    Fails to start... "Log.log is not a function"
    16 Posts 2 Posters 2.9k Views 2 Watching
      sdetweil @Bimtronic
      @Bimtronic in the MagicMirror folder
        Bimtronic @sdetweil
        I tried to run a new “npm install” in the MM-folder, but i still have the same errors.
        Is it advised to delete and reinstall Magic Mirror completely?
          sdetweil @Bimtronic
          @Bimtronic can you show me the output of the npm install
            Bimtronic @sdetweil
            mt@mt:~/MagicMirror $ npm install
            magicmirror@2.29.0 postinstall
            npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
            magicmirror@2.29.0 install-vendor
            echo "Installing vendor files …
            " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
            up to date in 3s
            magicmirror@2.29.0 install-fonts
            echo "Installing fonts …
            " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
            Installing fonts …
            up to date in 3s
            magicmirror@2.29.0 prepare
            [ -f node_modules/.bin/husky ] && husky || echo no husky installed.
            up to date in 56s
            208 packages are looking for funding
            run npm fund for details
            npm notice
            npm notice New patch version of npm available! 10.9.0 -> 10.9.2
            npm notice Changelog: https://github.com/npm/cli/releases/tag/v10.9.2
            npm notice To update run: npm install -g npm@10.9.2
            npm notice
              sdetweil @Bimtronic
              @Bimtronic ok and now, in the MagicMirror folder
              The output of npm start
                Bimtronic @sdetweil
                mt@mt:~/MagicMirror $ npm start
                magicmirror@2.29.0 start
                [2024-12-09 15:22:44.863] [ERROR] App threw an error during load
                [2024-12-09 15:22:44.871] [ERROR] TypeError: Log.log is not a function
                at Object. (/home/mt/MagicMirror/js/app.js:16:5)
                at Module._compile (node:internal/modules/cjs/loader:1484:14)
                at Module._extensions…js (node:internal/modules/cjs/loader:1564:10)
                at Module.load (node:internal/modules/cjs/loader:1295:32)
                at Module._load (node:internal/modules/cjs/loader:1111:12)
                at c._load (node:electron/js2c/node_init:2:17025)
                at Module.require (node:internal/modules/cjs/loader:1318:19)
                at require (node:internal/modules/helpers:179:18)
                at Object. (/home/mt/MagicMirror/js/electron.js:4:14)
                at cjsLoader (node:internal/modules/esm/translators:350:17)
                at ModuleWrap. (node:internal/modules/esm/translators:286:7)
                A JavaScript error occurred in the main process
                Uncaught Exception:
                  sdetweil @Bimtronic
                  @Bimtronic can you show me the config.js, xxx out any apikeys or private info
                    Bimtronic @sdetweil
                    Here it is, I really appreciate your help.
                    let config = {
                    	address: "localhost",				// Address to listen on, can be:
                    	port: 8080,
                    	basePath: "/",					// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
                    	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],		// Set [] to allow all IP addresses
                    	useHttps: false,	// Support HTTPS or not, default "false" will use HTTP
                    	httpsPrivateKey: "",	// HTTPS private key path, only require when useHttps is true
                    	httpsCertificate: "",	// HTTPS Certificate path, only require when useHttps is true
                    	language: "sv",
                    	locale: "sv-SV",
                    	timeFormat: 24,
                    	units: "metric",
                    		module: 'MMM-SystemStats',
                    		position: 'top_right', // This can be any of the regions.
                    		// classes: 'small dimmed', // Add your own styling. OPTIONAL.
                    		// header: 'System Stats', // Set the header text OPTIONAL
                    			updateInterval: 10000, // every 10 seconds
                    			align: 'right', // align labels
                    			//header: 'System Stats', // This is optional
                    			units: 'metric', // default, metric, imperial
                    			view: 'textAndIcon',
                    			module: "MMM-Online-State",
                    			position: "bottom_right",
                    				displaysymbol: true,
                    				symbolOnline: "wifi",
                    				colored: true,
                    				colorOnline: "#fff",
                    				colorOffline: "red",
                    			module: "alert",
                    			module: "updatenotification",
                    			position: "top_bar"
                    			module: "clock",
                    			position: "top_left"
                                            header: "Helgdagar",
                    			maximumEntries: 5,
        symbol: "calendar-check",
        url: "webcal://localhost:8080/modules/ics/se_holidays.ics"
                    	//		module: "compliments",
                    	//		position: "lower_third"
                    			module: "weather",
                    				weatherProvider: "openmeteo",
                    				type: "current",
                    				lat: 55.60587,
                    				lon: 13.00073
                    			module: "weather",
                    			header: "Väder",
                    				type: "forecast",
                    				lat: 55.60587,
                    				lon: 13.00073
                    			module: "newsfeed",
                    			position: "top_bar",
                    				feeds: [
                    						title: "Sydsvenskan - Senaste nytt",
                    						url: "https://www.sydsvenskan.se/feeds/feed.xml"
                    				showSourceTitle: true,
                    				showPublishDate: true,
                    				broadcastNewsFeeds: true,
                    				broadcastNewsUpdates: true
                                            module: 'MMM-Globe',
                                            position: 'middle_center',
                                                    style: 'geoColor',
                                                    imageSize: 300,
                                                    ownImagePath:'',
                                                    updateInterval: 10*60*1000
                      sdetweil @Bimtronic
                      @Bimtronic tgx
                      This looks like it is caused by MMM-SystemStats module
                      You can edit the MMM-SystemStats.js
                      and comment it out (add // as the start of the text on that line)
                      One occurance is not commented
                      Or change it to Log.info
                        Bimtronic @sdetweil
                        I deleted MMM-SystemStats from my config.
                        Still getting errors >
                        [2024-12-11 19:48:33.034] [ERROR] App threw an error during load
                        [2024-12-11 19:48:33.042] [ERROR] TypeError: Log.log is not a function
                        Uncaught Exception:
                          sdetweil @Bimtronic
                          @Bimtronic so weird
                          add
                          disabled:true,
                          after every
                          module:
                          line
                          and change to false one at a time
                            Bimtronic @sdetweil
                            I disabled all modules, same errors.
                            Disabled all but not the “alert”-module, same errors.
                            I dont think is from the config, maybe the node.js file-system that is messed up.
                            How do i uninstall MagicMirror and make a new clean install to start from scratch?
                              sdetweil @Bimtronic
                              @Bimtronic use my backup/restore scripts yo save your MagicMirror setup
                              https://github.com/sdetweil/MagicMirror-backup-restore
                              then you can rename/delete the MagicMirror folder
                              and use my install script
                              see https://github.com/sdetweil/MagicMirror_scripts
                              and then use restore to put the MagicMirror configuration back
