    Fails to start... "Log.log is not a function"
    16 Posts 2 Posters 2.6k Views 2 Watching
      Bimtronic @sdetweil
      mt@mt:~/MagicMirror $ npm install
      magicmirror@2.29.0 postinstall
      npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
      magicmirror@2.29.0 install-vendor
      echo "Installing vendor files …
      " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
      up to date in 3s
      magicmirror@2.29.0 install-fonts
      echo "Installing fonts …
      " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
      Installing fonts …
      up to date in 3s
      magicmirror@2.29.0 prepare
      [ -f node_modules/.bin/husky ] && husky || echo no husky installed.
      up to date in 56s
      208 packages are looking for funding
      run npm fund for details
      npm notice
      npm notice New patch version of npm available! 10.9.0 -> 10.9.2
      npm notice Changelog: https://github.com/npm/cli/releases/tag/v10.9.2
      npm notice To update run: npm install -g npm@10.9.2
      npm notice
        sdetweil @Bimtronic
        @Bimtronic ok and now, in the MagicMirror folder
        The output of npm start
          Bimtronic @sdetweil
          mt@mt:~/MagicMirror $ npm start
          magicmirror@2.29.0 start
          [2024-12-09 15:22:44.863] [ERROR] App threw an error during load
          [2024-12-09 15:22:44.871] [ERROR] TypeError: Log.log is not a function
          at Object. (/home/mt/MagicMirror/js/app.js:16:5)
          at Module._compile (node:internal/modules/cjs/loader:1484:14)
          at Module._extensions…js (node:internal/modules/cjs/loader:1564:10)
          at Module.load (node:internal/modules/cjs/loader:1295:32)
          at Module._load (node:internal/modules/cjs/loader:1111:12)
          at c._load (node:electron/js2c/node_init:2:17025)
          at Module.require (node:internal/modules/cjs/loader:1318:19)
          at require (node:internal/modules/helpers:179:18)
          at Object. (/home/mt/MagicMirror/js/electron.js:4:14)
          at cjsLoader (node:internal/modules/esm/translators:350:17)
          at ModuleWrap. (node:internal/modules/esm/translators:286:7)
          A JavaScript error occurred in the main process
          Uncaught Exception:
            sdetweil @Bimtronic
            @Bimtronic can you show me the config.js, xxx out any apikeys or private info
              Bimtronic @sdetweil
              Here it is, I really appreciate your help.
              let config = {
              	address: "localhost",				// Address to listen on, can be:
              	port: 8080,
              	basePath: "/",					// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
              	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],		// Set [] to allow all IP addresses
              	useHttps: false,	// Support HTTPS or not, default "false" will use HTTP
              	httpsPrivateKey: "",	// HTTPS private key path, only require when useHttps is true
              	httpsCertificate: "",	// HTTPS Certificate path, only require when useHttps is true
              	language: "sv",
              	locale: "sv-SV",
              	timeFormat: 24,
              	units: "metric",
              		module: 'MMM-SystemStats',
              		position: 'top_right', // This can be any of the regions.
              		// classes: 'small dimmed', // Add your own styling. OPTIONAL.
              		// header: 'System Stats', // Set the header text OPTIONAL
              			updateInterval: 10000, // every 10 seconds
              			align: 'right', // align labels
              			//header: 'System Stats', // This is optional
              			units: 'metric', // default, metric, imperial
              			view: 'textAndIcon',
              			module: "MMM-Online-State",
              			position: "bottom_right",
              				displaysymbol: true,
              				symbolOnline: "wifi",
              				colored: true,
              				colorOnline: "#fff",
              				colorOffline: "red",
              			module: "alert",
              			module: "updatenotification",
              			position: "top_bar"
              			module: "clock",
              			position: "top_left"
                                      header: "Helgdagar",
              			maximumEntries: 5,
                                                              symbol: "calendar-check",
                                                              url: "webcal://localhost:8080/modules/ics/se_holidays.ics"
              	//		module: "compliments",
              	//		position: "lower_third"
              			module: "weather",
              				weatherProvider: "openmeteo",
              				type: "current",
              				lat: 55.60587,
              				lon: 13.00073
              			module: "weather",
              			header: "Väder",
              				type: "forecast",
              				lat: 55.60587,
              				lon: 13.00073
              			module: "newsfeed",
              			position: "top_bar",
              				feeds: [
              						title: "Sydsvenskan - Senaste nytt",
              						url: "https://www.sydsvenskan.se/feeds/feed.xml"
              				showSourceTitle: true,
              				showPublishDate: true,
              				broadcastNewsFeeds: true,
              				broadcastNewsUpdates: true
                                      module: 'MMM-Globe',
                                      position: 'middle_center',
                                              style: 'geoColor',
                                              imageSize: 300,
                                              ownImagePath:'',
                                              updateInterval: 10*60*1000
                sdetweil @Bimtronic
                @Bimtronic tgx
                This looks like it is caused by MMM-SystemStats module
                You can edit the MMM-SystemStats.js
                and comment it out (add // as the start of the text on that line)
                One occurance is not commented
                Or change it to Log.info
                  Bimtronic @sdetweil
                  I deleted MMM-SystemStats from my config.
                  Still getting errors >
                  [2024-12-11 19:48:33.034] [ERROR] App threw an error during load
                  [2024-12-11 19:48:33.042] [ERROR] TypeError: Log.log is not a function
                  Uncaught Exception:
                    sdetweil @Bimtronic
                    @Bimtronic so weird
                    add
                    disabled:true,
                    after every
                    module:
                    line
                    and change to false one at a time
                      Bimtronic @sdetweil
                      I disabled all modules, same errors.
                      Disabled all but not the “alert”-module, same errors.
                      I dont think is from the config, maybe the node.js file-system that is messed up.
                      How do i uninstall MagicMirror and make a new clean install to start from scratch?
                        sdetweil @Bimtronic
                        @Bimtronic use my backup/restore scripts yo save your MagicMirror setup
                        https://github.com/sdetweil/MagicMirror-backup-restore
                        then you can rename/delete the MagicMirror folder
                        and use my install script
                        see https://github.com/sdetweil/MagicMirror_scripts
                        and then use restore to put the MagicMirror configuration back
