    MMM-Globe
    118 Posts 32 Posters 196.4k Views 37 Watching
    • I
      Idea215
      I have installed module on my P4, but somehow it does not really work. It is only displayed as in the picture below and not as in the pictures on the GitHub page. Does anyone know what the problem is?
      My Mirror:
      https://imgur.com/a/tOwDJru
      GitHub Version:
      https://i.imgur.com/oF3mxBC.png
      • W
        Wenike @Idea215
        @idea215 Did you go to the github link from the first post or just Googled for MMM-Globe? Yours looks like mine which is from a different MMM-Globe
        • O
          oli28
          What a beautiful modul! Any chance to change the font size to be able to fit more destinations next to each others? I did try to find it in the .css but had no luck yet.
          • F
            Foxy25
            I have a question about the module:
            I would like to make the background transparent, is that possible? At the moment it is black.
            That would help me, because I have a slideshow running in the background and the black background behind the globe doesn’t look so nice …
            Would be very grateful if someone could help.
            Foxy
            • W
              Wenike @Foxy25
              @foxy25 @foxy25 In your custom.css file, see if adding:
              .globe { opacity: 0.0; }
              Fixes the issue?
              • F
                Foxy25 @Wenike
                @wenike
                i use the command in the styles.css of the modul, not in the custom.css.
                It works, but it makes the complete module invisible, not only the background behind the globe.
                Thank you for your support.
                • A
                  ashishtank Module Developer @Foxy25
                  @foxy25 to make globe transparent there are two changes required.
                  • Module div’s background color
                  • Globe canvas itself have black color as background.
                  First one can be easily doable with css but to make globe transparent you will need to change the code as well. Do below to make globe transperent.
                  • In custom.css add below css
                  .globe
                  	background-color: unset;
                  • in modules\MMM-Globe\encom-globe.js file find below line and change it to.
                  from
                  this.renderer = new THREE.WebGLRenderer( { antialias: true } );
                  to
                  this.renderer = new THREE.WebGLRenderer( { antialias: true, alpha: true } );
                  below is output
                  Before
                  After
                  Let me know how/if it works for you.
                  F 1 Reply Last reply Reply Quote 1
                  • F
                    Foxy25 @ashishtank
                    It works perfect!!!
                    Thank you so much for you support!!!
                    Greetings from Germany
                    Foxy
                    • A
                      @foxy25 you are welcome :)
                        damith
                        hi everyone, I’ve tried to install on my PI but it won’t work…am getting black screen, here is my config file… any HELP…?
                        		module: "alert",
                        		module: "updatenotification",
                        		position: "top_bar"
                        		module: "clock",
                        		position: "top_left"
                        		header: "Italy Holidays",
                        					symbol: "calendar-check",
                        					url: "webcal://www.calendarlabs.com/ical-calendar/ics/53/Italy_Holidays.ics"					}
                        		module: "compliments",
                        		position: "top_center"
                        		module: "weather",
                        			type: "current",
                        			locationID: "3169070", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                        			apiKey: "492da6299f48937482d3c321215289b0"
                        		module: "weather",
                        		header: "Weather Forecast",
                        			type: "forecast",
                        		module: "newsfeed",
                        		position: "bottom_bar",
                        			feeds: [
                        					title: "REPUBBLICA",
                        					url: "https://www.repubblica.it/rss/homepage/rss2.0.xml"
                        			showSourceTitle: true,
                        			showPublishDate: true,
                        			broadcastNewsFeeds: true,
                        			broadcastNewsUpdates: true
                        	module: 'MMM-Globe',
                        	position: 'lower_third',	// This can be any of the regions. Best results in lower_third
                                    size:"x-small", // Globe size. See configuration options below for more options
                        			dayLength: 38, // (Optional) Rotation speed. See configuration options below
                        		    viewAngle: 15, // (Optional) Globe tilt. See configuration options below.
                        			introLinesDuration: 2000,
                        			receiveExternalLocations: 0,
                                    locations: [
                                        // Fill with location Objects if desired
                                        // e.g.
                                           {lat:37.77493,lng:-122.41942, label: "San Francisco"},
                                           {lat:-23.5475,lng:-46.63611, label: "Sao Paulo"}
                                        // Individual values must be seperated by a comma.
                                        // You can look up the latitude and longitude for a specific location on Google Maps.
                        if (typeof module !== “undefined”) {module.exports = config;}
                        thgmirrorT 1 Reply Last reply Reply Quote 0
                        • thgmirrorT
                          thgmirror @damith
                          Hi @damith,
                          May be, you have an issue in the config.js.
                          You can use the built-in check-tool from within the MagicMirror folder named
                          npm run config:check
                          Or use an external Website (I use https://esprima.org/demo/validate.html) to see if it is valed.
                          Thomas
                            damith
                            hi@thgmirror
                            Thank you very much for you reply, I’ve checked with built in check but no errors …!!
                            pi@raspberrypi:~/MagicMirror $ npm run config:check
                            magicmirror@2.15.0 config:check /home/pi/MagicMirror
                            node js/check_config.js
                            [02.05.2021 12:20.01.503] [INFO] Checking file… /home/pi/MagicMirror/config/config.js
                            [02.05.2021 12:20.01.719] [INFO] Your configuration file doesn’t contain syntax errors :)
                              sdetweil @damith
                              @damith did u do the npm install in the module folder after git clone?
                              if u look at the startup messages, where u start mm
                              npm start
                              or pm2 logs --lines=100
                              you might see a message, module not found.
                              this is the number 1 clue you didn’t do the npm install
                                damith @sdetweil
                                hi @sdetweil
                                Thank you very much for your reply… you are the NUMBER ONE… it works fine… Thanks again.
                                i have done NPM INSTALL… its worked fine…:face_savoring_food: :face_savoring_food:
                                  damith
                                  hi guys… my GLOBE is woking fine… but there is a problem with City NAMES, i won’t display…, config is ok… can anyone help me …?
                                  module: ‘MMM-Globe’,
                                  position: ‘lower_third’, // This can be any of the regions. Best results in lower_third
                                  size:“x-large”, // Globe size. See configuration options below for more options
                                  locations: [
                                  // e.g.
                                  {lat:37.77493,lng:-122.41942, label:“San Francisco”},
                                  {lat:7.58403,lng:80.78798, label:“Sri Lanka”},
                                  {lat:-23.5475,lng:-46.63611, label:“Sao Paulo”}
                                  • F
                                    Foxy25
                                    HI
                                    here is my working config:
                                    Greetings Torsten
                                    		position: 'fullscreen_below',	// This can be any of the regions. Best results in lower_third
                                                    size:"medium", // Globe size. See configuration options below for more options
                                                    dayLength: 43, // (Optional) Rotation speed. See configuration options below
                                                    locations: [
                                                        // e.g.
                                                        // {lat:37.77493,lng:-122.41942, label: "San Francisco"},
                                                        // {lat:-23.5475,lng:-46.63611, label: "Sao Paulo"}
                                                        {lat:49.6294791,lng:7.8252699, label: "Rockenhausen" },
                                                        {lat:40.7223507,lng:-73.9901943, label: "New York" },
                                                        {lat:36.1047739,lng:-115.1421297, label: "Las Vegas" },
                                                        {lat:13.7544142,lng:100.5020575, label: "Bangkok" },
                                    • H
                                      hiro.nguyen
                                      Hi, may i ask if it is possible to change background to transparent ?
                                      Thanks,
                                      G S 2 Replies Last reply Reply Quote 0
                                      • G
                                        greedyvegan @hiro.nguyen
                                        in the beginning of this post from 2021, it was recommended NOT to use this with a raspberry pi
                                        today, in 2024, I have a raspberry pi 5, does that matter? lol
                                        anyway, the left is on my pi 5 and the right is viewing it on a browser on my computer
                                        is there an update on a lite version?
                                          sdetweil @hiro.nguyen
                                          @hiro-nguyen sure, css
                                          google search css transparent background
                                            sdetweil @greedyvegan
                                            @greedyvegan you will need to enable the gpu in the system boot.txt
                                            AND
                                            tell MagicMirror electron to use it
                                            export ELECTRON_ENABLE_GPU=1
                                            in the script before
                                            npm  start
                                            if you used my script to install MagicMirror , that is ~/MagicMirror/installers/mm.sh
                                            • 6 / 6
