K Offline
          kent79 @MarcLandis
          @MarcLandis
          V3 submittion need to provide a credit information. It is bad idea. Well, I will keep using 2.5 api key and 2.28 old weather module in this moment.
          I wish MM can revert it later since version 2.5 is totally free. Thanks.
            @kent79 from openweathermap.com:
            "Dear OpenWeather user,
            We would like to inform you about our plans to complete the migration from One Call 2.5 to One Call 3.0 that started 2 years ago. In line with this, access to One Call 2.5 will be finally closed in June 2024.
            One Call 3.0 provides you with significantly advanced business-demanded features such as a minute forecast for 1 hour, 4 days forecast for any timestamp, a daily forecast for 8 days, including a human-readable summary, historical data (45-year archive) for timestamps, and with daily aggregation, 1.5-year long-term forecast with daily aggregation, and others."
            So V2.5 is only working because openwaethermap didn’t fully shut it down even the deadline is over. It can happen any day.
            • K Offline
              kent79 @MarcLandis
              @MarcLandis
              I see. Thank you for your quick reply. Any free API is available now? I will move
                @kent79 V3 is free for 1000 calls a day and unless you update the weather every minute you probably won’t reach that limit.
                • K Offline
                  kent79 @MarcLandis
                  @MarcLandis
                  Thank you for information
                    dawookie1979
                    i have same issue. I have signed up for the v3 api. Does anyone have a config for me to copy my api into?
                    my code:
                    module: “weather”,
                    position: “top_left”,
                    header: “Weather Forecast”,
                    weatherProvider: “openweathermap”,
                    type: “forecast”,
                    locationID: “2647310”, //
                    apiKey: “LEFT BLANK”
                      reilley @dawookie1979
                      @dawookie1979 - Be sure to add apiVersion: ‘3.0’ to your config
                      D K 2 Replies Last reply Reply Quote 0
                        dawookie1979 @reilley
                        @reilley Hello, where do i add it? can you help me edit my script?
                        S R 2 Replies Last reply Reply Quote 0
                          sdetweil @dawookie1979
                          @dawookie1979 see the documentation. its a property in the config section of the weather module configuration
                          documentation is linked from the top menu here
                            Andreas1956 @MarcLandis
                            @MarcLandis
                            i only added
                            apiVersion: “2.5”,
                            to my config, now its all fine again.
                              sdetweil @Andreas1956
                              @Andreas1956 tgat means you gave the old apikey, which will fail ‘soon’
                                Peter @sdetweil
                                @sdetweil Sam, do you know how many calls the default weather module makes per day?
                                Am I right: default is every 10 minutes, so 24x6 per day?
                                I have two Magic mirrors (1 for me and 1 for my daughter) using the same API.
                                I would like to use the API (3.0) for free, so use not more than 1000 calls per day.
                                Thanks for your answer in advance.
                                Peter
                                  @dawookie1979 - just add it somewhere in the config for your weather module. I added "apiVersion: “3.0"” just above the apiKey.
                                  I’d help you write yours, but I’m struggling with mine as well so you might get better assistance from the gurus here!
                                  • H Offline
                                    HeikoGr @kent79
                                    @kent79 @dawookie1979
                                    it’s all in the docs - but you need to read it carefully.
                                    in short: forecast needs
                                    • lat/lon , locationID isn’t working for forecast
                                    • weatherEndpoint: ‘/onecall’, must be set
                                    This works for me;
                                                disabled: false,
                                                module: "weather",
                                                config:
                                                    weatherProvider: 'openweathermap',
                                                    weatherEndpoint: '/onecall',
                                                    apiKey: 'xxx',
                                                    apiVersion: '3.0',
                                                    lat: '49.8',
                                                    lon: '8.49',
                                                    type: 'forecast',
                                                    colored: true,
                                                    fade: false,
                                                    maxNumberOfDays: 3,
                                                    degreeLabel: 'true',
                                                    showWindDirectionAsArrow: 'true',
                                                    decimalSymbol: ','
                                    R S 2 Replies Last reply Reply Quote 0
                                      reilley @HeikoGr
                                      @HeikoGr - What are you seeing for the header? Does it say [country]/[city] and if so, is it correct? Mine is saying “America/New York”, when I’m in Canton, Georgia.
                                        sdetweil @Peter
                                        @Peter yes, every 10 minutes, 6 times per hour
                                          sdetweil @HeikoGr
                                          @HeikoGr is that gepos right?
                                          i am in texas and my lat is 30
                                          • H Offline
                                            HeikoGr @sdetweil
                                            @sdetweil yes, lat/lon is correct as I am in Germany :-D
                                            @reilley unfortunately openweather doesnt respond with geoname but with timeszone… so it’s euroe/berlin in my case.
