    MMM-MPlayer
    44 Posts 10 Posters 19.5k Views 10 Watching
    • evroomE
      evroom @myfingersarecold
      @myfingersarecold
      Hi there !
      This is most probably the module I was most anticipating for and that will enable me to finally go from ‘buster’ to ‘bookworm’.
      Finally a worthy and easy follow-up for OMXPlayer.
      I am still testing, but it looks very promising.
      Thanks a lot !
      E.J.
      PS I will have a few question later on.
      MagicMirror version: 2.37.0
      evroomE 1 Reply Last reply
      • evroomE
        evroom @evroom
        @myfingersarecold
        Here two questions:
        1/ What does streamInterval do ?
        2/ Is it possible to rotate the output ?
        I am using my screen in portrait mode and therefore need my RTSP stream to be rotated by 90 degrees.
        Thanks in advance.
        • KristjanESPERANTOK
          KristjanESPERANTO Module Developer @myfingersarecold
          @myfingersarecold Nice! It would be cool if you maybe reconsidered and uploaded it to GitHub 👩‍💻
          • evroomE
            evroom @KristjanESPERANTO
            In order to encourage and to help you a bit, here a README.md:
            # MMM-MPlayer
            A MagicMirror module that uses MPlayer to display rtsp streams
            ## Project Status
            This module is working, but still under development.
            ## Installation of mplayer
            ### Verify if mplayer is already installed
            ```shell
            $ which mplayer
            /usr/bin/mplayer
            Install mplayer (when not installed yet)
            $ sudo apt install -y mplayer
            Installation of the MM module
            1. In your terminal, change to your Magic Mirror module directory cd ~/MagicMirror/modules
            2. Clone this repository git clone https://github.com/myfingersarecold/MMM-MPlayer
            3. Make changes to your config.js file.
            Config Example
            Edit the file ~/MagicMirror/config/config.js to add or modify the module.
            	module: 'MMM-MPlayer',
                    disabled: false,
                    header: "MPlayer",
            	  useTwoWindows: true,
            	  layout: 'row',
            	  windowSize: { width: 525, height: 295 },
            	  windowPosition: { x: 12, y: 575 },
            	  streamInterval: 30000,
            	  streams: {
            		window1: [
            		  'something_else.mp4',
            		  'something.mp4'
            		window2: [
            		  'rtsp://foo',
            		  'rtsp://bar',
            Configuration Options
            Option Description Default
            useTwoWindows Use two windows true
            layout Can be ‘row’ or ‘column’ row
            windowSize Window size for both windows { width: 525, height: 295 }
            windowPosition Position of the first window (window1)
            [window2 is either 5px below or to the right of this window, depending on layout]
            { x: 12, y: 575 }
            streamInterval 30000
            streams window1 and / or window2 streams [ mp4 , rtsp ]
            Test environment
            This procedure has been tested on:
            • Raspberry Pi 4 Model B Rev 1.5
            • Debian GNU/Linux 12 (bookworm)
            • Magic Mirror version: 2.30.0
            Contributions
            Code provided by user ‘myfingersarecold’.
            https://forum.magicmirror.builders/user/myfingersarecold
            • evroomE
              evroom @evroom
              @evroom said in MMM-MPlayer:
              @myfingersarecold
              Here two questions:
              To answer my own questions:
              1/ Cycles the streams defined in window1 and/or window2 after the provided interval (in milliseconds).
              Where applicable, the streams will start from the beginning again (for example for mp4 videos).
              2/ Yes, this is possible using the -vf rotate=[0-3] option and adjusting the windowPosition values.
              M 1 Reply Last reply
              • evroomE
                @myfingersarecold said in MMM-MPlayer:
                I don’t feel like actually uploading it to github, but here is the source code, and an example config.
                I took the liberty to take the provided code, make changes to it and make it available as a public repository:
                https://github.com/evroom/MMM-MPlayer
                My own main purpose for using it, is to setup a new Raspberry Pi (Raspberry Pi 4 Model B), with Debian 12 (bookworm) and the latest MM version (2.30.0).
                Replacing a Pi 3b 32-bit Debian 10 buster setup where OMXPlayer is still working.
                I will be using a single window with a single RTSP stream (for an Axis Network Camera).
                Nothing fancy.
                Best regards,
                E.J.
                KristjanESPERANTOK M 2 Replies Last reply
                Reply Quote 2
                  KristjanESPERANTO Module Developer @evroom
                  @evroom Nice! 🚀 Please add it to the module list 🙂
                  • evroomE
                    @KristjanESPERANTO said in MMM-MPlayer:
                    Done.
                    Reply Quote 2
                      myfingersarecold @evroom
                      @evroom you are 100% correct regarding item #1, the streamInterval is for when multiple streams are defined, it will switch between the available streams.
                      regarding #2 on my pi i didnt have to rotate the mplayer orientation, but i adjusted the output of my pi to portrait and everything behaved but ymmv depending on how it’s setup.
                        @evroom thanks for that. glad its of use to someone 😊
                        • Cr4z33C
                          Cr4z33 @myfingersarecold
                          I couldnt get the EXT-FreeboxTV module to work on my magic mirror
                          Out of curiosity what was the issue with it?
                          I use that module all the time to watch the TV channels of my Enigma2 decoder.
                          • evroomE
                            Could you please tell me how you do the general rotation to portrait ?
                            I use the custom.css to get it rotated clockwise.
                            As MPlayer is an overlay, like OMXPlayer, it is not affected by this.
                            body {
                              transform: rotate(-90deg);
                              transform-origin: top left;
                              width: 100vh;
                              height: 100vw;
                            But of course there are more, potential better, ways of getting it rotated.
                              @evroom
                              i didnt use this guide to do it, but this is how i rotated my screen.
                              https://www.makeuseof.com/how-to-rotate-your-raspberry-pi-screen-without-moving-the-display/
                              I am running the latest version of raspbian on my pi3
                              this results in my magicmirror instance loading in portrait mode, and my 16x9 streams loading properly where i want them without having to do any CSS rotation.
                                myfingersarecold @Cr4z33
                                @Cr4z33 no idea but couldn’t get RTSP streams to work.
                                • G
                                  Guku
                                  HI, im running my MM on on Proxmox VM and pointing my display to IP on VM, when i try to run Mplayer it just displays black box but no feed, i doo see the feed on the server VM. any ideas how to get this playing on my remote display?
                                    sdetweil @Guku
                                    @Guku did you expose that port on the vm to another connecting host?
                                    maybe a firewall filter?
                                    I don’t use proxmox, but I see this on windows VM’s all the time
                                    G 1 Reply Last reply
                                    • G
                                      Guku @sdetweil
                                      thanks for checking in with me, i gave up on the player since even when i ran it localy on my VM the camera feed was delayed by about 5sec which defeted the pourpose. thanks anyways!
                                        clakkentt
                                        Just a comment
                                        I am using MagicMirror on a pi using bullseye 32bit.
                                        When using a rpi4 everything works fine. When I transfer the sd card to a rpi3 every time the MPlayer shows a live feed the desktop taskbar shows up, when MPlayer is switching between feeds the taskbar is not visible.
                                        This is probably due to my specific choice of settings but just thought it might help someone.
                                          sdetweil @clakkentt
                                          @clakkentt if you use my backup/restore to capture your MM config
                                          and build a new card ON the pi3, and install MM and restore the config
                                          do you see the same problem?
                                          backup/restore here https://github.com/sdetweil/MagicMirror-backup-restore
                                          install/upgrade here https://github.com/sdetweil/MagicMirror_scripts
                                          C 1 Reply Last reply
                                            clakkentt @sdetweil
                                            Yes the problem is the same. I initially had MM running on a rpi3, when I installed MMM-MPlayer, I noticed the taskbar showing every time there was a feed showing.
                                            I started from scratch on an rpi4 and saw no problem but when I transferred the card to the rpi3 the issue came up again.
                                            Since I wanted to keep using the rpi3 for the MagicMirror I solved the problem by making the taskbar 0 pixels in height.
