    MMM-MovieListings
    28 Posts 4 Posters 14.5k Views 4 Watching
    • mumblebajM
      mumblebaj Module Developer
      I have been looking for a module that displays latest movie releases etc and saw MMM-MovieListings from @Tueti which was last updated 7 years ago and not working. I decided to revive this module and pull it into the here and now.
      Updates to original Module:
      Original module can be found here.
      I have submitted a PR but do not know if the owner will accept as the module was last updated 7 years ago.
      My fork can be found here
      Some screenshots:
      BerkSmash1984B mumblebajM 2 Replies Last reply
      Reply Quote 2
      • BerkSmash1984B
        BerkSmash1984 @mumblebaj
        @mumblebaj Thanks for creating this fork! I cannot seem to get the module to work, however. Here is what I am seeing in the dev console:
        Here is my config:
        Any ideas? I am using the API Read Access Token instead of the API Key from TMBD, as required per your GitHub.
        mumblebajM KristjanESPERANTOK 3 Replies Last reply
        • mumblebajM
          mumblebaj Module Developer @BerkSmash1984
          @BerkSmash1984 Hi. I have just cloned the module and tested with your config and it is working fine for me. Are you on the latest version of the module? Can you do a git status in the module folder and let me know if it says Your branch is up to date with 'origin/master'.
          BerkSmash1984B 1 Reply Last reply
          • mumblebajM
            @BerkSmash1984 Hi. I have just done a fresh clone of the module and tested it. It is working fine with your config. The error seems to indicate that the first call failed, this is the one that fetches the latest 20 movies. Can you do a git status in the module folder and see if you get Your branch is up to date with 'origin/master'.?
            • KristjanESPERANTOK
              KristjanESPERANTO Module Developer @BerkSmash1984
              @BerkSmash1984 said in MMM-MovieListings:
              Just an idea: Which node version are you using?
              • BerkSmash1984B
                @mumblebaj Thanks for the response and sorry for the delay on my side.
                I am in fact using the latest version:
                • BerkSmash1984B
                  BerkSmash1984 @KristjanESPERANTO
                  @KristjanESPERANTO I am on v.20.18.0
                  mumblebajM 1 Reply Last reply
                  • mumblebajM
                    @BerkSmash1984 Which version of MM are you running?
                    MM requires a minimum version of 20.9.xx. Yours is currently lower.
                    ⚠️ This release needs nodejs version v20 or v22, minimum version is v20.9.0.
                    • BerkSmash1984B
                      @mumblebaj I am on v2.25.0, not the latest, but the one before the latest, I think.
                      All other modules are working great.
                      I can update to the latest, just don’t want any modules to break. I have 10 unique pages showing multiple modules
                      mumblebajM S 2 Replies Last reply
                      • mumblebajM
                        @BerkSmash1984 And which node version? You can run node -v
                        • BerkSmash1984B
                          @mumblebaj
                          v20.18.0
                          mumblebajM BerkSmash1984B 2 Replies Last reply
                          • mumblebajM
                            @BerkSmash1984 I am not sure what updating node would do to your 2.25.0 version of MM. I assume it should be fine. I updated the module using node 20.9.0. I unfortunately do not have an older version of MM running. My dev machine runs the latest version.
                            @sdetweil Would MM v2.25.0 run fine with node 20.9.0? I am hoping you may have the answer at hand.
                            • BerkSmash1984B
                              @mumblebaj
                              I am assuming @sdetweil’s MM update script will also update node? I am happy to give that a go if so. I can easily make a backup for my MM to my local machine just in case.
                              • BerkSmash1984B
                                BerkSmash1984 @BerkSmash1984
                                @BerkSmash1984 updated to latest MM version via @sdetweil upgrade script but looks like it did not touch the Node version. All modules function post update with the exception of the of the MMM-MovieListings module.
                                Also, it states a Node update is not necessary:
                                S mumblebajM 2 Replies Last reply
                                  sdetweil @BerkSmash1984
                                  use my backup/restore scripts
                                  and install/upgrade scripts
                                    @BerkSmash1984 when u start mm, npm start
                                    we added messages that dump the runtime env
                                    from my linux system
                                    [2024-10-07 13:14:07.805] [INFO]  System information:
                                    ### SYSTEM:   manufacturer: System manufacturer; model: System Product Name; virtual: false
                                    ### OS:       platform: linux; distro: Ubuntu; release: 22.04.4 LTS; arch: x64; kernel: 5.15.0-122-generic
                                    ### VERSIONS: electron: 31.6.0; used node: 20.17.0; installed node: 22.9.0; npm: 10.8.3; pm2: 5.4.2
                                    ### OTHER:    timeZone: America/Los_Angeles; ELECTRON_ENABLE_GPU: undefined
                                    • BerkSmash1984B
                                      BerkSmash1984 @sdetweil
                                      @sdetweil said in MMM-MovieListings:
                                      Here is what mine shows:
                                      Do you think it is worth updating to Node 22.9.0? What is the safest way to do so?
                                        @BerkSmash1984 no. not worth it
                                        • mumblebajM
                                          @BerkSmash1984 I would give node 20.9.0 a go.
                                          • BerkSmash1984B
                                            @mumblebaj
                                            Just hesitant that the update will break other modules my MM is using. Sounds like Node updates could be more hassle than they are worth if your MM is functioning, minus a model or 2 ;)
                                            What is the safest way to update Node to 20.9.0? Node Version Manager?
