    Fails to start... "Log.log is not a function"
    16 Posts 2 Posters 2.2k Views 2 Watching
      Bimtronic
      I got this after i installed some modules and updated packs.
      magicmirror@2.29.0 start
      [2024-12-04 21:05:31.188] [ERROR] App threw an error during load
      [2024-12-04 21:05:31.196] [ERROR] TypeError: Log.log is not a function
      at Object. (/home/mt/MagicMirror/js/app.js:16:5)
      at Module._compile (node:internal/modules/cjs/loader:1484:14)
      at Module._extensions…js (node:internal/modules/cjs/loader:1564:10)
      at Module.load (node:internal/modules/cjs/loader:1295:32)
      at Module._load (node:internal/modules/cjs/loader:1111:12)
      at c._load (node:electron/js2c/node_init:2:17025)
      at Module.require (node:internal/modules/cjs/loader:1318:19)
      at require (node:internal/modules/helpers:179:18)
      at Object. (/home/mt/MagicMirror/js/electron.js:4:14)
      at cjsLoader (node:internal/modules/esm/translators:350:17)
      at ModuleWrap. (node:internal/modules/esm/translators:286:7)
      A JavaScript error occurred in the main process
      Uncaught Exception:
      How can i solve this?
        sdetweil @Bimtronic
        @Bimtronic the npm install did not complete
          Bimtronic @sdetweil
          I just ran “npm install” but it didnt solve this.
          Did you mean a package/module?
          mt@mt:~ $ npm install
          up to date, audited 79 packages in 21s
          22 packages are looking for funding
          run npm fund for details
          found 0 vulnerabilities
            sdetweil @Bimtronic
            @Bimtronic in the MagicMirror folder
              Bimtronic @sdetweil
              I tried to run a new “npm install” in the MM-folder, but i still have the same errors.
              Is it advised to delete and reinstall Magic Mirror completely?
                sdetweil @Bimtronic
                @Bimtronic can you show me the output of the npm install
                  Bimtronic @sdetweil
                  mt@mt:~/MagicMirror $ npm install
                  magicmirror@2.29.0 postinstall
                  npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
                  magicmirror@2.29.0 install-vendor
                  echo "Installing vendor files …
                  " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                  up to date in 3s
                  magicmirror@2.29.0 install-fonts
                  echo "Installing fonts …
                  " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                  Installing fonts …
                  up to date in 3s
                  magicmirror@2.29.0 prepare
                  [ -f node_modules/.bin/husky ] && husky || echo no husky installed.
                  up to date in 56s
                  208 packages are looking for funding
                  npm notice
                  npm notice New patch version of npm available! 10.9.0 -> 10.9.2
                  npm notice Changelog: https://github.com/npm/cli/releases/tag/v10.9.2
                  npm notice To update run: npm install -g npm@10.9.2
                  npm notice
                    sdetweil @Bimtronic
                    @Bimtronic ok and now, in the MagicMirror folder
                    The output of npm start
                      Bimtronic @sdetweil
                      mt@mt:~/MagicMirror $ npm start
                      [2024-12-09 15:22:44.863] [ERROR] App threw an error during load
                      [2024-12-09 15:22:44.871] [ERROR] TypeError: Log.log is not a function
                      Uncaught Exception:
                        sdetweil @Bimtronic
                        @Bimtronic can you show me the config.js, xxx out any apikeys or private info
                          Bimtronic @sdetweil
                          Here it is, I really appreciate your help.
                          let config = {
                          	address: "localhost",				// Address to listen on, can be:
                          	port: 8080,
                          	basePath: "/",					// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
                          	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],		// Set [] to allow all IP addresses
                          	useHttps: false,	// Support HTTPS or not, default "false" will use HTTP
                          	httpsPrivateKey: "",	// HTTPS private key path, only require when useHttps is true
                          	httpsCertificate: "",	// HTTPS Certificate path, only require when useHttps is true
                          	language: "sv",
                          	locale: "sv-SV",
                          	timeFormat: 24,
                          	units: "metric",
                          		module: 'MMM-SystemStats',
                          		position: 'top_right', // This can be any of the regions.
                          		// classes: 'small dimmed', // Add your own styling. OPTIONAL.
                          		// header: 'System Stats', // Set the header text OPTIONAL
                          			updateInterval: 10000, // every 10 seconds
                          			align: 'right', // align labels
                          			//header: 'System Stats', // This is optional
                          			units: 'metric', // default, metric, imperial
                          			view: 'textAndIcon',
                          			module: "MMM-Online-State",
                          			position: "bottom_right",
                          				displaysymbol: true,
                          				symbolOnline: "wifi",
                          				colored: true,
                          				colorOnline: "#fff",
                          				colorOffline: "red",
                          			module: "alert",
                          			module: "updatenotification",
                          			position: "top_bar"
                          			module: "clock",
                          			position: "top_left"
                                                  header: "Helgdagar",
                          			maximumEntries: 5,
        symbol: "calendar-check",
        url: "webcal://localhost:8080/modules/ics/se_holidays.ics"
                          	//		module: "compliments",
                          	//		position: "lower_third"
                          			module: "weather",
                          				weatherProvider: "openmeteo",
                          				type: "current",
                          				lat: 55.60587,
                          				lon: 13.00073
                          			module: "weather",
                          			header: "Väder",
                          				type: "forecast",
                          				lat: 55.60587,
                          				lon: 13.00073
                          			module: "newsfeed",
                          			position: "top_bar",
                          				feeds: [
                          						title: "Sydsvenskan - Senaste nytt",
                          						url: "https://www.sydsvenskan.se/feeds/feed.xml"
                          				showSourceTitle: true,
                          				showPublishDate: true,
                          				broadcastNewsFeeds: true,
                          				broadcastNewsUpdates: true
                                                  module: 'MMM-Globe',
                                                  position: 'middle_center',
                                                          style: 'geoColor',
                                                          imageSize: 300,
                                                          ownImagePath:'',
                                                          updateInterval: 10*60*1000
                            sdetweil @Bimtronic
                            @Bimtronic tgx
                            This looks like it is caused by MMM-SystemStats module
                            You can edit the MMM-SystemStats.js
                            and comment it out (add // as the start of the text on that line)
                            One occurance is not commented
                            Or change it to Log.info
                              Bimtronic @sdetweil
                              I deleted MMM-SystemStats from my config.
                              Still getting errors >
                              [2024-12-11 19:48:33.034] [ERROR] App threw an error during load
                              [2024-12-11 19:48:33.042] [ERROR] TypeError: Log.log is not a function
                              Uncaught Exception:
                                sdetweil @Bimtronic
                                @Bimtronic so weird
                                add
                                disabled:true,
                                after every
                                module:
                                line
                                and change to false one at a time
                                  Bimtronic @sdetweil
                                  I disabled all modules, same errors.
                                  Disabled all but not the “alert”-module, same errors.
                                  I dont think is from the config, maybe the node.js file-system that is messed up.
                                  How do i uninstall MagicMirror and make a new clean install to start from scratch?
                                    sdetweil @Bimtronic
                                    @Bimtronic use my backup/restore scripts yo save your MagicMirror setup
                                    https://github.com/sdetweil/MagicMirror-backup-restore
                                    then you can rename/delete the MagicMirror folder
                                    and use my install script
                                    see https://github.com/sdetweil/MagicMirror_scripts
                                    and then use restore to put the MagicMirror configuration back
