    MMM-Globe
    118 Posts 32 Posters 196.4k Views 37 Watching
    • F
      Foxy25 @Wenike
      @wenike
      i use the command in the styles.css of the modul, not in the custom.css.
      It works, but it makes the complete module invisible, not only the background behind the globe.
      Thank you for your support.
      • A
        ashishtank Module Developer @Foxy25
        @foxy25 to make globe transparent there are two changes required.
        • Module div’s background color
        • Globe canvas itself have black color as background.
        First one can be easily doable with css but to make globe transparent you will need to change the code as well. Do below to make globe transperent.
        • In custom.css add below css
        .globe
        	background-color: unset;
        • in modules\MMM-Globe\encom-globe.js file find below line and change it to.
        from
        this.renderer = new THREE.WebGLRenderer( { antialias: true } );
        to
        this.renderer = new THREE.WebGLRenderer( { antialias: true, alpha: true } );
        below is output
        Before
        After
        Let me know how/if it works for you.
        F 1 Reply Last reply Reply Quote 1
        • F
          Foxy25 @ashishtank
          It works perfect!!!
          Thank you so much for you support!!!
          Greetings from Germany
          Foxy
          • A
            @foxy25 you are welcome :)
              damith
              hi everyone, I’ve tried to install on my PI but it won’t work…am getting black screen, here is my config file… any HELP…?
              		module: "alert",
              		module: "updatenotification",
              		position: "top_bar"
              		module: "clock",
              		position: "top_left"
              		header: "Italy Holidays",
              					symbol: "calendar-check",
              					url: "webcal://www.calendarlabs.com/ical-calendar/ics/53/Italy_Holidays.ics"					}
              		module: "compliments",
              		position: "top_center"
              		module: "weather",
              			type: "current",
              			locationID: "3169070", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
              			apiKey: "492da6299f48937482d3c321215289b0"
              		module: "weather",
              		header: "Weather Forecast",
              			type: "forecast",
              		module: "newsfeed",
              		position: "bottom_bar",
              			feeds: [
              					title: "REPUBBLICA",
              					url: "https://www.repubblica.it/rss/homepage/rss2.0.xml"
              			showSourceTitle: true,
              			showPublishDate: true,
              			broadcastNewsFeeds: true,
              			broadcastNewsUpdates: true
              	module: 'MMM-Globe',
              	position: 'lower_third',	// This can be any of the regions. Best results in lower_third
                          size:"x-small", // Globe size. See configuration options below for more options
              			dayLength: 38, // (Optional) Rotation speed. See configuration options below
              		    viewAngle: 15, // (Optional) Globe tilt. See configuration options below.
              			introLinesDuration: 2000,
              			receiveExternalLocations: 0,
                          locations: [
                              // Fill with location Objects if desired
                              // e.g.
                                 {lat:37.77493,lng:-122.41942, label: "San Francisco"},
                                 {lat:-23.5475,lng:-46.63611, label: "Sao Paulo"}
                              // Individual values must be seperated by a comma.
                              // You can look up the latitude and longitude for a specific location on Google Maps.
              if (typeof module !== “undefined”) {module.exports = config;}
              thgmirrorT 1 Reply Last reply Reply Quote 0
              • thgmirrorT
                thgmirror @damith
                Hi @damith,
                May be, you have an issue in the config.js.
                You can use the built-in check-tool from within the MagicMirror folder named
                npm run config:check
                Or use an external Website (I use https://esprima.org/demo/validate.html) to see if it is valed.
                Thomas
                  damith
                  hi@thgmirror
                  Thank you very much for you reply, I’ve checked with built in check but no errors …!!
                  pi@raspberrypi:~/MagicMirror $ npm run config:check
                  magicmirror@2.15.0 config:check /home/pi/MagicMirror
                  node js/check_config.js
                  [02.05.2021 12:20.01.503] [INFO] Checking file… /home/pi/MagicMirror/config/config.js
                  [02.05.2021 12:20.01.719] [INFO] Your configuration file doesn’t contain syntax errors :)
                    sdetweil @damith
                    @damith did u do the npm install in the module folder after git clone?
                    if u look at the startup messages, where u start mm
                    npm start
                    or pm2 logs --lines=100
                    you might see a message, module not found.
                    this is the number 1 clue you didn’t do the npm install
                      damith @sdetweil
                      hi @sdetweil
                      Thank you very much for your reply… you are the NUMBER ONE… it works fine… Thanks again.
                      i have done NPM INSTALL… its worked fine…:face_savoring_food: :face_savoring_food:
                        damith
                        hi guys… my GLOBE is woking fine… but there is a problem with City NAMES, i won’t display…, config is ok… can anyone help me …?
                        module: ‘MMM-Globe’,
                        position: ‘lower_third’, // This can be any of the regions. Best results in lower_third
                        size:“x-large”, // Globe size. See configuration options below for more options
                        locations: [
                        // e.g.
                        {lat:37.77493,lng:-122.41942, label:“San Francisco”},
                        {lat:7.58403,lng:80.78798, label:“Sri Lanka”},
                        {lat:-23.5475,lng:-46.63611, label:“Sao Paulo”}
                        • F
                          Foxy25
                          HI
                          here is my working config:
                          Greetings Torsten
                          		position: 'fullscreen_below',	// This can be any of the regions. Best results in lower_third
                                          size:"medium", // Globe size. See configuration options below for more options
                                          dayLength: 43, // (Optional) Rotation speed. See configuration options below
                                          locations: [
                                              // e.g.
                                              // {lat:37.77493,lng:-122.41942, label: "San Francisco"},
                                              // {lat:-23.5475,lng:-46.63611, label: "Sao Paulo"}
                                              {lat:49.6294791,lng:7.8252699, label: "Rockenhausen" },
                                              {lat:40.7223507,lng:-73.9901943, label: "New York" },
                                              {lat:36.1047739,lng:-115.1421297, label: "Las Vegas" },
                                              {lat:13.7544142,lng:100.5020575, label: "Bangkok" },
                          • H
                            hiro.nguyen
                            Hi, may i ask if it is possible to change background to transparent ?
                            Thanks,
                            G S 2 Replies Last reply Reply Quote 0
                            • G
                              greedyvegan @hiro.nguyen
                              in the beginning of this post from 2021, it was recommended NOT to use this with a raspberry pi
                              today, in 2024, I have a raspberry pi 5, does that matter? lol
                              anyway, the left is on my pi 5 and the right is viewing it on a browser on my computer
                              is there an update on a lite version?
                                sdetweil @hiro.nguyen
                                @hiro-nguyen sure, css
                                google search css transparent background
                                  sdetweil @greedyvegan
                                  @greedyvegan you will need to enable the gpu in the system boot.txt
                                  AND
                                  tell MagicMirror electron to use it
                                  export ELECTRON_ENABLE_GPU=1
                                  in the script before
                                  npm  start
                                  if you used my script to install MagicMirror , that is ~/MagicMirror/installers/mm.sh
                                  • G
                                    greedyvegan @sdetweil
                                    like this?
                                    I got this error
                                    [PM2][ERROR] File ecosystem.config.js not found
                                      @greedyvegan that pm2 error is usually caused by using sudo sometime when you shouldn’t
                                      what happened before that? is that the first time w pm2
                                      maybe
                                      pm2 status
                                      pm2 delete xxx
                                      where xxx is the name or number on the MagicMirror line
                                      then run my fixuppm2 script
                                      pm2 seems fragile recently. not sure why
                                      • G
                                        i accidently ran pm2 start instead of pm2 start mm
                                        then it returned
                                        then i ran pm2 start mm
                                        then it returned
                                        [PM2][ERROR] Script not found: /home/thecastle/MagicMirror/mm
                                        status
                                        after pm2 delete 0
                                        after pm2 save
                                        update -
                                        it’s currently running (it was always running, it just had a weird error)
                                        and told me to copy/paste
                                        sudo env PATH=$PATH:/usr/local/bin /usr/local/lib/node_modules/pm2/bin/pm2 startup systemd -u pi --hp /home/pi
                                          @greedyvegan yep, that’s why you run my script. lots of things to do
                                          • G
                                            thank you very much!
                                            • 6 / 6
