Fails to start... "Log.log is not a function"
16 Posts 2 Posters 849 Views 2 Watching
    Bimtronic
    I got this after i installed some modules and updated packs.
    magicmirror@2.29.0 start
    [2024-12-04 21:05:31.188] [ERROR] App threw an error during load
    [2024-12-04 21:05:31.196] [ERROR] TypeError: Log.log is not a function
    at Object. (/home/mt/MagicMirror/js/app.js:16:5)
    at Module._compile (node:internal/modules/cjs/loader:1484:14)
    at Module._extensions…js (node:internal/modules/cjs/loader:1564:10)
    at Module.load (node:internal/modules/cjs/loader:1295:32)
    at Module._load (node:internal/modules/cjs/loader:1111:12)
    at c._load (node:electron/js2c/node_init:2:17025)
    at Module.require (node:internal/modules/cjs/loader:1318:19)
    at require (node:internal/modules/helpers:179:18)
    at Object. (/home/mt/MagicMirror/js/electron.js:4:14)
    at cjsLoader (node:internal/modules/esm/translators:350:17)
    at ModuleWrap. (node:internal/modules/esm/translators:286:7)
    A JavaScript error occurred in the main process
    Uncaught Exception:
    How can i solve this?
    S 1 Reply Last reply Dec 4, 2024, 8:20 PM Reply Quote 0
    • S Away
      sdetweil @Bimtronic
      @Bimtronic the npm install did not complete
      B 1 Reply Last reply Dec 4, 2024, 8:30 PM Reply Quote 0
        Bimtronic @sdetweil
        I just ran “npm install” but it didnt solve this.
        Did you mean a package/module?
        mt@mt:~ $ npm install
        up to date, audited 79 packages in 21s
        22 packages are looking for funding
        run npm fund for details
        found 0 vulnerabilities
        S 1 Reply Last reply Dec 4, 2024, 8:54 PM Reply Quote 0
        • S Away
          sdetweil @Bimtronic
          @Bimtronic in the MagicMirror folder
          B 1 Reply Last reply Dec 5, 2024, 6:38 AM Reply Quote 1
            Bimtronic @sdetweil
            I tried to run a new “npm install” in the MM-folder, but i still have the same errors.
            Is it advised to delete and reinstall Magic Mirror completely?
            S 1 Reply Last reply Dec 5, 2024, 12:51 PM Reply Quote 0
            • S Away
              sdetweil @Bimtronic
              @Bimtronic can you show me the output of the npm install
              B 1 Reply Last reply Dec 9, 2024, 9:03 AM Reply Quote 0
                Bimtronic @sdetweil
                mt@mt:~/MagicMirror $ npm install
                magicmirror@2.29.0 postinstall
                npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
                magicmirror@2.29.0 install-vendor
                echo "Installing vendor files …
                " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                up to date in 3s
                magicmirror@2.29.0 install-fonts
                echo "Installing fonts …
                " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                Installing fonts …
                up to date in 3s
                magicmirror@2.29.0 prepare
                [ -f node_modules/.bin/husky ] && husky || echo no husky installed.
                up to date in 56s
                208 packages are looking for funding
                npm notice
                npm notice New patch version of npm available! 10.9.0 -> 10.9.2
                npm notice Changelog: https://github.com/npm/cli/releases/tag/v10.9.2
                npm notice To update run: npm install -g npm@10.9.2
                npm notice
                S 1 Reply Last reply Dec 9, 2024, 12:54 PM Reply Quote 0
                • S Away
                  sdetweil @Bimtronic
                  @Bimtronic ok and now, in the MagicMirror folder
                  The output of npm start
                  B 1 Reply Last reply Dec 9, 2024, 2:23 PM Reply Quote 0
                    Bimtronic @sdetweil
                    mt@mt:~/MagicMirror $ npm start
                    [2024-12-09 15:22:44.863] [ERROR] App threw an error during load
                    [2024-12-09 15:22:44.871] [ERROR] TypeError: Log.log is not a function
                    Uncaught Exception:
                    S 1 Reply Last reply Dec 9, 2024, 2:27 PM Reply Quote 0
                    • S Away
                      sdetweil @Bimtronic
                      @Bimtronic can you show me the config.js, xxx out any apikeys or private info
                      B 1 Reply Last reply Dec 10, 2024, 6:45 AM Reply Quote 1
