    Fails to start... "Log.log is not a function"
    16 Posts 2 Posters 1.9k Views 2 Watching
      Bimtronic @sdetweil
      I tried to run a new “npm install” in the MM-folder, but i still have the same errors.
      Is it advised to delete and reinstall Magic Mirror completely?
        sdetweil @Bimtronic
        @Bimtronic can you show me the output of the npm install
          Bimtronic @sdetweil
          mt@mt:~/MagicMirror $ npm install
          magicmirror@2.29.0 postinstall
          npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
          magicmirror@2.29.0 install-vendor
          echo "Installing vendor files …
          " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
          up to date in 3s
          magicmirror@2.29.0 install-fonts
          echo "Installing fonts …
          " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
          Installing fonts …
          up to date in 3s
          magicmirror@2.29.0 prepare
          [ -f node_modules/.bin/husky ] && husky || echo no husky installed.
          up to date in 56s
          208 packages are looking for funding
          run npm fund for details
          npm notice
          npm notice New patch version of npm available! 10.9.0 -> 10.9.2
          npm notice Changelog: https://github.com/npm/cli/releases/tag/v10.9.2
          npm notice To update run: npm install -g npm@10.9.2
          npm notice
            sdetweil @Bimtronic
            @Bimtronic ok and now, in the MagicMirror folder
            The output of npm start
              Bimtronic @sdetweil
              mt@mt:~/MagicMirror $ npm start
              magicmirror@2.29.0 start
              [2024-12-09 15:22:44.863] [ERROR] App threw an error during load
              [2024-12-09 15:22:44.871] [ERROR] TypeError: Log.log is not a function
              at Object. (/home/mt/MagicMirror/js/app.js:16:5)
              at Module._compile (node:internal/modules/cjs/loader:1484:14)
              at Module._extensions…js (node:internal/modules/cjs/loader:1564:10)
              at Module.load (node:internal/modules/cjs/loader:1295:32)
              at Module._load (node:internal/modules/cjs/loader:1111:12)
              at c._load (node:electron/js2c/node_init:2:17025)
              at Module.require (node:internal/modules/cjs/loader:1318:19)
              at require (node:internal/modules/helpers:179:18)
              at Object. (/home/mt/MagicMirror/js/electron.js:4:14)
              at cjsLoader (node:internal/modules/esm/translators:350:17)
              at ModuleWrap. (node:internal/modules/esm/translators:286:7)
              A JavaScript error occurred in the main process
              Uncaught Exception:
                sdetweil @Bimtronic
                @Bimtronic can you show me the config.js, xxx out any apikeys or private info
                  Bimtronic @sdetweil
                  Here it is, I really appreciate your help.
                  let config = {
                  	address: "localhost",				// Address to listen on, can be:
                  	port: 8080,
                  	basePath: "/",					// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
                  	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],		// Set [] to allow all IP addresses
                  	useHttps: false,	// Support HTTPS or not, default "false" will use HTTP
                  	httpsPrivateKey: "",	// HTTPS private key path, only require when useHttps is true
                  	httpsCertificate: "",	// HTTPS Certificate path, only require when useHttps is true
                  	language: "sv",
                  	locale: "sv-SV",
                  	timeFormat: 24,
                  	units: "metric",
                  		module: 'MMM-SystemStats',
                  		position: 'top_right', // This can be any of the regions.
                  		// classes: 'small dimmed', // Add your own styling. OPTIONAL.
                  		// header: 'System Stats', // Set the header text OPTIONAL
                  			updateInterval: 10000, // every 10 seconds
                  			align: 'right', // align labels
                  			//header: 'System Stats', // This is optional
                  			units: 'metric', // default, metric, imperial
                  			view: 'textAndIcon',
                  			module: "MMM-Online-State",
                  			position: "bottom_right",
                  				displaysymbol: true,
                  				symbolOnline: "wifi",
                  				colored: true,
                  				colorOnline: "#fff",
                  				colorOffline: "red",
                  			module: "alert",
                  			module: "updatenotification",
                  			position: "top_bar"
                  			module: "clock",
                  			position: "top_left"
                                          header: "Helgdagar",
                  			maximumEntries: 5,
        symbol: "calendar-check",
        url: "webcal://localhost:8080/modules/ics/se_holidays.ics"
                  	//		module: "compliments",
                  	//		position: "lower_third"
                  			module: "weather",
                  				weatherProvider: "openmeteo",
                  				type: "current",
                  				lat: 55.60587,
                  				lon: 13.00073
                  			module: "weather",
                  			header: "Väder",
                  				type: "forecast",
                  				lat: 55.60587,
                  				lon: 13.00073
                  			module: "newsfeed",
                  			position: "top_bar",
                  				feeds: [
                  						title: "Sydsvenskan - Senaste nytt",
                  						url: "https://www.sydsvenskan.se/feeds/feed.xml"
                  				showSourceTitle: true,
                  				showPublishDate: true,
                  				broadcastNewsFeeds: true,
                  				broadcastNewsUpdates: true
                                          module: 'MMM-Globe',
                                          position: 'middle_center',
                                                  style: 'geoColor',
                                                  imageSize: 300,
                                                  ownImagePath:'',
                                                  updateInterval: 10*60*1000
                    sdetweil @Bimtronic
                    @Bimtronic tgx
                    This looks like it is caused by MMM-SystemStats module
                    You can edit the MMM-SystemStats.js
                    and comment it out (add // as the start of the text on that line)
                    One occurance is not commented
                    Or change it to Log.info
                      Bimtronic @sdetweil
                      I deleted MMM-SystemStats from my config.
                      Still getting errors >
                      [2024-12-11 19:48:33.034] [ERROR] App threw an error during load
                      [2024-12-11 19:48:33.042] [ERROR] TypeError: Log.log is not a function
                      Uncaught Exception:
                        sdetweil @Bimtronic
                        @Bimtronic so weird
                        add
                        disabled:true,
                        after every
                        module:
                        line
                        and change to false one at a time
