    Fails to start... "Log.log is not a function"
    16 Posts 2 Posters 2.8k Views 2 Watching
      Bimtronic @sdetweil
      I just ran “npm install” but it didnt solve this.
      Did you mean a package/module?
      mt@mt:~ $ npm install
      up to date, audited 79 packages in 21s
      22 packages are looking for funding
      run npm fund for details
      found 0 vulnerabilities
        sdetweil @Bimtronic
        @Bimtronic in the MagicMirror folder
          Bimtronic @sdetweil
          I tried to run a new “npm install” in the MM-folder, but i still have the same errors.
          Is it advised to delete and reinstall Magic Mirror completely?
            sdetweil @Bimtronic
            @Bimtronic can you show me the output of the npm install
              Bimtronic @sdetweil
              mt@mt:~/MagicMirror $ npm install
              magicmirror@2.29.0 postinstall
              npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
              magicmirror@2.29.0 install-vendor
              echo "Installing vendor files …
              " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
              up to date in 3s
              magicmirror@2.29.0 install-fonts
              echo "Installing fonts …
              " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
              Installing fonts …
              up to date in 3s
              magicmirror@2.29.0 prepare
              [ -f node_modules/.bin/husky ] && husky || echo no husky installed.
              up to date in 56s
              208 packages are looking for funding
              npm notice
              npm notice New patch version of npm available! 10.9.0 -> 10.9.2
              npm notice Changelog: https://github.com/npm/cli/releases/tag/v10.9.2
              npm notice To update run: npm install -g npm@10.9.2
              npm notice
                sdetweil @Bimtronic
                @Bimtronic ok and now, in the MagicMirror folder
                The output of npm start
                  Bimtronic @sdetweil
                  mt@mt:~/MagicMirror $ npm start
                  magicmirror@2.29.0 start
                  [2024-12-09 15:22:44.863] [ERROR] App threw an error during load
                  [2024-12-09 15:22:44.871] [ERROR] TypeError: Log.log is not a function
                  at Object. (/home/mt/MagicMirror/js/app.js:16:5)
                  at Module._compile (node:internal/modules/cjs/loader:1484:14)
                  at Module._extensions…js (node:internal/modules/cjs/loader:1564:10)
                  at Module.load (node:internal/modules/cjs/loader:1295:32)
                  at Module._load (node:internal/modules/cjs/loader:1111:12)
                  at c._load (node:electron/js2c/node_init:2:17025)
                  at Module.require (node:internal/modules/cjs/loader:1318:19)
                  at require (node:internal/modules/helpers:179:18)
                  at Object. (/home/mt/MagicMirror/js/electron.js:4:14)
                  at cjsLoader (node:internal/modules/esm/translators:350:17)
                  at ModuleWrap. (node:internal/modules/esm/translators:286:7)
                  A JavaScript error occurred in the main process
                  Uncaught Exception:
                    sdetweil @Bimtronic
                    @Bimtronic can you show me the config.js, xxx out any apikeys or private info
                      Bimtronic @sdetweil
                      Here it is, I really appreciate your help.
                      let config = {
                      	address: "localhost",				// Address to listen on, can be:
                      	port: 8080,
                      	basePath: "/",					// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
                      	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],		// Set [] to allow all IP addresses
                      	useHttps: false,	// Support HTTPS or not, default "false" will use HTTP
                      	httpsPrivateKey: "",	// HTTPS private key path, only require when useHttps is true
                      	httpsCertificate: "",	// HTTPS Certificate path, only require when useHttps is true
                      	language: "sv",
                      	locale: "sv-SV",
                      	timeFormat: 24,
                      	units: "metric",
                      		module: 'MMM-SystemStats',
                      		position: 'top_right', // This can be any of the regions.
                      		// classes: 'small dimmed', // Add your own styling. OPTIONAL.
                      		// header: 'System Stats', // Set the header text OPTIONAL
                      			updateInterval: 10000, // every 10 seconds
                      			align: 'right', // align labels
                      			//header: 'System Stats', // This is optional
                      			units: 'metric', // default, metric, imperial
                      			view: 'textAndIcon',
                      			module: "MMM-Online-State",
                      			position: "bottom_right",
                      				displaysymbol: true,
                      				symbolOnline: "wifi",
                      				colored: true,
                      				colorOnline: "#fff",
                      				colorOffline: "red",
                      			module: "alert",
                      			module: "updatenotification",
                      			position: "top_bar"
                      			module: "clock",
                      			position: "top_left"
                                              header: "Helgdagar",
                      			maximumEntries: 5,
        symbol: "calendar-check",
        url: "webcal://localhost:8080/modules/ics/se_holidays.ics"
                      	//		module: "compliments",
                      	//		position: "lower_third"
                      			module: "weather",
                      				weatherProvider: "openmeteo",
                      				type: "current",
                      				lat: 55.60587,
                      				lon: 13.00073
                      			module: "weather",
                      			header: "Väder",
                      				type: "forecast",
                      				lat: 55.60587,
                      				lon: 13.00073
                      			module: "newsfeed",
                      			position: "top_bar",
                      				feeds: [
                      						title: "Sydsvenskan - Senaste nytt",
                      						url: "https://www.sydsvenskan.se/feeds/feed.xml"
                      				showSourceTitle: true,
                      				showPublishDate: true,
                      				broadcastNewsFeeds: true,
                      				broadcastNewsUpdates: true
                                              module: 'MMM-Globe',
                                              position: 'middle_center',
                                                      style: 'geoColor',
                                                      imageSize: 300,
                                                      ownImagePath:'',
                                                      updateInterval: 10*60*1000
                        sdetweil @Bimtronic
                        @Bimtronic tgx
                        This looks like it is caused by MMM-SystemStats module
                        You can edit the MMM-SystemStats.js
                        and comment it out (add // as the start of the text on that line)
                        One occurance is not commented
                        Or change it to Log.info
                          Bimtronic @sdetweil
                          I deleted MMM-SystemStats from my config.
                          Still getting errors >
                          [2024-12-11 19:48:33.034] [ERROR] App threw an error during load
                          [2024-12-11 19:48:33.042] [ERROR] TypeError: Log.log is not a function
                          Uncaught Exception:
                            sdetweil @Bimtronic
                            @Bimtronic so weird
                            add
                            disabled:true,
                            after every
                            module:
                            line
                            and change to false one at a time
                              Bimtronic @sdetweil
                              I disabled all modules, same errors.
                              Disabled all but not the “alert”-module, same errors.
                              I dont think is from the config, maybe the node.js file-system that is messed up.
                              How do i uninstall MagicMirror and make a new clean install to start from scratch?
                                sdetweil @Bimtronic
                                @Bimtronic use my backup/restore scripts yo save your MagicMirror setup
                                https://github.com/sdetweil/MagicMirror-backup-restore
                                then you can rename/delete the MagicMirror folder
                                and use my install script
                                see https://github.com/sdetweil/MagicMirror_scripts
                                and then use restore to put the MagicMirror configuration back
