    2.30.0 and MMM-CalendarExt3 missing calendars
    29 Posts 3 Posters 8.7k Views 4 Watching
      redfishbluefish
      2.30.0 doesn’t seem to be playing nicely with MMM-CalendarExt3 in my setup and I don’t see any clues in the logs as to why. Default calendar modules appears to be working as expected and I can see that the Calendar-Fetcher is broadcasting events for all of my calendars.
      Oddly, events from one of the 5 calendars I’m using do appear in MMM-CalendarExt3 correctly. Changing order of calendar definitions in the config.js make no difference.
      The only error I see in logs is shown below but this appears to be related to a known issue in MMM-RemoteControl and MMM-CalendarExt3 (and the error goes away if I disable MMM-RemoteControl) which is also present when I’m running 2.29.0.
      0|mm  | [2025-01-01 15:51:41.985] [ERROR] ERROR! Could not validate main module js file.
      0|mm  | [2025-01-01 15:51:41.992] [ERROR] ReferenceError: HTMLElement is not defined
      0|mm  |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-CalendarExt3/MMM-CalendarExt3.js:6:26)
      0|mm  |     at Module._compile (node:internal/modules/cjs/loader:1484:14)
      0|mm  |     at Module._extensions..js (node:internal/modules/cjs/loader:1564:10)
      0|mm  |     at Module.load (node:internal/modules/cjs/loader:1295:32)
      0|mm  |     at Module._load (node:internal/modules/cjs/loader:1111:12)
      0|mm  |     at c._load (node:electron/js2c/node_init:2:17025)
      0|mm  |     at Module.require (node:internal/modules/cjs/loader:1318:19)
      0|mm  |     at require (node:internal/modules/helpers:179:18)
      0|mm  |     at Class.loadModuleDefaultConfig (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:317:30)
      0|mm  |     at /home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:271:26
      0|mm  |     at FSReqCallback.oncomplete (node:fs:198:5)
      I have since done a revert to 2.29.0 and with the exact same config.js etc, MMM-CalendarExt3 is working fine. I’m going to try and spin up a server only version of 2.30.0 to poke at since I can’t wipe out my main installation.
        @redfishbluefish
        apply this fix
        see
        https://forum.magicmirror.builders/topic/19282/version-2-30-0-calendar-fix-for-clipping-broadcast-events
          sdetweil @redfishbluefish
          @redfishbluefish i am using ext3 w 2.30
          did u use my script or manual upgrade
          because if the nodejs change you may need to nom instsll agsin to get the extension installed
            redfishbluefish @sdetweil
            @sdetweil manual upgrade. I also did a reinstall of the modules I use since nodes changed.
            MMM-CalendarExt3 was installed/working with 2.30.0 as it shows up and has the info for one of the calendars but not for all calendars.
              @redfishbluefish timing may have changed.
              can you look at the output of npm start and see if the events were broadcast
              if using pm2, then pm2 logs --lines=xxxx
              xxxx is the number of most recent lines to show, default 15
              ext3 tries to wait and not flash every time events arrive .
              there is a delay parm for next time to check, its fairly long
                @sdetweil I updated my docker server-only install to 2.30.0 to test on. The config.js file is almost identical to what I have on my RPi and this is what I see after restarting MagicMirror:
                [2025-01-01 17:45:14.379] [LOG]   Starting MagicMirror: v2.30.0
                [2025-01-01 17:45:14.397] [LOG]   Loading config ...
                [2025-01-01 17:45:14.400] [LOG]   config template file not exists, no envsubst
                [2025-01-01 17:45:14.790] [INFO]  Checking config file /opt/magic_mirror/config/config.js ...
                [2025-01-01 17:45:14.889] [INFO]  Your configuration file doesn't contain syntax errors :)
                [2025-01-01 17:45:14.890] [INFO]  Checking modules structure configuration ...
                [2025-01-01 17:45:14.971] [INFO]  Your modules structure configuration doesn't contain errors :)
                [2025-01-01 17:45:15.119] [LOG]   Loading module helpers ...
                [2025-01-01 17:45:15.123] [LOG]   No helper found for module: alert.
                [2025-01-01 17:45:15.140] [LOG]   Initializing new module helper ...
                [2025-01-01 17:45:15.141] [LOG]   Module helper loaded: MMM-Wheel
                [2025-01-01 17:45:15.146] [LOG]   No helper found for module: MMM-Carousel.
                [2025-01-01 17:45:15.194] [LOG]   Initializing new module helper ...
                [2025-01-01 17:45:15.195] [LOG]   Module helper loaded: updatenotification
                [2025-01-01 17:45:15.198] [LOG]   No helper found for module: clock.
                [2025-01-01 17:45:15.211] [LOG]   Initializing new module helper ...
                [2025-01-01 17:45:15.211] [LOG]   Module helper loaded: MMM-UCDSB
                [2025-01-01 17:45:15.214] [LOG]   No helper found for module: weather.
                [2025-01-01 17:45:15.391] [LOG]   Initializing new module helper ...
                [2025-01-01 17:45:15.392] [LOG]   Module helper loaded: calendar
                [2025-01-01 17:45:15.396] [LOG]   No helper found for module: MMM-CalendarExt3.
                [2025-01-01 17:45:15.397] [LOG]   All module helpers loaded.
                [2025-01-01 17:45:15.406] [LOG]   Starting server on port 8080 ...
                [2025-01-01 17:45:15.409] [WARN]  You're using a full whitelist configuration to allow for all IPs
                [2025-01-01 17:45:15.427] [LOG]   Server started ...
                [2025-01-01 17:45:15.428] [LOG]   Connecting socket for: MMM-Wheel
                [2025-01-01 17:45:15.429] [LOG]   Starting module helper: MMM-Wheel
                [2025-01-01 17:45:15.429] [LOG]   Connecting socket for: updatenotification
                [2025-01-01 17:45:15.430] [LOG]   Starting module helper: updatenotification
                [2025-01-01 17:45:15.431] [LOG]   Connecting socket for: MMM-UCDSB
                [2025-01-01 17:45:15.431] [LOG]   Starting module helper: MMM-UCDSB
                [2025-01-01 17:45:15.432] [LOG]   Connecting socket for: calendar
                [2025-01-01 17:45:15.432] [LOG]   Starting node helper for: calendar
                [2025-01-01 17:45:15.432] [LOG]   Sockets connected & modules started ...
                [2025-01-01 17:45:15.433] [INFO]
                >>>   Ready to go! Please point your browser to: http://0.0.0.0:8080   <<<
                [2025-01-01 17:45:15.669] [INFO]  System information:
                ### SYSTEM:   manufacturer: ; model: Docker Container; virtual: false
                ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: x64; kernel: 5.15.49-linuxkit
                ### VERSIONS: electron: undefined; used node: 22.12.0; installed node: 22.12.0; npm: 10.9.0; pm2:
                ### OTHER:    timeZone: America/Toronto; ELECTRON_ENABLE_GPU: undefined
                I notice that there are no calendar events being broadcast at all (which likely makes sense since nothing has attempted to load the page yet).
                After loading the site I get (calendar urls deleted):
                [2025-01-01 17:48:40.701] [LOG]   Create new calendarfetcher for url: Holidays.ics - Interval: 3600000
                [2025-01-01 17:48:40.786] [LOG]   Create new calendarfetcher for url: basic1.ics - Interval: 3600000
                [2025-01-01 17:48:40.791] [LOG]   Create new calendarfetcher for url: calendarId=1509643 - Interval: 3600000
                [2025-01-01 17:48:40.797] [LOG]   Create new calendarfetcher for url: basic2.ics - Interval: 3600000
                [2025-01-01 17:48:40.803] [LOG]   Create new calendarfetcher for url: basic3.ics - Interval: 3600000
                [2025-01-01 17:48:40.891] [INFO]  updatenotification: Updater Class Loaded!
                [2025-01-01 17:48:40.892] [INFO]  updatenotification: Checking PM2 using...
                [2025-01-01 17:48:40.892] [INFO]  updatenotification: Running in docker container, not using PM2 ...
                [2025-01-01 17:48:40.893] [INFO]  Checking git for module: MMM-Wheel
                [2025-01-01 17:48:40.895] [INFO]  Checking git for module: MMM-Carousel
                [2025-01-01 17:48:40.920] [INFO]  Checking git for module: MMM-UCDSB
                [2025-01-01 17:48:40.942] [INFO]  Checking git for module: MMM-CalendarExt3
                [2025-01-01 17:48:41.003] [INFO]  Calendar-Fetcher: Broadcasting 34 events from Holidays.ics.
                [2025-01-01 17:48:41.021] [INFO]  Checking git for module: MagicMirror
                [2025-01-01 17:48:41.053] [INFO]  Calendar-Fetcher: Broadcasting 61 events from calendarId=1509643.
                [2025-01-01 17:48:41.112] [INFO]  Calendar-Fetcher: Broadcasting 3 events from basic3.ics.
                [2025-01-01 17:48:41.826] [INFO]  Calendar-Fetcher: Broadcasting 294 events from basic1.ics.
                [2025-01-01 17:48:42.801] [INFO]  Calendar-Fetcher: Broadcasting 282 events from basic2.ics.
                The basic3.ics calendar event show in MMM-CalendarExt3 but nothing else.
                R S 2 Replies Last reply Reply Quote 0
                  redfishbluefish @redfishbluefish
                  This post looks like a similar issue: https://forum.magicmirror.builders/topic/19273/mmm-calendarext3-not-showing-events-on-calendar-but-does-on-list-after-2-30-update
                    @redfishbluefish ok, cal module is working
                    ext3 is done all in browser,
                    open the developer window, ctrl-shift-i,
                    select the console tab
                    add ext to the filter field
                      @redfishbluefish you both reported at approximately same time
                        @sdetweil I get what’s in the screenshot in the console but CalendarExt3 is loaded in the browser correctly.
                        Note that this looks identical to what I see when running 2.29.0.
                          @redfishbluefish hm… I have 3 instances , on pages, with multiple cals.
                          all three instances are working…
                          I checked was downlevel (on 1.8.5), now on 1.9.4 latest… no change. all working as expected. I added a calendar fix reported by author, about calendar symbols in an array
                          symbol: [ “foo”, “bar” ]
                          but you aren’t seeing any exceptions
                            @sdetweil thanks for looking at this. I’d love to see an error of some sorts - much easier to track down! :)
                            I’ll strip down to a basic config.js and see if I can find something that works for me and maybe that will give some clues.
                              @redfishbluefish all you have to do is add
                              disabled:true,
                              after all the modules to turn off
                                @redfishbluefish
                                or copy the sample config
                                add the cal and ext3 stuff
                                then
                                export MM_CONFIG_FILE=config/xxxxx
                                npm start
                                xxxx is the new config name
                                  MMRIZE @redfishbluefish
                                  @redfishbluefish
                                  To make things simple;
                                  • Disable all other modules except clock, calendar, MMM-CalendarExt3.
                                  If you still have issue or found any error log (front-end log in your browser, not back-end log in your terminal), report me.
                                  However, in my test, it works on the new installation of MM 2.30.
                                    redfishbluefish @MMRIZE
                                    @MMRIZE I’m running a server-only instance in docker for testing now with this config.js:
                                    let config = {
                                    	address: "0.0.0.0",
                                    	port: 8080,
                                    	basePath: "/",
                                    	ipWhitelist: [],
                                    	useHttps: false,
                                    	httpsPrivateKey: "",
                                    	httpsCertificate: "",
                                    	language: "en",
                                    	locale: "en-US",
                                    	logLevel: ["INFO", "LOG", "WARN", "ERROR"],
                                    	timeFormat: 24,
                                    	units: "metric",
                                    			module: "clock",
                                    				timeFormat: 12,
                                    				broadcastPastEvents: true, // <= IMPORTANT to see past events
                                    				defaultSymbol: "square",
                                    						url: "https://ics.calendarlabs.com/39/f7480acf/Canada_Holidays.ics",
                                    						name: "can_holiday", // <= RECOMMENDED to assign name
                                    						color: "crimson", // <= RECOMMENDED to assign color
                                    			module: "MMM-CalendarExt3",
                                    			position: "bottom_bar",
                                    			title: "",
                                    				mode: "week",
                                    				weeksInView: 4,
                                    				weekIndex: 0,
                                    				useWeather: false,
                                    				displayEndTime: false,
                                    				instanceId: "basicCalendar",
                                    				maxEventLines: 6,
                                    				fontSize: '24px',
                                    				eventHeight: '26px',
                                    				refreshInterval: 1000 * 60 * 5,
                                    				useMarquee: false,
                                    				calendarSet: ['can_holiday'],
                                    Today (Jan 1) should have a full day event on CalendarExt3 for New Year’s Day (as seen in top right calendar output).
                                    Front end logs:
                                    [Info] Initializing MagicMirror². (main.js, line 582)
                                    [Log] Loading core translation file: translations/en.json (translator.js, line 116)
                                    [Log] Loading core translation fallback file: translations/en.json (translator.js, line 132)
                                    [Log] Load script: modules/default/clock/clock.js (loader.js, line 178)
                                    [Log] Module registered: clock (module.js, line 489)
                                    [Info] Bootstrapping module: clock (loader.js, line 151)
                                    [Log] Load script: vendor/node_modules/moment/min/moment-with-locales.js (loader.js, line 178)
                                    [Log] Load script: vendor/node_modules/moment-timezone/builds/moment-timezone-with-data.js (loader.js, line 178)
                                    [Log] Load script: vendor/node_modules/suncalc/suncalc.js (loader.js, line 178)
                                    [Log] Scripts loaded for: clock (loader.js, line 155)
                                    [Log] Load stylesheet: modules/default/clock/clock_styles.css (loader.js, line 194)
                                    [Log] Styles loaded for: clock (loader.js, line 158)
                                    [Log] Translations loaded for: clock (loader.js, line 161)
                                    [Log] Load script: modules/default/calendar/calendar.js (loader.js, line 178)
                                    [Log] Check MagicMirror² version for module 'calendar' - Minimum version:  2.1.0 - Current version: 2.30.0 (module.js, line 481)
                                    [Log] Version is ok! (module.js, line 483)
                                    [Log] Module registered: calendar (module.js, line 489)
                                    [Info] Bootstrapping module: calendar (loader.js, line 151)
                                    [Log] Load script: modules/default/calendar/calendarutils.js (loader.js, line 178)
                                    [Log] File already loaded: moment.js (loader.js, line 254)
                                    [Log] Scripts loaded for: calendar (loader.js, line 155)
                                    [Log] Load stylesheet: modules/default/calendar/calendar.css (loader.js, line 194)
                                    [Log] Load stylesheet: vendor/css/font-awesome.css (loader.js, line 194)
                                    [Log] Styles loaded for: calendar (loader.js, line 158)
                                    [Log] Translations loaded for: calendar (loader.js, line 161)
                                    [Log] Load script: modules/MMM-CalendarExt3/MMM-CalendarExt3.js (loader.js, line 178)
                                    [Log] Module registered: MMM-CalendarExt3 (module.js, line 489)
                                    [Info] Bootstrapping module: MMM-CalendarExt3 (loader.js, line 151)
                                    [Log] Scripts loaded for: MMM-CalendarExt3 (loader.js, line 155)
                                    [Log] Load stylesheet: modules/MMM-CalendarExt3/MMM-CalendarExt3.css (loader.js, line 194)
                                    [Log] Styles loaded for: MMM-CalendarExt3 (loader.js, line 158)
                                    [Log] Translations loaded for: MMM-CalendarExt3 (loader.js, line 161)
                                    [Log] Load stylesheet: css/custom.css (loader.js, line 194)
                                    [Info] Starting module: clock (clock.js, line 43)
                                    [Info] Starting module: calendar (calendar.js, line 96)
                                    [Info] All modules started! (main.js, line 601)
                                    [Info] sorting events count=0 (calendar.js, line 699)
                                    [Info] slicing events total maxcount=10 (calendar.js, line 739)
                                    [Warning] [CX3] Module is not prepared yet, wait a while. (MMM-CalendarExt3.js, line 390)
                                    [Info] sorting events count=10 (calendar.js, line 699)
                                    [Info] event fullday (calendar.js, line 506, x10)
                                    And for completeness, backend logs:
                                    [2025-01-01 21:05:03.871] [LOG]   Starting MagicMirror: v2.30.0
                                    [2025-01-01 21:05:03.886] [LOG]   Loading config ...
                                    [2025-01-01 21:05:03.889] [LOG]   config template file not exists, no envsubst
                                    [2025-01-01 21:05:04.171] [INFO]  Checking config file /opt/magic_mirror/config/config.js ...
                                    [2025-01-01 21:05:04.216] [INFO]  Your configuration file doesn't contain syntax errors :)
                                    [2025-01-01 21:05:04.217] [INFO]  Checking modules structure configuration ...
                                    [2025-01-01 21:05:04.312] [INFO]  Your modules structure configuration doesn't contain errors :)
                                    [2025-01-01 21:05:04.412] [LOG]   Loading module helpers ...
                                    [2025-01-01 21:05:04.415] [LOG]   No helper found for module: clock.
                                    [2025-01-01 21:05:04.583] [LOG]   Initializing new module helper ...
                                    [2025-01-01 21:05:04.585] [LOG]   Module helper loaded: calendar
                                    [2025-01-01 21:05:04.590] [LOG]   No helper found for module: MMM-CalendarExt3.
                                    [2025-01-01 21:05:04.590] [LOG]   All module helpers loaded.
                                    [2025-01-01 21:05:04.600] [LOG]   Starting server on port 8080 ...
                                    [2025-01-01 21:05:04.602] [WARN]  You're using a full whitelist configuration to allow for all IPs
                                    [2025-01-01 21:05:04.612] [LOG]   Server started ...
                                    [2025-01-01 21:05:04.613] [LOG]   Connecting socket for: calendar
                                    [2025-01-01 21:05:04.614] [LOG]   Starting node helper for: calendar
                                    [2025-01-01 21:05:04.615] [LOG]   Sockets connected & modules started ...
                                    [2025-01-01 21:05:04.615] [INFO]
                                    [2025-01-01 21:05:04.744] [INFO]  System information:
                                    [2025-01-01 21:05:18.517] [LOG]   Create new calendarfetcher for url: https://ics.calendarlabs.com/39/f7480acf/Canada_Holidays.ics - Interval: 3600000
                                    [2025-01-01 21:05:18.779] [INFO]  Calendar-Fetcher: Broadcasting 34 events from https://ics.calendarlabs.com/39/f7480acf/Canada_Holidays.ics.
                                    [2025-01-01 21:13:12.600] [LOG]   Use existing calendarfetcher for url: https://ics.calendarlabs.com/39/f7480acf/Canada_Holidays.ics
                                    [2025-01-01 21:13:12.601] [INFO]  Calendar-Fetcher: Broadcasting 34 events from https://ics.calendarlabs.com/39/f7480acf/Canada_Holidays.ics.
                                    [2025-01-01 21:13:12.837] [INFO]  Calendar-Fetcher: Broadcasting 34 events from https://ics.calendarlabs.com/39/f7480acf/Canada_Holidays.ics.
                                      @redfishbluefish
                                      At first, I thought the New Year's Day event wasn’t visible because of a time zone issue (since I live in Germany, it’s already January 2nd here).
                                      So, I downloaded the ICS file and changed the date of the New Year's Day event from 20250101 to 20250102 for testing. When I tested it, I encountered the same issue you mentioned!!!
                                      I was quite confused, but to confirm, I used the following:
                                      eventPayload: (events) => {
                                      	console.log(events)
                                      	return events
                                      The eventPayload function is a great place to check what data has actually been broadcasted since it executes whenever events are received.
                                      As a result…
                                      ??? New Year's Day isn’t being broadcasted?? I still don’t know why.
                                      You can compare the display(left) and the console(right). In right, there is no New Year's Day event. the calendar module doesn’t emit that event. CX3 cannot draw undelivered events.
                                      @sdetweil I think it’s better you check this symptom. the default calendar miss this event to broadcast, but don’t know why.
                                        sdetweil @MMRIZE
                                        @MMRIZE ok will check it
                                        if you change maxevents in default cal does it affect
                                        the results
                                          MMRIZE
                                          I think I found it.
                                          Add these into the default calendar module.
                                          maximumEntries: 100,
                                          maximumNumberOfDays: 365,
                                            sdetweil @MMRIZE
                                            @MMRIZE the default
                                            maxEntries is 10
                                              @MMRIZE was in 2.29 as well
