    MMM-Globe
    118 Posts 32 Posters 189.7k Views 37 Watching
      sdetweil @damith
      @damith did u do the npm install in the module folder after git clone?
      if u look at the startup messages, where u start mm
      npm start
      or pm2 logs --lines=100
      you might see a message, module not found.
      this is the number 1 clue you didn’t do the npm install
        damith @sdetweil
        hi @sdetweil
        Thank you very much for your reply… you are the NUMBER ONE… it works fine… Thanks again.
        i have done NPM INSTALL… its worked fine…:face_savoring_food: :face_savoring_food:
          damith
          hi guys… my GLOBE is woking fine… but there is a problem with City NAMES, i won’t display…, config is ok… can anyone help me …?
          module: ‘MMM-Globe’,
          position: ‘lower_third’, // This can be any of the regions. Best results in lower_third
          size:“x-large”, // Globe size. See configuration options below for more options
          dayLength: 38, // (Optional) Rotation speed. See configuration options below
          viewAngle: 15, // (Optional) Globe tilt. See configuration options below.
          introLinesDuration: 2000,
          receiveExternalLocations: 0,
          locations: [
          // Fill with location Objects if desired
          // e.g.
          {lat:37.77493,lng:-122.41942, label:“San Francisco”},
          {lat:7.58403,lng:80.78798, label:“Sri Lanka”},
          {lat:-23.5475,lng:-46.63611, label:“Sao Paulo”}
                          // Individual values must be seperated by a comma.
                          // You can look up the latitude and longitude for a specific location on Google Maps.
          • F Offline
            Foxy25
            HI
            here is my working config:
            Greetings Torsten
            		module: 'MMM-Globe',
            		position: 'fullscreen_below',	// This can be any of the regions. Best results in lower_third
                            size:"medium", // Globe size. See configuration options below for more options
                            dayLength: 43, // (Optional) Rotation speed. See configuration options below
                            locations: [
                                // e.g.
                                // {lat:37.77493,lng:-122.41942, label: "San Francisco"},
                                // {lat:-23.5475,lng:-46.63611, label: "Sao Paulo"}
                                {lat:49.6294791,lng:7.8252699, label: "Rockenhausen" },
                                {lat:40.7223507,lng:-73.9901943, label: "New York" },
                                {lat:36.1047739,lng:-115.1421297, label: "Las Vegas" },
                                {lat:13.7544142,lng:100.5020575, label: "Bangkok" },
            • H Offline
              hiro.nguyen
              Hi, may i ask if it is possible to change background to transparent ?
              Thanks,
              G S 2 Replies Last reply Reply Quote 0
              • G Offline
                greedyvegan @hiro.nguyen
                in the beginning of this post from 2021, it was recommended NOT to use this with a raspberry pi
                today, in 2024, I have a raspberry pi 5, does that matter? lol
                anyway, the left is on my pi 5 and the right is viewing it on a browser on my computer
                is there an update on a lite version?
                  sdetweil @hiro.nguyen
                  @hiro-nguyen sure, css
                  google search css transparent background
                    sdetweil @greedyvegan
                    @greedyvegan you will need to enable the gpu in the system boot.txt
                    AND
                    tell MagicMirror electron to use it
                    export ELECTRON_ENABLE_GPU=1
                    in the script before
                    npm  start
                    if you used my script to install MagicMirror , that is ~/MagicMirror/installers/mm.sh
                    • G Offline
                      greedyvegan @sdetweil
                      like this?
                      I got this error
                      [PM2][ERROR] File ecosystem.config.js not found
                        @greedyvegan that pm2 error is usually caused by using sudo sometime when you shouldn’t
                        what happened before that? is that the first time w pm2
                        maybe
                        pm2 status
                        pm2 delete xxx
                        where xxx is the name or number on the MagicMirror line
                        then run my fixuppm2 script
                        pm2 seems fragile recently. not sure why
                        • G Offline
                          i accidently ran pm2 start instead of pm2 start mm
                          then it returned
                          then i ran pm2 start mm
                          then it returned
                          [PM2][ERROR] Script not found: /home/thecastle/MagicMirror/mm
                          status
                          after pm2 delete 0
                          after pm2 save
                          update -
                          it’s currently running (it was always running, it just had a weird error)
                          and told me to copy/paste
                          sudo env PATH=$PATH:/usr/local/bin /usr/local/lib/node_modules/pm2/bin/pm2 startup systemd -u pi --hp /home/pi
                            @greedyvegan yep, that’s why you run my script. lots of things to do
                            • G Offline
                              thank you very much!
                              • 6 / 6
