    2.30.0 and MMM-CalendarExt3 missing calendars
    29 Posts 3 Posters 7.6k Views 4 Watching
      redfishbluefish @sdetweil
      @sdetweil manual upgrade. I also did a reinstall of the modules I use since nodes changed.
      MMM-CalendarExt3 was installed/working with 2.30.0 as it shows up and has the info for one of the calendars but not for all calendars.
        sdetweil @redfishbluefish
        @redfishbluefish timing may have changed.
        can you look at the output of npm start and see if the events were broadcast
        if using pm2, then pm2 logs --lines=xxxx
        xxxx is the number of most recent lines to show, default 15
        ext3 tries to wait and not flash every time events arrive .
        there is a delay parm for next time to check, its fairly long
          @sdetweil I updated my docker server-only install to 2.30.0 to test on. The config.js file is almost identical to what I have on my RPi and this is what I see after restarting MagicMirror:
          [2025-01-01 17:45:14.379] [LOG]   Starting MagicMirror: v2.30.0
          [2025-01-01 17:45:14.397] [LOG]   Loading config ...
          [2025-01-01 17:45:14.400] [LOG]   config template file not exists, no envsubst
          [2025-01-01 17:45:14.790] [INFO]  Checking config file /opt/magic_mirror/config/config.js ...
          [2025-01-01 17:45:14.889] [INFO]  Your configuration file doesn't contain syntax errors :)
          [2025-01-01 17:45:14.890] [INFO]  Checking modules structure configuration ...
          [2025-01-01 17:45:14.971] [INFO]  Your modules structure configuration doesn't contain errors :)
          [2025-01-01 17:45:15.119] [LOG]   Loading module helpers ...
          [2025-01-01 17:45:15.123] [LOG]   No helper found for module: alert.
          [2025-01-01 17:45:15.140] [LOG]   Initializing new module helper ...
          [2025-01-01 17:45:15.141] [LOG]   Module helper loaded: MMM-Wheel
          [2025-01-01 17:45:15.146] [LOG]   No helper found for module: MMM-Carousel.
          [2025-01-01 17:45:15.194] [LOG]   Initializing new module helper ...
          [2025-01-01 17:45:15.195] [LOG]   Module helper loaded: updatenotification
          [2025-01-01 17:45:15.198] [LOG]   No helper found for module: clock.
          [2025-01-01 17:45:15.211] [LOG]   Initializing new module helper ...
          [2025-01-01 17:45:15.211] [LOG]   Module helper loaded: MMM-UCDSB
          [2025-01-01 17:45:15.214] [LOG]   No helper found for module: weather.
          [2025-01-01 17:45:15.391] [LOG]   Initializing new module helper ...
          [2025-01-01 17:45:15.392] [LOG]   Module helper loaded: calendar
          [2025-01-01 17:45:15.396] [LOG]   No helper found for module: MMM-CalendarExt3.
          [2025-01-01 17:45:15.397] [LOG]   All module helpers loaded.
          [2025-01-01 17:45:15.406] [LOG]   Starting server on port 8080 ...
          [2025-01-01 17:45:15.409] [WARN]  You're using a full whitelist configuration to allow for all IPs
          [2025-01-01 17:45:15.427] [LOG]   Server started ...
          [2025-01-01 17:45:15.428] [LOG]   Connecting socket for: MMM-Wheel
          [2025-01-01 17:45:15.429] [LOG]   Starting module helper: MMM-Wheel
          [2025-01-01 17:45:15.429] [LOG]   Connecting socket for: updatenotification
          [2025-01-01 17:45:15.430] [LOG]   Starting module helper: updatenotification
          [2025-01-01 17:45:15.431] [LOG]   Connecting socket for: MMM-UCDSB
          [2025-01-01 17:45:15.431] [LOG]   Starting module helper: MMM-UCDSB
          [2025-01-01 17:45:15.432] [LOG]   Connecting socket for: calendar
          [2025-01-01 17:45:15.432] [LOG]   Starting node helper for: calendar
          [2025-01-01 17:45:15.432] [LOG]   Sockets connected & modules started ...
          [2025-01-01 17:45:15.433] [INFO]
          >>>   Ready to go! Please point your browser to: http://0.0.0.0:8080   <<<
          [2025-01-01 17:45:15.669] [INFO]  System information:
          ### SYSTEM:   manufacturer: ; model: Docker Container; virtual: false
          ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: x64; kernel: 5.15.49-linuxkit
          ### VERSIONS: electron: undefined; used node: 22.12.0; installed node: 22.12.0; npm: 10.9.0; pm2:
          ### OTHER:    timeZone: America/Toronto; ELECTRON_ENABLE_GPU: undefined
          I notice that there are no calendar events being broadcast at all (which likely makes sense since nothing has attempted to load the page yet).
          After loading the site I get (calendar urls deleted):
          [2025-01-01 17:48:40.701] [LOG]   Create new calendarfetcher for url: Holidays.ics - Interval: 3600000
          [2025-01-01 17:48:40.786] [LOG]   Create new calendarfetcher for url: basic1.ics - Interval: 3600000
          [2025-01-01 17:48:40.791] [LOG]   Create new calendarfetcher for url: calendarId=1509643 - Interval: 3600000
          [2025-01-01 17:48:40.797] [LOG]   Create new calendarfetcher for url: basic2.ics - Interval: 3600000
          [2025-01-01 17:48:40.803] [LOG]   Create new calendarfetcher for url: basic3.ics - Interval: 3600000
          [2025-01-01 17:48:40.891] [INFO]  updatenotification: Updater Class Loaded!
          [2025-01-01 17:48:40.892] [INFO]  updatenotification: Checking PM2 using...
          [2025-01-01 17:48:40.892] [INFO]  updatenotification: Running in docker container, not using PM2 ...
          [2025-01-01 17:48:40.893] [INFO]  Checking git for module: MMM-Wheel
          [2025-01-01 17:48:40.895] [INFO]  Checking git for module: MMM-Carousel
          [2025-01-01 17:48:40.920] [INFO]  Checking git for module: MMM-UCDSB
          [2025-01-01 17:48:40.942] [INFO]  Checking git for module: MMM-CalendarExt3
          [2025-01-01 17:48:41.003] [INFO]  Calendar-Fetcher: Broadcasting 34 events from Holidays.ics.
          [2025-01-01 17:48:41.021] [INFO]  Checking git for module: MagicMirror
          [2025-01-01 17:48:41.053] [INFO]  Calendar-Fetcher: Broadcasting 61 events from calendarId=1509643.
          [2025-01-01 17:48:41.112] [INFO]  Calendar-Fetcher: Broadcasting 3 events from basic3.ics.
          [2025-01-01 17:48:41.826] [INFO]  Calendar-Fetcher: Broadcasting 294 events from basic1.ics.
          [2025-01-01 17:48:42.801] [INFO]  Calendar-Fetcher: Broadcasting 282 events from basic2.ics.
          The basic3.ics calendar event show in MMM-CalendarExt3 but nothing else.
          R S 2 Replies Last reply Reply Quote 0
            redfishbluefish @redfishbluefish
            This post looks like a similar issue: https://forum.magicmirror.builders/topic/19273/mmm-calendarext3-not-showing-events-on-calendar-but-does-on-list-after-2-30-update
              @redfishbluefish ok, cal module is working
              ext3 is done all in browser,
              open the developer window, ctrl-shift-i,
              select the console tab
              add ext to the filter field
                @redfishbluefish you both reported at approximately same time
                  @sdetweil I get what’s in the screenshot in the console but CalendarExt3 is loaded in the browser correctly.
                  Note that this looks identical to what I see when running 2.29.0.
                    @redfishbluefish hm… I have 3 instances , on pages, with multiple cals.
                    all three instances are working…
                    I checked was downlevel (on 1.8.5), now on 1.9.4 latest… no change. all working as expected. I added a calendar fix reported by author, about calendar symbols in an array
                    symbol: [ “foo”, “bar” ]
                    but you aren’t seeing any exceptions
                      @sdetweil thanks for looking at this. I’d love to see an error of some sorts - much easier to track down! :)
                      I’ll strip down to a basic config.js and see if I can find something that works for me and maybe that will give some clues.
                        @redfishbluefish all you have to do is add
                        disabled:true,
                        after all the modules to turn off
