    MMM-MovieListings
    28 Posts 4 Posters 10.0k Views 4 Watching
    • BerkSmash1984B Offline
      BerkSmash1984 @mumblebaj
      @mumblebaj Thanks for creating this fork! I cannot seem to get the module to work, however. Here is what I am seeing in the dev console:
      Here is my config:
      Any ideas? I am using the API Read Access Token instead of the API Key from TMBD, as required per your GitHub.
      mumblebajM KristjanESPERANTOK 3 Replies Last reply Reply Quote 0
      • mumblebajM Offline
        mumblebaj Module Developer @BerkSmash1984
        @BerkSmash1984 Hi. I have just cloned the module and tested with your config and it is working fine for me. Are you on the latest version of the module? Can you do a git status in the module folder and let me know if it says Your branch is up to date with 'origin/master'.
        BerkSmash1984B 1 Reply Last reply Reply Quote 0
          @BerkSmash1984 Hi. I have just done a fresh clone of the module and tested it. It is working fine with your config. The error seems to indicate that the first call failed, this is the one that fetches the latest 20 movies. Can you do a git status in the module folder and see if you get Your branch is up to date with 'origin/master'.?
          • KristjanESPERANTOK Offline
            KristjanESPERANTO Module Developer @BerkSmash1984
            @BerkSmash1984 said in MMM-MovieListings:
            Just an idea: Which node version are you using?
              @mumblebaj Thanks for the response and sorry for the delay on my side.
              I am in fact using the latest version:
                BerkSmash1984 @KristjanESPERANTO
                @KristjanESPERANTO I am on v.20.18.0
                  @BerkSmash1984 Which version of MM are you running?
                  MM requires a minimum version of 20.9.xx. Yours is currently lower.
                  ⚠️ This release needs nodejs version v20 or v22, minimum version is v20.9.0.
                    @mumblebaj I am on v2.25.0, not the latest, but the one before the latest, I think.
                    All other modules are working great.
                    I can update to the latest, just don’t want any modules to break. I have 10 unique pages showing multiple modules
                    mumblebajM S 2 Replies Last reply Reply Quote 0
                      @BerkSmash1984 And which node version? You can run node -v
                        @mumblebaj
                        v20.18.0
                        mumblebajM BerkSmash1984B 2 Replies Last reply Reply Quote 0
